E-post fra MicroSoft
Zeph
Fikk denne mailen: Avsender var Customer Support
Microsoft All Products | Support | Search | Microsoft.com Guide
Microsoft Home
MS Partner
this is the latest version of security update, the "October 2003, Cumulative Patch" update which eliminates all known security vulnerabilities affecting MS Internet Explorer, MS Outlook and MS Outlook Express as well as three newly discovered vulnerabilities. Install now to help protect your computer. This update includes the functionality of all previously released patches.
System requirements Windows 95/98/Me/2000/NT/XP
This update applies to MS Internet Explorer, version 4.01 and later
MS Outlook, version 8.00 and later
MS Outlook Express, version 4.01 and later
Recommendation Customers should install the patch at the earliest opportunity.
How to install Run attached file. Choose Yes on displayed dialog box.
How to use You don't need to do anything after installing this item.
Microsoft Product Support Services and Knowledge Base articles can be found on the Microsoft Technical Support web site. For security-related information about Microsoft products, please visit the Microsoft Security Advisor web site, or Contact Us.
Thank you for using Microsoft products.
Please do not reply to this message. It was sent from an unmonitored e-mail address and we are unable to respond to any replies.
The names of the actual companies and products mentioned herein are the trademarks of their respective owners.
Contact Us | Legal | TRUSTe
©2003 Microsoft Corporation. All rights reserved. Terms of Use | Privacy Statement | Accessibility
Den ser jo ok ut, men eg tar ikkje sjanser på slikt. Noen som kan bekrefeavkrefte om denne er trygg å opne? Har aldri fått e-post fra MS før og lurer på hvor de fikk adressa mi fra.
den der settningen, du gjør lurt i å ikke åpne den kunne du spart deg. for hva tror du han har gjort da, når han skrev det som stod i mailen? da har han jo allerede fått viruset på maskina da jo.
det er vel vedlegget han kanskje sikter til, ikke å åpne selve e-posten.....eller hva ? Skyter du fra hofta, Wil ?
Har fått noen av disse mailene fra "Microsoft", og det gjorde meg mistenksom med det samme. Det beste som skjedde var at PC-Cillin fjernet viruset som fulgte med.
Det undrer meg at det er noen som tør å gå på stram line, uten sikkerhetsnett. Kjøp deg et godt antivirusprogram. Det koster ikke all verden, og du sparer masse jobb i fremtiden.....
