laptop til BF4
kan hende det er det, det blir når skatte penger kommer :)
dumt spm :p er det vanskelig og koble dette sammen når pcen evt kommer? siden den kommer i "deler" er det ting som kan gjøres feil liksom?
er som regel vant til laptoper den siste tiden og den er sammenkobla vis jeg kan kalle det det?
Vil forsåvidt fungere, dog ikke perfekt match :p
Finally, that low heatsink clearance did rear its ugly head when I went to close up. Our Cooler Master Hyper 212 Evo is by no means an extravagant cooler or even one of the largest ones on the market, but its 159mm height caused the tops of the heatpipes to press against the side panel, bowing it outward a little. I was still able to secure the panel, but end users are going to want to look into a smaller tower-style heatsink like the Xigmatek Loki to really maximize the Core 1000.
