Firewall problem Asus RT-AC66U
har fått ett snålt problem som har kommet den siste tiden, det som skjer er at jeg logger på en server jeg har stående på loftet (win2008 server) med remote desktop, og laster ned torrents (lovlige selvsagt....), av og til kan jeg legge på en, av og til tre, og av og til ti, før jeg plutselig mister kontakten med serveren (kan da heller ikke komme inn på de delte diskene via utforsker)
jeg tror problemet er firewall'n i routeren, jeg har kopiert deler av loggen, kan noen her se hva problemet er? (pc'n jeg sitter på er en bedriftspc med domene)
May  1 21:24:35 kernel: vlan1: received packet with  own address as source address
May  1 22:06:20 dnsmasq-dhcp[315]: Ignoring domain xtel.local for DHCP host name XTLT0360
May  1 22:24:31 kernel: vlan1: received packet with  own address as source address
May  1 23:24:27 kernel: vlan1: received packet with  own address as source address
May  2 00:24:23 kernel: vlan1: received packet with  own address as source address
May  2 01:24:23 kernel: vlan1: received packet with  own address as source address
May  2 03:24:23 kernel: vlan1: received packet with  own address as source address
May  2 04:24:21 kernel: vlan1: received packet with  own address as source address
May  2 04:24:22 kernel: vlan1: received packet with  own address as source address
May  2 05:24:19 kernel: vlan1: received packet with  own address as source address
May  2 05:24:20 kernel: vlan1: received packet with  own address as source address
May  2 06:19:46 kernel: wlc_dump_aggfifo:
May  2 06:19:46 kernel: framerdy 0x10 bmccmd 4 framecnt 1
May  2 06:19:46 kernel: AQM agg params 0xfc0 maxlen hi/lo 0x0 0xffff minlen 0x0 adjlen 0x8
May  2 06:19:46 kernel: AQM agg results 0x8000 len hi/lo: 0x0 0x0 BAbitmap(0-3) 0 0 0 0
May  2 06:24:18 kernel: vlan1: received packet with  own address as source address
May  2 07:24:17 kernel: vlan1: received packet with  own address as source address
May  2 07:37:21 dnsmasq-dhcp[315]: Ignoring domain xtel.local for DHCP host name XTLT0360
May  2 07:37:25 dnsmasq-dhcp[315]: Ignoring domain xtel.local for DHCP host name XTLT0360
May  2 07:37:42 dnsmasq-dhcp[315]: Ignoring domain xtel.local for DHCP host name XTLT0360
May  2 07:37:46 dnsmasq-dhcp[315]: Ignoring domain xtel.local for DHCP host name XTLT0360
May  2 16:32:00 kernel: eth2: received packet with  own address as source address
May  2 16:32:00 dnsmasq-dhcp[315]: Ignoring domain xtel.local for DHCP host name XTLT0360
May  2 19:36:17 dnsmasq-dhcp[315]: Ignoring domain xtel.local for DHCP host name XTLT0360
May  3 00:21:52 miniupnpd[464]: Expired NAT-PMP mapping port 4442 UDP removed
May  3 00:21:52 miniupnpd[464]: Expired NAT-PMP mapping port 4442 TCP removed
May  3 07:36:17 dnsmasq-dhcp[315]: Ignoring domain xtel.local for DHCP host name XTLT0360
May  3 18:37:29 dnsmasq-dhcp[315]: Ignoring domain xtel.local for DHCP host name XTLT0360
May  4 01:43:41 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
May  4 01:43:41 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
May  4 01:43:41 kernel: HTB: quantum of class 10002 is big. Consider r2q change.
May  4 01:43:41 kernel: HTB: quantum of class 10060 is big. Consider r2q change.
May  4 01:43:41 kernel: HTB: quantum of class 10010 is big. Consider r2q change.
May  4 01:43:41 rc_service: udhcpc 2491:notify_rc stop_upnp
May  4 01:43:41 miniupnpd[464]: received signal 15, good-bye
May  4 01:43:41 rc_service: udhcpc 2491:notify_rc start_upnp
May  4 01:43:42 ddns: clear ddns cache file for server/hostname change
May  4 01:43:42 ddns update: ez-ipupdate: starting...
May  4 01:43:42 miniupnpd[2549]: HTTP listening on port 37483
May  4 01:43:42 miniupnpd[2549]: Listening for NAT-PMP traffic on port 5351
May  4 01:43:42 ddns update: connected to dynupdate.no-ip.com (8.23.224.120) on port 80.
May  4 01:43:42 ddns update: request successful
May  4 01:43:42 ddns update: asusddns_update: 0
May  4 01:43:42 ddns: ddns update ok
May  4 01:43:42 dhcp client: bound 85.166.254.6 via 85.166.252.1 during 3600 seconds.
May  4 05:50:20 dnsmasq-dhcp[315]: Ignoring domain xtel.local for DHCP host name XTLT0360
May  4 16:54:48 dnsmasq-dhcp[315]: Ignoring domain xtel.local for DHCP host name XTLT0360
May  5 00:01:06 miniupnpd[2549]: Expired NAT-PMP mapping port 4442 UDP removed
May  5 00:01:06 miniupnpd[2549]: Expired NAT-PMP mapping port 4442 TCP removed
May  5 03:50:38 dnsmasq-dhcp[315]: Ignoring domain xtel.local for DHCP host name XTLT0360
May  5 08:35:42 dnsmasq-dhcp[315]: Ignoring domain xtel.local for DHCP host name XTLT0360
May  5 18:06:16 kernel: eth2: received packet with  own address as source address
May  5 18:06:16 dnsmasq-dhcp[315]: Ignoring domain xtel.local for DHCP host name XTLT0360
May  6 01:06:48 miniupnpd[2549]: Expired NAT-PMP mapping port 4442 UDP removed
May  6 01:06:48 miniupnpd[2549]: Expired NAT-PMP mapping port 4442 TCP removed
May  6 06:06:17 dnsmasq-dhcp[315]: Ignoring domain xtel.local for DHCP host name XTLT0360
May  6 08:07:18 dnsmasq-dhcp[315]: Ignoring domain xtel.local for DHCP host name XTLT0360
May  6 18:10:46 kernel: eth2: received packet with  own address as source address
May  6 18:10:46 dnsmasq-dhcp[315]: Ignoring domain xtel.local for DHCP host name XTLT0360
May  7 00:23:21 miniupnpd[2549]: Expired NAT-PMP mapping port 4442 UDP removed
May  7 00:23:21 miniupnpd[2549]: Expired NAT-PMP mapping port 4442 TCP removed
May  7 06:10:46 dnsmasq-dhcp[315]: Ignoring domain xtel.local for DHCP host name XTLT0360
May  7 15:22:53 miniupnpd[2549]: HTTP Connection from 10.0.0.49 closed unexpectedly
May  7 16:11:04 miniupnpd[2549]: HTTP Connection from 10.0.0.49 closed unexpectedly
May  7 17:03:26 kernel: eth2: received packet with  own address as source address
May  7 17:03:26 dnsmasq-dhcp[315]: Ignoring domain xtel.local for DHCP host name XTLT0360
Endret av xFrEaKx
