Rare farger på mobilen, hvordan bytte tilbake igjen?
Du har nok bare aktivert negative farger, prøv følgende :
How to turn on or off negative colours?
If you want to customize this option or want to fix the negative screen issue caused by an accidentally enabling this option, then kindly follow the steps listed below:
  1. Go to Apps through Home screen.
  2. Scroll to Settings, then tap on it.
  3. Scroll to Accessibility, then tap on it.
  4. Scroll down to the Vision section. Depending on your current settings tap Negative colours option to enable or disable this option. When the checkbox next to this option is ticked means the phone will reverse the colours of the screen.
  5. Tap Home button to return to the standby mode.
