"Epox 8KHA+ + thermal diode of the Athlon XP ?"
Gjest Slettet+1374861
Hello,
I think about buying this motherboard (according to my local hardware-store it should be available soon), but there is one question which bothers me:
According to several news articles, the thermal diode of the Athlon XP can only then function properly, when it is supported by the motherboard.
Does the Epox 8KHA+ support the thermal diode of the Athlon XP, so it can/should prevent the CPU from overheating ?
If not, is there a board available, which does ?
Thank you in advance.
With best regards,
Patrique Wolfrum
no boards support it now.
Game Over?? Your're damn right I'm OVER!
My Rig
Heatware
Er ikke helt med her...noen forklar meg dette please!
