internett lagg
Gjest medlem-332567
Gjest medlem-332567
As for cable TV internet, you don't have your own connection, you share one with your neighborhood, its how the cable line is wired.
One line goes into the neighborhood and its get split up by normal coaxle splitters. The one the Cable company uses in that outdoor unit is more of a hub that a splitter, but it works on the completely same principles, instead of a one line in 2 out splitter, its a 10 way splitter. coaxle cable the cable company uses is meant for TV signals not modern Internet.
er det mulig at hele nettet går til det, hvis ja hvordan forsikrere jeg meg om at det skjer?
jeg har hatt lagg hele dagen.
Tror ikke det er så mye i det de fleste sentrale steder i Norge i alle fall.
Selvsagt hvis det er dårlige linjer der du bor.
Kjør speedtest.net så ser du den reelle hastigheten din. Er den som du betaler for, så er det nok noe annet.
