Feilen du har er visst ikke unormal for den repeateren.
http://forum.tp-link.com/showthread.php?5114-TL-WA850RE-keeps-disconnecting-a-few-times-every-hour-help-please
FOOTNOTE: Well 2 weeks later we appear to have a new problem ... the signal drops when a new gadget connects with the network. The repeater works perfectly for hours and hours but as soon as somebody turns on an additional gadget (usually an Apple iPad or a laptop) and tries to connect to wifi the signal drops and *ALL* wireless connections are lost from our original router along with the TP-LINK repeater.
FOOTNOTE 2:Some good news and some bad news. We found that by changing the wifi network settings on iPads and iPods there was a definite improvement although it only lasted for a few days. If you're interested in giving it a try too then (on your Apple products) choose Settings-->Wi-Fi-->Select your wifi signal and then at the bottom of the next screen change the 'HTTP proxy' setting from 'Off' to 'Auto'. Not sure why this solved the TP-LINK problem for 2 days and then failed(?); might be a permanent fix for you though.
FOOTNOTE 3: Following a lot of research everything is pointing towards clashes with security protocol when multiple devices (iPads, iPods, laptops, etc) try to join and leave the wifi signal generated by the TP-LINK repeater. We're using WPA2-PSK (as most people do) so what are the options? Change to WEP? Definitely a backward step. Hit it with a thumping-great mallet? Tempting. Send it back and try a different one? Probably.
