jos67 Skrevet 29. april 2014 Rapporter Del Skrevet 29. april 2014 (endret) Har CD internett aksess, og har nylig kjøpt meg en ny router, Asus RT-AC68U. Problemet er at netverket "henger seg" 3-4 ganger ila en time. Da mister alle devicer nettverket (både kablede og trådløse) for kanskje 1 min... Og etter ett minutt så kommer nettverket tilbake. Oppsettet jeg benyttet for Asus boksen var enkelt.Tok ut min gamle router, koblet til den nye Asus routeren (kabel fra thompson inn i WAN tilkoblingen på Asus'en). Asus boksen er satt opp i "Wireless router mode". --> Se bilde for enkel tegning av nettet Selve modemet fra Canal Digital har nett hele tiden, så virker som at problemet ligger i config'en til Asus routeren. Loggfil på/rett etter et slikt "downtime" tidspunkt Jan 1 01:00:12 syslog: module proxyarp not found in modules.dep Jan 1 01:00:13 stop_nat_rules: apply the redirect_rules! Jan 1 01:00:13 WAN Connection: ISP's DHCP did not function properly. Jan 1 01:00:13 RT-AC68U: start httpd Jan 1 01:00:14 syslog: Generating SSL certificate... Jan 1 01:00:19 disk monitor: be idle Jan 1 01:00:19 miniupnpd[550]: HTTP listening on port 44867 Jan 1 01:00:19 miniupnpd[550]: Listening for NAT-PMP traffic on port 5351 Jan 1 01:00:20 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)! Jan 1 01:00:22 kernel: nf_conntrack_rtsp v0.6.21 loading Jan 1 01:00:22 kernel: nf_nat_rtsp v0.6.21 loading Jan 1 01:00:22 rc_service: udhcpc 567:notify_rc stop_upnp Jan 1 01:00:22 rc_service: udhcpc 567:notify_rc start_upnp Jan 1 01:00:22 miniupnpd[550]: received signal 15, good-bye Jan 1 01:00:22 rc_service: waitting "stop_upnp" via udhcpc ... Jan 1 01:00:23 WAN Connection: WAN was restored. Jan 1 01:00:23 rc_service: udhcpc 567:notify_rc stop_ntpc Jan 1 01:00:23 rc_service: udhcpc 567:notify_rc start_ntpc Jan 1 01:00:23 rc_service: waitting "stop_ntpc" via udhcpc ... Jan 1 01:00:23 miniupnpd[621]: HTTP listening on port 41986 Jan 1 01:00:23 miniupnpd[621]: Listening for NAT-PMP traffic on port 5351 Jan 1 01:00:24 miniupnpd[621]: send(res_buf): Connection reset by peer Apr 29 17:13:26 dhcp client: bound 95.34.110.170 via 95.34.110.1 during 18000 seconds. Apr 29 17:13:26 rc_service: ntp 625:notify_rc restart_upnp Apr 29 17:13:26 rc_service: ntp 625:notify_rc restart_diskmon Apr 29 17:13:26 rc_service: waitting "restart_upnp" via ntp ... Apr 29 17:13:26 miniupnpd[621]: received signal 15, good-bye Apr 29 17:13:26 miniupnpd[640]: HTTP listening on port 56183 Apr 29 17:13:26 miniupnpd[640]: Listening for NAT-PMP traffic on port 5351 Apr 29 17:13:28 disk monitor: be idle Hvis jeg er inlogget på ASUS'en når den "booter/stopper", så får jeg følgende feilmelding; Innstillingene er blitt oppdatert. Websiden oppdateres. IP-adressen eller portnummeret er blitt endret. Du kobles nå fra RT-AC68U. For å oppnå tilgang til RT-AC68U-innstillingene må du koble til det trådløse nettverket igjen og bruke den oppdaterte IP-adressen og portnummeret. Noen som har tips på hva jeg kan gjøre for å fikse opp i dette? Endret 29. april 2014 av jos67 Lenke til kommentar
Mr D Skrevet 29. april 2014 Rapporter Del Skrevet 29. april 2014 (endret) Har du sjekket hvilke FW den har og oppdatert hvis det finnes nyere? http://www.asus.com/no/Networking/RTAC68U/HelpDesk_Download/ Endret 29. april 2014 av Mr D 1 Lenke til kommentar
jos67 Skrevet 29. april 2014 Forfatter Rapporter Del Skrevet 29. april 2014 Hei Har 3.0.0.4.374.5517, og når jeg sjekker fra routeren påstår den at jeg har siste versjon. Men ser fra linken din at det eksisterern andre versjoner med "høyere versjonsnummer" Prøver ut og ser hva som skjer. Lenke til kommentar
Mr D Skrevet 29. april 2014 Rapporter Del Skrevet 29. april 2014 Den automatiske oppdateringen funker dårlig på mine enheter, så den har jeg sluttet å bruke. Den FW-versjonen din ruter har, er borte fra lista så det er nok veldig lurt å oppgradere til nyere. 1 Lenke til kommentar
jos67 Skrevet 29. april 2014 Forfatter Rapporter Del Skrevet 29. april 2014 (endret) Har oppdatert og så langt ser det bra ut :-) 40+ minutter uten nedetid er en klar forbedring! Endret 29. april 2014 av jos67 Lenke til kommentar
Mr D Skrevet 29. april 2014 Rapporter Del Skrevet 29. april 2014 Så bra. Den boksen skal vel ha (tilnærmet) 0 nedetid. Lenke til kommentar
JOSwasHere Skrevet 1. mai 2014 Rapporter Del Skrevet 1. mai 2014 (endret) Gremdeles funker alt stabilt, så denne kan settes som løst. -- Hmmmm ser jeg har en annen bruker på telefon vs PC'en min... Endret 1. mai 2014 av JOSwasHere Lenke til kommentar
