Zic0 Skrevet 12. oktober 2003 Rapporter Del Skrevet 12. oktober 2003 Vel jeg skal bytte port til min FTP server, så jeg tenkte at jeg skal lete i vsftp.conf fila, men finner ikke noe om porter: # Example config file /etc/vsftpd.conf # # The default compiled in settings are very paranoid. This sample file # loosens things up a bit, to make the ftp daemon more usable. # # Allow anonymous FTP? anonymous_enable=YES # # Uncomment this to allow local users to log in. local_enable=YES # # Uncomment this to enable any form of FTP write command. write_enable=YES # # Default umask for local users is 077. You may wish to change this to 022, # if your users expect that (022 is used by most other ftpd's) local_umask=022 # # Uncomment this to allow the anonymous FTP user to upload files. This only # has an effect if the above global write enable is activated. Also, you will # obviously need to create a directory writable by the FTP user. #anon_upload_enable=YES # # Uncomment this if you want the anonymous FTP user to be able to create # new directories. #anon_mkdir_write_enable=YES # # Activate directory messages - messages given to remote users when they # go into a certain directory. dirmessage_enable=YES # # Activate logging of uploads/downloads. xferlog_enable=YES # # Make sure PORT transfer connections originate from port 20 (ftp-data). connect_from_port_20=YES # # If you want, you can arrange for uploaded anonymous files to be owned by # a different user. Note! Using "root" for uploaded files is not # recommended! #chown_uploads=YES #chown_username=whoever # # You may override where the log file goes if you like. The default is shown # below. #xferlog_file=/var/log/vsftpd.log # # If you want, you can have your log file in standard ftpd xferlog format xferlog_std_format=YES # # You may change the default value for timing out an idle session. #idle_session_timeout=600 # # You may change the default value for timing out a data connection. #data_connection_timeout=120 # # It is recommended that you define on your system a unique user which the # ftp server can use as a totally isolated and unprivileged user. #nopriv_user=ftpsecure # # Enable this and the server will recognise asynchronous ABOR requests. Not # recommended for security (the code is non-trivial). Not enabling it, # however, may confuse older FTP clients. #async_abor_enable=YES # # By default the server will pretend to allow ASCII mode but in fact ignore # the request. Turn on the below options to have the server actually do ASCII # mangling on files when in ASCII mode. # Beware that turning on ascii_download_enable enables malicious remote parties # to consume your I/O resources, by issuing the command "SIZE /big/file" in # ASCII mode. # These ASCII options are split into upload and download because you may wish # to enable ASCII uploads (to prevent uploaded scripts etc. from breaking), # without the DoS risk of SIZE and ASCII downloads. ASCII mangling should be # on the client anyway.. #ascii_upload_enable=YES #ascii_download_enable=YES # # You may fully customise the login banner string: #ftpd_banner=Welcome to blah FTP service. # # You may specify a file of disallowed anonymous e-mail addresses. Apparently # useful for combatting certain DoS attacks. #deny_email_enable=YES # (default follows) #banned_email_file=/etc/vsftpd.banned_emails # # You may specify an explicit list of local users to chroot() to their home # directory. If chroot_local_user is YES, then this list becomes a list of # users to NOT chroot(). #chroot_list_enable=YES # (default follows) #chroot_list_file=/etc/vsftpd.chroot_list # # You may activate the "-R" option to the builtin ls. This is disabled by # default to avoid remote users being able to cause excessive I/O on large # sites. However, some broken FTP clients such as "ncftp" and "mirror" assume # the presence of the "-R" option, so there is a strong case for enabling it. #ls_recurse_enable=YES pam_service_name=vsftpd userlist_enable=YES #enable for standalone mode listen=YES tcp_wrappers=YES Sånn ser min conf fil ut. Vet noen hva jeg skal endre eller er jeg på feil plass? takker for alle svar Lenke til kommentar
P@rm@nn Skrevet 12. oktober 2003 Rapporter Del Skrevet 12. oktober 2003 starter du vsftpd fra en superserver som initd eller xinitd ? I så fall skal det forandres i den superserveren. I Xinitd vil du sette inn f.eks port = 3111 Om du kjører vsftpd i "standalone mode" så bruker du listen_port i vsftpd.conf som f.eks: listen_port=3111 Lenke til kommentar
Zic0 Skrevet 12. oktober 2003 Forfatter Rapporter Del Skrevet 12. oktober 2003 Om du kjører vsftpd i "standalone mode" så bruker du listen_port i vsftpd.conf som f.eks: listen_port=3111 Hvor skal jeg sette det inn? Lenke til kommentar
P@rm@nn Skrevet 12. oktober 2003 Rapporter Del Skrevet 12. oktober 2003 Om du kjører vsftpd i "standalone mode" så bruker du listen_port i vsftpd.conf som f.eks: listen_port=3111 Hvor skal jeg sette det inn? Du skriver rett å slett listen_port=3111 nederst i din vsftpd.conf . Husk at det må stå som et sammenhengende ord, altså ingen mellomrom mellom likhetstegnet og f.eks portnummeret. Lenke til kommentar
