[Løst] Finner ikke disk i det hele tatt i Debian
Hei. Jeg prøver å legge til en harddisk i Debian, men finner den ikke i det hele tatt. fdisk -l | grep Disk eller fdisk -l finner bare sda og sdb, men ikke sdc - altså disken jeg ser etter.
lspci -vnn viser:
root@xxxxx-xxx:~# lspci -vnn
00:00.0 RAM memory [0500]: NVIDIA Corporation MCP61 Host Bridge [10de:03e2] (rev a1)
Subsystem: ASUSTeK Computer Inc. M4N68T series motherboard [1043:83a4]
Flags: bus master, 66MHz, fast devsel, latency 0
Capabilities: [44] HyperTransport: Slave or Primary Interface
Capabilities: [dc] HyperTransport: MSI Mapping Enable+ Fixed-
00:01.0 ISA bridge [0601]: NVIDIA Corporation MCP61 LPC Bridge [10de:03e1] (rev a2)
I/O ports at 0900
00:01.1 SMBus [0c05]: NVIDIA Corporation MCP61 SMBus [10de:03eb] (rev a2)
Flags: 66MHz, fast devsel, IRQ 10
I/O ports at 0e00
I/O ports at 0600
I/O ports at 0700
Capabilities: [44] Power Management version 2
Kernel driver in use: nForce2_smbus
00:01.2 RAM memory [0500]: NVIDIA Corporation MCP61 Memory Controller [10de:03f5] (rev a2)
00:02.0 USB controller [0c03]: NVIDIA Corporation MCP61 USB 1.1 Controller [10de:03f1] (rev a3) (prog-if 10 [OHCI])
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 23
Memory at dddfb000 (32-bit, non-prefetchable)
Kernel driver in use: ohci_hcd
00:02.1 USB controller [0c03]: NVIDIA Corporation MCP61 USB 2.0 Controller [10de:03f2] (rev a3) (prog-if 20 [EHCI])
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 22
Memory at dddfac00 (32-bit, non-prefetchable)
Capabilities: [44] Debug port: BAR=1 offset=0098
Capabilities: [80] Power Management version 2
Kernel driver in use: ehci_hcd
00:04.0 PCI bridge [0604]: NVIDIA Corporation MCP61 PCI bridge [10de:03f3] (rev a1) (prog-if 01 [subtractive decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=64
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: dde00000-ddefffff
Capabilities: [b8] Subsystem: ASUSTeK Computer Inc. Device [1043:83a4]
Capabilities: [8c] HyperTransport: MSI Mapping Enable- Fixed-
00:05.0 Audio device [0403]: NVIDIA Corporation MCP61 High Definition Audio [10de:03f0] (rev a2)
Subsystem: ASUSTeK Computer Inc. Device [1043:8290]
Memory at dddf4000 (32-bit, non-prefetchable)
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [6c] HyperTransport: MSI Mapping Enable- Fixed+
Kernel driver in use: snd_hda_intel
00:06.0 IDE interface [0101]: NVIDIA Corporation MCP61 IDE [10de:03ec] (rev a2) (prog-if 8a [Master SecP PriP])
[virtual] Memory at 000001f0 (32-bit, non-prefetchable)
[virtual] Memory at 000003f0 (type 3, non-prefetchable)
[virtual] Memory at 00000170 (32-bit, non-prefetchable)
[virtual] Memory at 00000370 (type 3, non-prefetchable)
I/O ports at ffa0
Kernel driver in use: pata_amd
00:07.0 Bridge [0680]: NVIDIA Corporation MCP61 Ethernet [10de:03ef] (rev a2)
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 43
Memory at dddf9000 (32-bit, non-prefetchable)
I/O ports at c480
Capabilities: [50] MSI: Enable+ Count=1/8 Maskable+ 64bit+
Kernel driver in use: forcedeth
00:08.0 IDE interface [0101]: NVIDIA Corporation MCP61 SATA Controller [10de:03f6] (rev a2) (prog-if 85 [Master SecO PriO])
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 20
I/O ports at c400
I/O ports at c080
I/O ports at c000
I/O ports at bc00
I/O ports at b880
Memory at dddf8000 (32-bit, non-prefetchable)
Capabilities: [b0] MSI: Enable- Count=1/4 Maskable- 64bit+
Capabilities: [cc] HyperTransport: MSI Mapping Enable- Fixed+
Kernel driver in use: sata_nv
00:08.1 IDE interface [0101]: NVIDIA Corporation MCP61 SATA Controller [10de:03f6] (rev a2) (prog-if 85 [Master SecO PriO])
I/O ports at b800
I/O ports at b480
I/O ports at b400
I/O ports at b080
I/O ports at b000
Memory at dddef000 (32-bit, non-prefetchable)
00:09.0 PCI bridge [0604]: NVIDIA Corporation MCP61 PCI Express bridge [10de:03e8] (rev a2) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: ddf00000-dfffffff
Prefetchable memory behind bridge: 00000000d0000000-00000000dbffffff
Capabilities: [40] Subsystem: NVIDIA Corporation Device [10de:0000]
Capabilities: [48] Power Management version 2
Capabilities: [50] MSI: Enable+ Count=1/2 Maskable- 64bit+
Capabilities: [60] HyperTransport: MSI Mapping Enable- Fixed-
Capabilities: [80] Express Root Port (Slot+), MSI 00
Capabilities: [100] Virtual Channel
Kernel driver in use: pcieport
00:0b.0 PCI bridge [0604]: NVIDIA Corporation MCP61 PCI Express bridge [10de:03e9] (rev a2) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
00:0c.0 PCI bridge [0604]: NVIDIA Corporation MCP61 PCI Express bridge [10de:03e9] (rev a2) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
00:18.0 Host bridge [0600]: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration [1022:1100]
Flags: fast devsel
Capabilities: [80] HyperTransport: Host or Secondary Interface
00:18.1 Host bridge [0600]: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map [1022:1101]
Flags: fast devsel
00:18.2 Host bridge [0600]: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller [1022:1102]
Flags: fast devsel
00:18.3 Host bridge [0600]: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control [1022:1103]
Flags: fast devsel
Capabilities: [f0] Secure device <?>
Kernel driver in use: k8temp
01:07.0 Ethernet controller [0200]: D-Link System Inc DGE-528T Gigabit Ethernet Adapter [1186:4300] (rev 10)
Subsystem: D-Link System Inc DGE-528T Gigabit Ethernet Adapter [1186:4300]
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 19
I/O ports at d800
Memory at ddeffc00 (32-bit, non-prefetchable)
Expansion ROM at ddec0000 [disabled]
Capabilities: [dc] Power Management version 2
Kernel driver in use: r8169
02:00.0 VGA compatible controller [0300]: NVIDIA Corporation GF114 [GeForce GTX 560 Ti] [10de:1200] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Micro-Star International Co., Ltd. Device [1462:2382]
Flags: bus master, fast devsel, latency 0, IRQ 18
Memory at de000000 (32-bit, non-prefetchable)
Memory at d0000000 (64-bit, prefetchable)
Memory at d8000000 (64-bit, prefetchable)
I/O ports at ec00
Expansion ROM at ddf80000 [disabled]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [128] Power Budgeting <?>
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Kernel driver in use: nouveau
02:00.1 Audio device [0403]: NVIDIA Corporation GF114 HDMI Audio Controller [10de:0e0c] (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at ddf7c000 (32-bit, non-prefetchable)
dmesg viser:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.2.0-4-amd64 ([email protected]) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP Debian 3.2.54-2
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-amd64 root=UUID=1a8f3384-2868-4c2d-a5e3-2dfb34b992e5 ro quiet
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009b400 (usable)
[ 0.000000] BIOS-e820: 000000000009b400 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e2000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007ffb0000 (usable)
[ 0.000000] BIOS-e820: 000000007ffb0000 - 000000007ffbe000 (ACPI data)
[ 0.000000] BIOS-e820: 000000007ffbe000 - 000000007ffe0000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007ffe0000 - 000000007ffee000 (reserved)
[ 0.000000] BIOS-e820: 000000007fff0000 - 0000000080000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fef00000 (reserved)
[ 0.000000] BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: System manufacturer System Product Name/M2N68-AM Plus, BIOS 0701 04/08/2009
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] No AGP bridge found
[ 0.000000] last_pfn = 0x7ffb0 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0000000000 mask FF80000000 write-back
[ 0.000000] 1 disabled
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [ffff8800000ff780] ff780
[ 0.000000] initial memory mapped : 0 - 20000000
[ 0.000000] Base memory trampoline at [ffff880000096000] 96000 size 20480
[ 0.000000] init_memory_mapping: 0000000000000000-000000007ffb0000
[ 0.000000] 0000000000 - 007fe00000 page 2M
[ 0.000000] 007fe00000 - 007ffb0000 page 4k
[ 0.000000] kernel direct mapping tables up to 7ffb0000 @ 1fffc000-20000000
[ 0.000000] RAMDISK: 36bda000 - 375e5000
[ 0.000000] ACPI: RSDP 00000000000fb730 00014 (v00 ACPIAM)
[ 0.000000] ACPI: RSDT 000000007ffb0000 00038 (v01 040809 RSDT2045 20090408 MSFT 00000097)
[ 0.000000] ACPI: FACP 000000007ffb0200 00084 (v02 040809 FACP2045 20090408 MSFT 00000097)
[ 0.000000] ACPI: DSDT 000000007ffb0450 06A1F (v01 A1270 A1270000 00000000 INTL 20060113)
[ 0.000000] ACPI: FACS 000000007ffbe000 00040
[ 0.000000] ACPI: APIC 000000007ffb0390 00080 (v01 040809 APIC2045 20090408 MSFT 00000097)
[ 0.000000] ACPI: MCFG 000000007ffb0410 0003C (v01 040809 OEMMCFG 20090408 MSFT 00000097)
[ 0.000000] ACPI: OEMB 000000007ffbe040 00071 (v01 040809 OEMB2045 20090408 MSFT 00000097)
[ 0.000000] ACPI: HPET 000000007ffb6e70 00038 (v01 040809 OEMHPET0 20090408 MSFT 00000097)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] Scanning NUMA topology in Northbridge 24
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at 0000000000000000-000000007ffb0000
[ 0.000000] Initmem setup node 0 0000000000000000-000000007ffb0000
[ 0.000000] NODE_DATA [000000007ffab000 - 000000007ffaffff]
[ 0.000000] [ffffea0000000000-ffffea0001bfffff] PMD -> [ffff88007d600000-ffff88007f1fffff] on node 0
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] DMA32 0x00001000 -> 0x00100000
[ 0.000000] Normal empty
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009b
[ 0.000000] 0: 0x00000100 -> 0x0007ffb0
[ 0.000000] On node 0 totalpages: 524091
[ 0.000000] DMA zone: 56 pages used for memmap
[ 0.000000] DMA zone: 5 pages reserved
[ 0.000000] DMA zone: 3918 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 7111 pages used for memmap
[ 0.000000] DMA32 zone: 513001 pages, LIFO batch:31
[ 0.000000] Detected use of extended apic ids on hypertransport bus
[ 0.000000] ACPI: PM-Timer IO Port: 0x508
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled)
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] ACPI: IRQ14 used by override.
[ 0.000000] ACPI: IRQ15 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x10de8201 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009b000 - 000000000009c000
[ 0.000000] PM: Registered nosave memory: 000000000009c000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e2000
[ 0.000000] PM: Registered nosave memory: 00000000000e2000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:7ec00000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 28 pages/cpu @ffff88007fc00000 s82944 r8192 d23552 u524288
[ 0.000000] pcpu-alloc: s82944 r8192 d23552 u524288 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 516919
[ 0.000000] Policy zone: DMA32
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-amd64 root=UUID=1a8f3384-2868-4c2d-a5e3-2dfb34b992e5 ro quiet
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Checking aperture...
[ 0.000000] Node 0: aperture @ a6b2000000 size 32 MB
[ 0.000000] Aperture beyond 4GB. Ignoring.
[ 0.000000] Memory: 2048436k/2096832k available (3429k kernel code, 468k absent, 47928k reserved, 3309k data, 576k init)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:33024 nr_irqs:712 16
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2209.980 MHz processor.
[ 0.000000] Marking TSC unstable due to TSCs unsynchronized
[ 0.004006] Calibrating delay loop (skipped), value calculated using timer frequency.. 4419.96 BogoMIPS (lpj=8839920)
[ 0.004012] pid_max: default: 32768 minimum: 301
[ 0.004071] Security Framework initialized
[ 0.004077] AppArmor: AppArmor disabled by boot time parameter
[ 0.004259] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.005632] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.006380] Mount-cache hash table entries: 256
[ 0.006549] Initializing cgroup subsys cpuacct
[ 0.006555] Initializing cgroup subsys memory
[ 0.006572] Initializing cgroup subsys devices
[ 0.006577] Initializing cgroup subsys freezer
[ 0.006579] Initializing cgroup subsys net_cls
[ 0.006582] Initializing cgroup subsys blkio
[ 0.006593] Initializing cgroup subsys perf_event
[ 0.006630] tseg: 0000000000
[ 0.006645] CPU: Physical Processor ID: 0
[ 0.006647] CPU: Processor Core ID: 0
[ 0.006650] mce: CPU supports 5 MCE banks
[ 0.008016] using AMD E400 aware idle routine
[ 0.008335] ACPI: Core revision 20110623
[ 0.012609] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.052613] CPU0: AMD Athlon 64 X2 Dual Core Processor 4200+ stepping 02
[ 0.056003] Performance Events: AMD PMU driver.
[ 0.056003] ... version: 0
[ 0.056003] ... bit width: 48
[ 0.056003] ... generic registers: 4
[ 0.056003] ... value mask: 0000ffffffffffff
[ 0.056003] ... max period: 00007fffffffffff
[ 0.056003] ... fixed-purpose events: 0
[ 0.056003] ... event mask: 000000000000000f
[ 0.056003] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.056003] Booting Node 0, Processors #1
[ 0.056003] smpboot cpu 1: start_ip = 96000
[ 0.140069] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.140095] Brought up 2 CPUs
[ 0.140097] Total of 2 processors activated (8840.01 BogoMIPS).
[ 0.140655] devtmpfs: initialized
[ 0.144302] PM: Registering ACPI NVS region at 7ffbe000 (139264 bytes)
[ 0.144302] print_constraints: dummy:
[ 0.144302] NET: Registered protocol family 16
[ 0.144420] node 0 link 0: io port [1000, ffffff]
[ 0.144424] TOM: 0000000080000000 aka 2048M
[ 0.144427] node 0 link 0: mmio [e0000000, efffffff]
[ 0.144430] node 0 link 0: mmio [a0000, bffff]
[ 0.144433] node 0 link 0: mmio [80000000, fe0bffff]
[ 0.144436] bus: [00, 07] on node 0 link 0
[ 0.144440] bus: 00 index 0 [io 0x0000-0xffff]
[ 0.144443] bus: 00 index 1 [mem 0x80000000-0xfcffffffff]
[ 0.144445] bus: 00 index 2 [mem 0x000a0000-0x000bffff]
[ 0.144457] ACPI: bus type pci registered
[ 0.144540] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.144544] PCI: not using MMCONFIG
[ 0.144546] PCI: Using configuration type 1 for base access
[ 0.144698] mtrr: your CPUs had inconsistent variable MTRR settings
[ 0.144700] mtrr: probably your BIOS does not setup all CPUs.
[ 0.144702] mtrr: corrected configuration.
[ 0.145393] bio: create slab <bio-0> at 0
[ 0.145393] ACPI: Added _OSI(Module Device)
[ 0.145393] ACPI: Added _OSI(Processor Device)
[ 0.145393] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.145393] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.145393] ACPI: EC: Look up EC in DSDT
[ 0.148501] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.152320] ACPI: Interpreter enabled
[ 0.152327] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.152354] ACPI: Using IOAPIC for interrupt routing
[ 0.152379] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.154150] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 0.179843] ACPI: No dock devices found.
[ 0.179846] HEST: Table not found.
[ 0.179852] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.180072] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.180288] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7]
[ 0.180291] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff]
[ 0.180294] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.180297] pci_root PNP0A03:00: host bridge window [mem 0x000d0000-0x000dffff]
[ 0.180300] pci_root PNP0A03:00: host bridge window [mem 0x80000000-0xdfffffff]
[ 0.180303] pci_root PNP0A03:00: host bridge window [mem 0xf0000000-0xfebfffff]
[ 0.180332] pci 0000:00:00.0: [10de:03e2] type 0 class 0x000500
[ 0.180507] pci 0000:00:01.0: [10de:03e1] type 0 class 0x000601
[ 0.180515] pci 0000:00:01.0: reg 10: [io 0x0900-0x09ff]
[ 0.180553] pci 0000:00:01.1: [10de:03eb] type 0 class 0x000c05
[ 0.180564] pci 0000:00:01.1: reg 10: [io 0x0e00-0x0e3f]
[ 0.180579] pci 0000:00:01.1: reg 20: [io 0x0600-0x063f]
[ 0.180585] pci 0000:00:01.1: reg 24: [io 0x0700-0x073f]
[ 0.180613] pci 0000:00:01.1: PME# supported from D3hot D3cold
[ 0.180632] pci 0000:00:01.2: [10de:03f5] type 0 class 0x000500
[ 0.180676] pci 0000:00:02.0: [10de:03f1] type 0 class 0x000c03
[ 0.180685] pci 0000:00:02.0: reg 10: [mem 0xdddfb000-0xdddfbfff]
[ 0.180718] pci 0000:00:02.0: supports D1 D2
[ 0.180721] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.180737] pci 0000:00:02.1: [10de:03f2] type 0 class 0x000c03
[ 0.180747] pci 0000:00:02.1: reg 10: [mem 0xdddfac00-0xdddfacff]
[ 0.180787] pci 0000:00:02.1: supports D1 D2
[ 0.180790] pci 0000:00:02.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.180813] pci 0000:00:04.0: [10de:03f3] type 1 class 0x000604
[ 0.180856] pci 0000:00:05.0: [10de:03f0] type 0 class 0x000403
[ 0.180867] pci 0000:00:05.0: reg 10: [mem 0xdddf4000-0xdddf7fff]
[ 0.180907] pci 0000:00:05.0: PME# supported from D3hot D3cold
[ 0.180930] pci 0000:00:06.0: [10de:03ec] type 0 class 0x000101
[ 0.180951] pci 0000:00:06.0: reg 20: [io 0xffa0-0xffaf]
[ 0.180986] pci 0000:00:07.0: [10de:03ef] type 0 class 0x000680
[ 0.180996] pci 0000:00:07.0: reg 10: [mem 0xdddf9000-0xdddf9fff]
[ 0.181001] pci 0000:00:07.0: reg 14: [io 0xc480-0xc487]
[ 0.181034] pci 0000:00:07.0: supports D1 D2
[ 0.181037] pci 0000:00:07.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.181055] pci 0000:00:08.0: [10de:03f6] type 0 class 0x000101
[ 0.181064] pci 0000:00:08.0: reg 10: [io 0xc400-0xc407]
[ 0.181069] pci 0000:00:08.0: reg 14: [io 0xc080-0xc083]
[ 0.181074] pci 0000:00:08.0: reg 18: [io 0xc000-0xc007]
[ 0.181078] pci 0000:00:08.0: reg 1c: [io 0xbc00-0xbc03]
[ 0.181083] pci 0000:00:08.0: reg 20: [io 0xb880-0xb88f]
[ 0.181088] pci 0000:00:08.0: reg 24: [mem 0xdddf8000-0xdddf8fff]
[ 0.181119] pci 0000:00:08.1: [10de:03f6] type 0 class 0x000101
[ 0.181127] pci 0000:00:08.1: reg 10: [io 0xb800-0xb807]
[ 0.181132] pci 0000:00:08.1: reg 14: [io 0xb480-0xb483]
[ 0.181137] pci 0000:00:08.1: reg 18: [io 0xb400-0xb407]
[ 0.181142] pci 0000:00:08.1: reg 1c: [io 0xb080-0xb083]
[ 0.181146] pci 0000:00:08.1: reg 20: [io 0xb000-0xb00f]
[ 0.181151] pci 0000:00:08.1: reg 24: [mem 0xdddef000-0xdddeffff]
[ 0.181188] pci 0000:00:09.0: [10de:03e8] type 1 class 0x000604
[ 0.181215] pci 0000:00:09.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.181233] pci 0000:00:0b.0: [10de:03e9] type 1 class 0x000604
[ 0.181259] pci 0000:00:0b.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.181276] pci 0000:00:0c.0: [10de:03e9] type 1 class 0x000604
[ 0.181302] pci 0000:00:0c.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.181325] pci 0000:00:18.0: [1022:1100] type 0 class 0x000600
[ 0.181347] pci 0000:00:18.1: [1022:1101] type 0 class 0x000600
[ 0.181365] pci 0000:00:18.2: [1022:1102] type 0 class 0x000600
[ 0.181384] pci 0000:00:18.3: [1022:1103] type 0 class 0x000600
[ 0.181438] pci 0000:01:07.0: [1186:4300] type 0 class 0x000200
[ 0.181451] pci 0000:01:07.0: reg 10: [io 0xd800-0xd8ff]
[ 0.181459] pci 0000:01:07.0: reg 14: [mem 0xddeffc00-0xddeffcff]
[ 0.181489] pci 0000:01:07.0: reg 30: [mem 0xddec0000-0xddedffff pref]
[ 0.181509] pci 0000:01:07.0: supports D1 D2
[ 0.181512] pci 0000:01:07.0: PME# supported from D1 D2 D3hot D3cold
[ 0.181540] pci 0000:00:04.0: PCI bridge to [bus 01-01] (subtractive decode)
[ 0.181544] pci 0000:00:04.0: bridge window [io 0xd000-0xdfff]
[ 0.181548] pci 0000:00:04.0: bridge window [mem 0xdde00000-0xddefffff]
[ 0.181552] pci 0000:00:04.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.181555] pci 0000:00:04.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.181559] pci 0000:00:04.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.181562] pci 0000:00:04.0: bridge window [mem 0x000d0000-0x000dffff] (subtractive decode)
[ 0.181565] pci 0000:00:04.0: bridge window [mem 0x80000000-0xdfffffff] (subtractive decode)
[ 0.181569] pci 0000:00:04.0: bridge window [mem 0xf0000000-0xfebfffff] (subtractive decode)
[ 0.181602] pci 0000:02:00.0: [10de:1200] type 0 class 0x000300
[ 0.181610] pci 0000:02:00.0: reg 10: [mem 0xde000000-0xdfffffff]
[ 0.181619] pci 0000:02:00.0: reg 14: [mem 0xd0000000-0xd7ffffff 64bit pref]
[ 0.181628] pci 0000:02:00.0: reg 1c: [mem 0xd8000000-0xdbffffff 64bit pref]
[ 0.181635] pci 0000:02:00.0: reg 24: [io 0xec00-0xec7f]
[ 0.181642] pci 0000:02:00.0: reg 30: [mem 0xddf80000-0xddffffff pref]
[ 0.181689] pci 0000:02:00.1: [10de:0e0c] type 0 class 0x000403
[ 0.181698] pci 0000:02:00.1: reg 10: [mem 0xddf7c000-0xddf7ffff]
[ 0.188025] pci 0000:00:09.0: PCI bridge to [bus 02-02]
[ 0.188029] pci 0000:00:09.0: bridge window [io 0xe000-0xefff]
[ 0.188032] pci 0000:00:09.0: bridge window [mem 0xddf00000-0xdfffffff]
[ 0.188036] pci 0000:00:09.0: bridge window [mem 0xd0000000-0xdbffffff 64bit pref]
[ 0.188057] pci 0000:00:0b.0: PCI bridge to [bus 03-03]
[ 0.188080] pci 0000:00:0c.0: PCI bridge to [bus 04-04]
[ 0.188093] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.188267] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[ 0.188338] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR10._PRT]
[ 0.188380] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR11._PRT]
[ 0.188422] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR12._PRT]
[ 0.188568] pci0000:00: Requesting ACPI _OSC control (0x1d)
[ 0.188786] pci0000:00: ACPI _OSC request failed (AE_SUPPORT), returned control mask: 0x0c
[ 0.188789] ACPI _OSC control for PCIe not granted, disabling ASPM
[ 0.194672] ACPI: PCI Interrupt Link [LNKA] (IRQs 16 17 18 19) *0, disabled.
[ 0.194799] ACPI: PCI Interrupt Link [LNKB] (IRQs 16 17 18 19) *10
[ 0.194922] ACPI: PCI Interrupt Link [LNKC] (IRQs 16 17 18 19) *0, disabled.
[ 0.195046] ACPI: PCI Interrupt Link [LNKD] (IRQs 16 17 18 19) *0, disabled.
[ 0.195171] ACPI: PCI Interrupt Link [LNEA] (IRQs 16 17 18 19) *5
[ 0.195294] ACPI: PCI Interrupt Link [LNEB] (IRQs 16 17 18 19) *0, disabled.
[ 0.195417] ACPI: PCI Interrupt Link [LNEC] (IRQs 16 17 18 19) *0, disabled.
[ 0.195544] ACPI: PCI Interrupt Link [LNED] (IRQs 16 17 18 19) *11
[ 0.195670] ACPI: PCI Interrupt Link [LUB0] (IRQs 20 21 22 23) *5
[ 0.195796] ACPI: PCI Interrupt Link [LUB2] (IRQs 20 21 22 23) *11
[ 0.195921] ACPI: PCI Interrupt Link [LMAC] (IRQs 20 21 22 23) *5
[ 0.196058] ACPI: PCI Interrupt Link [LAZA] (IRQs 20 21 22 23) *10
[ 0.196182] ACPI: PCI Interrupt Link [LMC9] (IRQs 20 21 22 23) *0, disabled.
[ 0.196311] ACPI: PCI Interrupt Link [LSMB] (IRQs 20 21 22 23) *10
[ 0.196434] ACPI: PCI Interrupt Link [LPMU] (IRQs 20 21 22 23) *0, disabled.
[ 0.196561] ACPI: PCI Interrupt Link [LSA0] (IRQs 20 21 22 23) *11
[ 0.196687] ACPI: PCI Interrupt Link [LSA1] (IRQs 20 21 22 23) *11
[ 0.196825] ACPI: PCI Interrupt Link [LATA] (IRQs 20 21 22 23) *0, disabled.
[ 0.196953] vgaarb: device added: PCI:0000:02:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.196953] vgaarb: loaded
[ 0.196953] vgaarb: bridge control possible 0000:02:00.0
[ 0.196953] PCI: Using ACPI for IRQ routing
[ 0.203109] PCI: pci_cache_line_size set to 64 bytes
[ 0.203181] reserve RAM buffer: 000000000009b400 - 000000000009ffff
[ 0.203184] reserve RAM buffer: 000000007ffb0000 - 000000007fffffff
[ 0.203332] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.203339] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 31
[ 0.203344] hpet0: 3 comparators, 32-bit 25.000000 MHz counter
[ 0.208084] Switching to clocksource hpet
[ 0.210367] pnp: PnP ACPI init
[ 0.210397] ACPI: bus type pnp registered
[ 0.210544] pnp 00:00: [bus 00-ff]
[ 0.210548] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.210551] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.210553] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.210556] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.210559] pnp 00:00: [mem 0x000d0000-0x000dffff window]
[ 0.210562] pnp 00:00: [mem 0x80000000-0xdfffffff window]
[ 0.210565] pnp 00:00: [mem 0xf0000000-0xfebfffff window]
[ 0.210650] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 0.210685] pnp 00:01: [dma 4]
[ 0.210688] pnp 00:01: [io 0x0000-0x000f]
[ 0.210690] pnp 00:01: [io 0x0081-0x0083]
[ 0.210693] pnp 00:01: [io 0x0087]
[ 0.210695] pnp 00:01: [io 0x0089-0x008b]
[ 0.210698] pnp 00:01: [io 0x008f]
[ 0.210701] pnp 00:01: [io 0x00c0-0x00df]
[ 0.210732] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.210746] pnp 00:02: [io 0x0070-0x0071]
[ 0.210763] pnp 00:02: [irq 8]
[ 0.210796] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.210807] pnp 00:03: [io 0x0061]
[ 0.210839] pnp 00:03: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.210851] pnp 00:04: [io 0x00f0-0x00ff]
[ 0.210860] pnp 00:04: [irq 13]
[ 0.210893] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.212218] pnp 00:05: [io 0x0378-0x037f]
[ 0.212228] pnp 00:05: [irq 7]
[ 0.212230] pnp 00:05: [dma 0 disabled]
[ 0.212585] pnp 00:05: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.213080] pnp 00:06: [mem 0x000d0000-0x000d3fff window]
[ 0.213084] pnp 00:06: [mem 0x000d4000-0x000d7fff window]
[ 0.213086] pnp 00:06: [mem 0x000de000-0x000dffff window]
[ 0.213089] pnp 00:06: [io 0x0010-0x001f]
[ 0.213092] pnp 00:06: [io 0x0022-0x003f]
[ 0.213094] pnp 00:06: [io 0x0044-0x004d]
[ 0.213097] pnp 00:06: [io 0x0050-0x005f]
[ 0.213100] pnp 00:06: [io 0x0062-0x0063]
[ 0.213102] pnp 00:06: [io 0x0065-0x006f]
[ 0.213105] pnp 00:06: [io 0x0072-0x007f]
[ 0.213107] pnp 00:06: [io 0x0080]
[ 0.213110] pnp 00:06: [io 0x0084-0x0086]
[ 0.213112] pnp 00:06: [io 0x0088]
[ 0.213114] pnp 00:06: [io 0x008c-0x008e]
[ 0.213118] pnp 00:06: [io 0x0090-0x009f]
[ 0.213121] pnp 00:06: [io 0x00a2-0x00bf]
[ 0.213124] pnp 00:06: [io 0x00e0-0x00ef]
[ 0.213126] pnp 00:06: [io 0x04d0-0x04d1]
[ 0.213129] pnp 00:06: [io 0x0800-0x080f]
[ 0.213131] pnp 00:06: [io 0x0500-0x057f]
[ 0.213134] pnp 00:06: [io 0x0580-0x05ff]
[ 0.213136] pnp 00:06: [io 0x0800-0x087f]
[ 0.213139] pnp 00:06: [io 0x0880-0x08ff]
[ 0.213142] pnp 00:06: [io 0x0d00-0x0d7f]
[ 0.213144] pnp 00:06: [io 0x0d80-0x0dff]
[ 0.213147] pnp 00:06: [io 0x0900-0x097f]
[ 0.213149] pnp 00:06: [io 0x0980-0x09ff]
[ 0.213152] pnp 00:06: [io 0x1100-0x117f]
[ 0.213155] pnp 00:06: [io 0x1180-0x11ff]
[ 0.213158] pnp 00:06: [mem 0xfec80000-0x1fd93ffff]
[ 0.213160] pnp 00:06: [mem 0xfefe0000-0xfefe01ff]
[ 0.213163] pnp 00:06: [mem 0xfefe1000-0xfefe1fff]
[ 0.213166] pnp 00:06: [mem 0xfee01000-0xfeefffff]
[ 0.213176] pnp 00:06: disabling [io 0x0900-0x097f] because it overlaps 0000:00:01.0 BAR 0 [io 0x0900-0x09ff]
[ 0.213180] pnp 00:06: disabling [io 0x0980-0x09ff] because it overlaps 0000:00:01.0 BAR 0 [io 0x0900-0x09ff]
[ 0.213301] system 00:06: [io 0x04d0-0x04d1] has been reserved
[ 0.213304] system 00:06: [io 0x0800-0x080f] has been reserved
[ 0.213307] system 00:06: [io 0x0500-0x057f] has been reserved
[ 0.213311] system 00:06: [io 0x0580-0x05ff] has been reserved
[ 0.213314] system 00:06: [io 0x0800-0x087f] could not be reserved
[ 0.213318] system 00:06: [io 0x0880-0x08ff] has been reserved
[ 0.213321] system 00:06: [io 0x0d00-0x0d7f] has been reserved
[ 0.213324] system 00:06: [io 0x0d80-0x0dff] has been reserved
[ 0.213328] system 00:06: [io 0x1100-0x117f] has been reserved
[ 0.213331] system 00:06: [io 0x1180-0x11ff] has been reserved
[ 0.213335] system 00:06: [mem 0x000d0000-0x000d3fff window] has been reserved
[ 0.213338] system 00:06: [mem 0x000d4000-0x000d7fff window] has been reserved
[ 0.213342] system 00:06: [mem 0x000de000-0x000dffff window] has been reserved
[ 0.213346] system 00:06: [mem 0xfec80000-0x1fd93ffff] could not be reserved
[ 0.213349] system 00:06: [mem 0xfefe0000-0xfefe01ff] has been reserved
[ 0.213353] system 00:06: [mem 0xfefe1000-0xfefe1fff] has been reserved
[ 0.213357] system 00:06: [mem 0xfee01000-0xfeefffff] has been reserved
[ 0.213360] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.213442] pnp 00:07: [mem 0xfed00000-0xfed00fff]
[ 0.213478] pnp 00:07: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.213554] pnp 00:08: [mem 0xfec00000-0xfec00fff]
[ 0.213557] pnp 00:08: [mem 0xfee00000-0xfee00fff]
[ 0.213560] pnp 00:08: [mem 0x80000000-0x7fffffff disabled]
[ 0.213614] system 00:08: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.213618] system 00:08: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.213621] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.213834] pnp 00:09: [io 0x0000-0xffffffffffffffff disabled]
[ 0.213837] pnp 00:09: [io 0x0230-0x023f]
[ 0.213840] pnp 00:09: [io 0x0290-0x029f]
[ 0.213842] pnp 00:09: [io 0x0a00-0x0a0f]
[ 0.213845] pnp 00:09: [io 0x0a10-0x0a1f]
[ 0.213904] system 00:09: [io 0x0230-0x023f] has been reserved
[ 0.213907] system 00:09: [io 0x0290-0x029f] has been reserved
[ 0.213911] system 00:09: [io 0x0a00-0x0a0f] has been reserved
[ 0.213914] system 00:09: [io 0x0a10-0x0a1f] has been reserved
[ 0.213918] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.214608] pnp 00:0a: [io 0x03f8-0x03ff]
[ 0.214618] pnp 00:0a: [irq 4]
[ 0.214622] pnp 00:0a: [dma 0 disabled]
[ 0.214712] pnp 00:0a: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.214765] pnp 00:0b: [mem 0xe0000000-0xefffffff]
[ 0.214819] system 00:0b: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.214822] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.214994] pnp 00:0c: [mem 0x00000000-0x0009ffff]
[ 0.214997] pnp 00:0c: [mem 0x000c0000-0x000cffff]
[ 0.215000] pnp 00:0c: [mem 0x000e0000-0x000fffff]
[ 0.215003] pnp 00:0c: [mem 0x00100000-0x7fffffff]
[ 0.215006] pnp 00:0c: [mem 0xfec00000-0xffffffff]
[ 0.215071] system 00:0c: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.215075] system 00:0c: [mem 0x000c0000-0x000cffff] could not be reserved
[ 0.215078] system 00:0c: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.215082] system 00:0c: [mem 0x00100000-0x7fffffff] could not be reserved
[ 0.215085] system 00:0c: [mem 0xfec00000-0xffffffff] could not be reserved
[ 0.215089] system 00:0c: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.215405] pnp: PnP ACPI: found 13 devices
[ 0.215408] ACPI: ACPI bus type pnp unregistered
[ 0.223215] PCI: max bus depth: 1 pci_try_num: 2
[ 0.223238] pci 0000:00:04.0: PCI bridge to [bus 01-01]
[ 0.223242] pci 0000:00:04.0: bridge window [io 0xd000-0xdfff]
[ 0.223246] pci 0000:00:04.0: bridge window [mem 0xdde00000-0xddefffff]
[ 0.223252] pci 0000:00:09.0: PCI bridge to [bus 02-02]
[ 0.223255] pci 0000:00:09.0: bridge window [io 0xe000-0xefff]
[ 0.223259] pci 0000:00:09.0: bridge window [mem 0xddf00000-0xdfffffff]
[ 0.223262] pci 0000:00:09.0: bridge window [mem 0xd0000000-0xdbffffff 64bit pref]
[ 0.223267] pci 0000:00:0b.0: PCI bridge to [bus 03-03]
[ 0.223272] pci 0000:00:0c.0: PCI bridge to [bus 04-04]
[ 0.223282] pci 0000:00:04.0: setting latency timer to 64
[ 0.223287] pci 0000:00:09.0: setting latency timer to 64
[ 0.223291] pci 0000:00:0b.0: setting latency timer to 64
[ 0.223296] pci 0000:00:0c.0: setting latency timer to 64
[ 0.223300] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.223302] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.223305] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.223308] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff]
[ 0.223311] pci_bus 0000:00: resource 8 [mem 0x80000000-0xdfffffff]
[ 0.223314] pci_bus 0000:00: resource 9 [mem 0xf0000000-0xfebfffff]
[ 0.223317] pci_bus 0000:01: resource 0 [io 0xd000-0xdfff]
[ 0.223320] pci_bus 0000:01: resource 1 [mem 0xdde00000-0xddefffff]
[ 0.223322] pci_bus 0000:01: resource 4 [io 0x0000-0x0cf7]
[ 0.223325] pci_bus 0000:01: resource 5 [io 0x0d00-0xffff]
[ 0.223328] pci_bus 0000:01: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.223331] pci_bus 0000:01: resource 7 [mem 0x000d0000-0x000dffff]
[ 0.223333] pci_bus 0000:01: resource 8 [mem 0x80000000-0xdfffffff]
[ 0.223336] pci_bus 0000:01: resource 9 [mem 0xf0000000-0xfebfffff]
[ 0.223339] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.223342] pci_bus 0000:02: resource 1 [mem 0xddf00000-0xdfffffff]
[ 0.223345] pci_bus 0000:02: resource 2 [mem 0xd0000000-0xdbffffff 64bit pref]
[ 0.223433] NET: Registered protocol family 2
[ 0.223571] IP route cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.224593] TCP established hash table entries: 262144 (order: 10, 4194304 bytes)
[ 0.227287] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.227927] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.227930] TCP reno registered
[ 0.227942] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.227971] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.228154] NET: Registered protocol family 1
[ 0.228461] ACPI: PCI Interrupt Link [LUB0] enabled at IRQ 23
[ 0.808224] ACPI: PCI Interrupt Link [LUB2] enabled at IRQ 22
[ 0.808289] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.808337] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.808394] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.808448] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.808503] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.808562] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.808625] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.808691] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.808715] pci 0000:02:00.0: Boot video device
[ 0.808725] PCI: CLS 64 bytes, default 64
[ 0.808792] Unpacking initramfs...
[ 1.092597] Freeing initrd memory: 10284k freed
[ 1.100198] audit: initializing netlink socket (disabled)
[ 1.100215] type=2000 audit(1396705765.096:1): initialized
[ 1.115716] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.116471] VFS: Disk quotas dquot_6.5.2
[ 1.116509] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.116599] msgmni has been set to 4020
[ 1.116848] alg: No test for stdrng (krng)
[ 1.116886] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.116890] io scheduler noop registered
[ 1.116892] io scheduler deadline registered
[ 1.116912] io scheduler cfq registered (default)
[ 1.117031] pcieport 0000:00:09.0: setting latency timer to 64
[ 1.117060] pcieport 0000:00:09.0: irq 40 for MSI/MSI-X
[ 1.117135] pcieport 0000:00:0b.0: setting latency timer to 64
[ 1.117154] pcieport 0000:00:0b.0: irq 41 for MSI/MSI-X
[ 1.117214] pcieport 0000:00:0c.0: setting latency timer to 64
[ 1.117233] pcieport 0000:00:0c.0: irq 42 for MSI/MSI-X
[ 1.117344] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.117376] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.117378] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 1.117703] ERST: Table is not found!
[ 1.117705] GHES: HEST is not enabled!
[ 1.117789] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.138138] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.192527] 00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.192884] Linux agpgart interface v0.103
[ 1.193027] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.193462] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.193470] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.193639] mousedev: PS/2 mouse device common for all mice
[ 1.193698] rtc_cmos 00:02: RTC can wake from S4
[ 1.193848] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 1.193888] rtc0: alarms up to one year, y3k, 114 bytes nvram, hpet irqs
[ 1.193903] cpuidle: using governor ladder
[ 1.193905] cpuidle: using governor menu
[ 1.194154] TCP cubic registered
[ 1.194219] NET: Registered protocol family 10
[ 1.194787] Mobile IPv6
[ 1.194790] NET: Registered protocol family 17
[ 1.194795] Registering the dns_resolver key type
[ 1.194966] PM: Hibernation image not present or could not be loaded.
[ 1.194978] registered taskstats version 1
[ 1.195505] rtc_cmos 00:02: setting system clock to 2014-04-05 13:49:25 UTC (1396705765)
[ 1.195558] Initializing network drop monitor service
[ 1.197090] Freeing unused kernel memory: 576k freed
[ 1.197355] Write protecting the kernel read-only data: 6144k
[ 1.202304] Freeing unused kernel memory: 648k freed
[ 1.207901] Freeing unused kernel memory: 688k freed
[ 1.223967] udevd[49]: starting version 175
[ 1.250155] forcedeth: Reverse Engineered nForce ethernet driver. Version 0.64.
[ 1.250435] ACPI: PCI Interrupt Link [LMAC] enabled at IRQ 21
[ 1.250462] forcedeth 0000:00:07.0: setting latency timer to 64
[ 1.280156] SCSI subsystem initialized
[ 1.283134] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.283383] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 19
[ 1.283425] r8169 0000:01:07.0: (unregistered net_device): not PCI Express
[ 1.283930] r8169 0000:01:07.0: eth0: RTL8169sb/8110sb at 0xffffc9000036cc00, 00:21:91:e7:a7:12, XID 10000000 IRQ 19
[ 1.283934] r8169 0000:01:07.0: eth0: jumbo features [frames: 7152 bytes, tx checksumming: ok]
[ 1.284696] usbcore: registered new interface driver usbfs
[ 1.284724] usbcore: registered new interface driver hub
[ 1.284789] usbcore: registered new device driver usb
[ 1.285345] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.313376] forcedeth 0000:00:07.0: ifname eth1, PHY OUI 0x732 @ 3, addr 00:26:18:02:dd:3a
[ 1.313382] forcedeth 0000:00:07.0: highdma pwrctl mgmt gbit lnktim msi desc-v3
[ 1.313872] ehci_hcd 0000:00:02.1: setting latency timer to 64
[ 1.313876] ehci_hcd 0000:00:02.1: EHCI Host Controller
[ 1.313910] ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 1
[ 1.313939] ehci_hcd 0000:00:02.1: debug port 1
[ 1.313946] ehci_hcd 0000:00:02.1: cache line size of 64 is not supported
[ 1.313974] ehci_hcd 0000:00:02.1: irq 22, io mem 0xdddfac00
[ 1.319474] libata version 3.00 loaded.
[ 1.320458] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.324155] ehci_hcd 0000:00:02.1: USB 2.0 started, EHCI 1.00
[ 1.324195] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.324198] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.324201] usb usb1: Product: EHCI Host Controller
[ 1.324204] usb usb1: Manufacturer: Linux 3.2.0-4-amd64 ehci_hcd
[ 1.324206] usb usb1: SerialNumber: 0000:00:02.1
[ 1.324370] hub 1-0:1.0: USB hub found
[ 1.324376] hub 1-0:1.0: 10 ports detected
[ 1.324880] pata_amd 0000:00:06.0: version 0.4.1
[ 1.324942] pata_amd 0000:00:06.0: setting latency timer to 64
[ 1.330810] scsi0 : pata_amd
[ 1.332415] scsi1 : pata_amd
[ 1.332989] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 1.332992] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 1.333101] ohci_hcd 0000:00:02.0: setting latency timer to 64
[ 1.333104] ohci_hcd 0000:00:02.0: OHCI Host Controller
[ 1.333121] ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 2
[ 1.333160] ohci_hcd 0000:00:02.0: irq 23, io mem 0xdddfb000
[ 1.390035] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.390040] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.390043] usb usb2: Product: OHCI Host Controller
[ 1.390046] usb usb2: Manufacturer: Linux 3.2.0-4-amd64 ohci_hcd
[ 1.390048] usb usb2: SerialNumber: 0000:00:02.0
[ 1.390229] hub 2-0:1.0: USB hub found
[ 1.390237] hub 2-0:1.0: 10 ports detected
[ 1.390375] sata_nv 0000:00:08.0: version 3.5
[ 1.390623] ACPI: PCI Interrupt Link [LSA0] enabled at IRQ 20
[ 1.390696] sata_nv 0000:00:08.0: setting latency timer to 64
[ 1.391037] scsi2 : sata_nv
[ 1.391141] scsi3 : sata_nv
[ 1.391278] ata3: SATA max UDMA/133 cmd 0xc400 ctl 0xc080 bmdma 0xb880 irq 20
[ 1.391281] ata4: SATA max UDMA/133 cmd 0xc000 ctl 0xbc00 bmdma 0xb888 irq 20
[ 1.391490] ACPI: PCI Interrupt Link [LSA1] enabled at IRQ 23
[ 1.391533] sata_nv 0000:00:08.1: setting latency timer to 64
[ 1.391815] scsi4 : sata_nv
[ 1.391915] scsi5 : sata_nv
[ 1.392065] ata5: SATA max UDMA/133 cmd 0xb800 ctl 0xb480 bmdma 0xb000 irq 23
[ 1.392068] ata6: SATA max UDMA/133 cmd 0xb400 ctl 0xb080 bmdma 0xb008 irq 23
[ 1.499008] ata2: port disabled--ignoring
[ 1.692018] usb 1-4: new high-speed USB device number 3 using ehci_hcd
[ 1.840874] usb 1-4: New USB device found, idVendor=0cf3, idProduct=9271
[ 1.840877] usb 1-4: New USB device strings: Mfr=16, Product=32, SerialNumber=48
[ 1.840880] usb 1-4: Product: USB2.0 WLAN
[ 1.840882] usb 1-4: Manufacturer: ATHEROS
[ 1.840884] usb 1-4: SerialNumber: 12345
[ 1.856045] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.860042] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.868356] ata5.00: ATA-9: ST1000DM003-1CH162, CC47, max UDMA/133
[ 1.868360] ata5.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.900343] ata5.00: configured for UDMA/133
[ 1.923815] ata3.00: ATA-8: WDC WD1200BEVS-22UST0, 01.01A01, max UDMA/133
[ 1.923819] ata3.00: 234441648 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.936697] ata3.00: configured for UDMA/133
[ 1.936884] scsi 2:0:0:0: Direct-Access ATA WDC WD1200BEVS-2 01.0 PQ: 0 ANSI: 5
[ 2.144017] usb 2-2: new low-speed USB device number 2 using ohci_hcd
[ 2.358036] usb 2-2: New USB device found, idVendor=03f0, idProduct=0324
[ 2.358040] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.358043] usb 2-2: Product: HP Basic USB Keyboard
[ 2.358045] usb 2-2: Manufacturer: LiteON
[ 2.404037] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.412119] ata4.00: ATAPI: Optiarc DVD RW AD-5280S, 1.01, max UDMA/100
[ 2.428118] ata4.00: configured for UDMA/100
[ 2.429277] scsi 3:0:0:0: CD-ROM Optiarc DVD RW AD-5280S 1.01 PQ: 0 ANSI: 5
[ 2.429582] scsi 4:0:0:0: Direct-Access ATA ST1000DM003-1CH1 CC47 PQ: 0 ANSI: 5
[ 2.750243] ata6: SATA link down (SStatus 0 SControl 300)
[ 2.761188] sd 2:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/111 GiB)
[ 2.761199] sd 4:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
[ 2.761204] sd 4:0:0:0: [sdb] 4096-byte physical blocks
[ 2.761248] sd 2:0:0:0: [sda] Write Protect is off
[ 2.761252] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.761260] sd 4:0:0:0: [sdb] Write Protect is off
[ 2.761264] sd 4:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.761276] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.761288] sd 4:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.769387] input: LiteON HP Basic USB Keyboard as /devices/pci0000:00/0000:00:02.0/usb2/2-2/2-2:1.0/input/input0
[ 2.769467] generic-usb 0003:03F0:0324.0001: input,hidraw0: USB HID v1.00 Keyboard [LiteON HP Basic USB Keyboard] on usb-0000:00:02.0-2/input0
[ 2.769491] usbcore: registered new interface driver usbhid
[ 2.769493] usbhid: USB HID core driver
[ 2.770759] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 2.770824] scsi 3:0:0:0: Attached scsi generic sg1 type 5
[ 2.770881] sd 4:0:0:0: Attached scsi generic sg2 type 0
[ 2.811201] sdb: sdb1
[ 2.811613] sd 4:0:0:0: [sdb] Attached SCSI disk
[ 2.833807] sda: sda1 sda2 < sda5 >
[ 2.834235] sd 2:0:0:0: [sda] Attached SCSI disk
[ 2.839069] sr0: scsi3-mmc drive: 48x/48x writer cd/rw xa/form2 cdda tray
[ 2.839076] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.839593] sr 3:0:0:0: Attached scsi CD-ROM sr0
[ 3.264274] PM: Starting manual resume from disk
[ 3.264280] PM: Hibernation image partition 8:5 present
[ 3.264282] PM: Looking for hibernation image.
[ 3.264587] PM: Image not found (code -22)
[ 3.264591] PM: Hibernation image not present or could not be loaded.
[ 3.342001] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.812527] udevd[342]: starting version 175
[ 6.855059] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 6.855068] ACPI: Power Button [PWRB]
[ 6.855150] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 6.855154] ACPI: Power Button [PWRF]
[ 7.029979] parport_pc 00:05: reported by Plug and Play ACPI
[ 7.030026] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
[ 7.034488] k8temp 0000:00:18.3: Temperature readouts might be wrong - check erratum #141
[ 7.493725] EDAC MC: Ver: 2.1.0
[ 7.494816] MCE: In-kernel MCE decoding enabled.
[ 7.506452] i2c i2c-0: nForce2 SMBus adapter at 0x600
[ 7.506481] i2c i2c-1: nForce2 SMBus adapter at 0x700
[ 7.506957] AMD64 EDAC driver v3.4.0
[ 7.506999] EDAC amd64: DRAM ECC disabled.
[ 7.507011] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[ 7.507012] Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
[ 7.507014] (Note that use of the override may cause unknown side effects.)
[ 7.749229] powernow-k8: Found 1 AMD Athlon 64 X2 Dual Core Processor 4200+ (2 cpu cores) (version 2.20.00)
[ 7.749248] [Firmware Bug]: powernow-k8: No compatible ACPI _PSS objects found.
[ 7.749249] [Firmware Bug]: powernow-k8: Try again with latest BIOS.
[ 7.766501] input: PC Speaker as /devices/platform/pcspkr/input/input3
[ 7.911817] cfg80211: Calling CRDA to update world regulatory domain
[ 7.998496] [drm] Initialized drm 1.1.0 20060810
[ 8.531454] wmi: Mapper loaded
[ 8.579453] usb 1-4: firmware: agent aborted loading htc_9271.fw (not found?)
[ 8.579578] ath9k_htc: probe of 1-4:1.0 failed with error -22
[ 8.579605] usbcore: registered new interface driver ath9k_htc
[ 8.883209] ACPI: PCI Interrupt Link [LAZA] enabled at IRQ 22
[ 8.883216] hda_intel: Disabling MSI
[ 8.883244] snd_hda_intel 0000:00:05.0: setting latency timer to 64
[ 9.126924] ACPI: PCI Interrupt Link [LNED] enabled at IRQ 18
[ 9.127580] nouveau 0000:02:00.0: setting latency timer to 64
[ 9.127607] [drm] nouveau 0000:02:00.0: Detected an NVc0 generation card (0x0ce000a1)
[ 9.135065] [drm] nouveau 0000:02:00.0: Checking PRAMIN for VBIOS
[ 9.226410] [drm] nouveau 0000:02:00.0: ... appears to be valid
[ 9.226412] [drm] nouveau 0000:02:00.0: Using VBIOS from PRAMIN
[ 9.226417] [drm] nouveau 0000:02:00.0: BIT BIOS found
[ 9.226421] [drm] nouveau 0000:02:00.0: Bios version 70.24.21.00
[ 9.226425] [drm] nouveau 0000:02:00.0: TMDS table version 2.0
[ 9.226784] [drm] nouveau 0000:02:00.0: MXM: no VBIOS data, nothing to do
[ 9.226787] [drm] nouveau 0000:02:00.0: DCB version 4.0
[ 9.226791] [drm] nouveau 0000:02:00.0: DCB outp 00: 02000300 00000000
[ 9.226794] [drm] nouveau 0000:02:00.0: DCB outp 01: 01000302 00020030
[ 9.226797] [drm] nouveau 0000:02:00.0: DCB outp 02: 04011380 00000000
[ 9.226800] [drm] nouveau 0000:02:00.0: DCB outp 03: 08011382 00020030
[ 9.226802] [drm] nouveau 0000:02:00.0: DCB outp 04: 02022362 00020010
[ 9.226805] [drm] nouveau 0000:02:00.0: DCB conn 00: 00001030
[ 9.226808] [drm] nouveau 0000:02:00.0: DCB conn 01: 00010130
[ 9.226811] [drm] nouveau 0000:02:00.0: DCB conn 02: 00002261
[ 9.226816] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 0 at offset 0x6E81
[ 9.246809] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 1 at offset 0x7581
[ 9.254463] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 2 at offset 0x8D6D
[ 9.254466] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 3 at offset 0x8D77
[ 9.254523] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 4 at offset 0x8F56
[ 9.254525] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table at offset 0x8FBB
[ 9.274372] [drm] nouveau 0000:02:00.0: 0x8FBB: Condition still not met after 20ms, skipping following opcodes
[ 9.276801] [TTM] Zone kernel: Available graphics memory: 1030316 kiB
[ 9.276803] [TTM] Initializing pool allocator
[ 9.276811] [TTM] Initializing DMA pool allocator
[ 9.276826] [drm] nouveau 0000:02:00.0: Detected 1024MiB VRAM (GDDR5)
[ 9.277188] [drm] nouveau 0000:02:00.0: 512 MiB GART (aperture)
[ 9.280417] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 9.280419] [drm] No driver support for vblank timestamp query.
[ 9.285507] [drm] nouveau 0000:02:00.0: 3 available performance level(s)
[ 9.285512] [drm] nouveau 0000:02:00.0: 0: core 50MHz shader 101MHz memory 135MHz voltage 950mV
[ 9.285516] [drm] nouveau 0000:02:00.0: 1: core 405MHz shader 810MHz memory 324MHz voltage 950mV
[ 9.285521] [drm] nouveau 0000:02:00.0: 3: core 880MHz shader 1760MHz memory 2100MHz voltage 962mV-1050mV
[ 9.285526] [drm] nouveau 0000:02:00.0: c: core 50MHz shader 101MHz memory 135MHz voltage 950mV fanspeed 40%
[ 9.460433] [drm] nouveau 0000:02:00.0: allocated 1680x1050 fb: 0x1e0000, bo ffff880036f63000
[ 9.460543] fbcon: nouveaufb (fb0) is primary device
[ 9.493544] Console: switching to colour frame buffer device 210x65
[ 9.504345] fb0: nouveaufb frame buffer device
[ 9.504347] drm: registered panic notifier
[ 9.504358] [drm] Initialized nouveau 1.0.0 20120316 for 0000:02:00.0 on minor 0
[ 9.510129] cfg80211: World regulatory domain updated:
[ 9.510134] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 9.510138] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 9.510142] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 9.510145] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 9.510148] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 9.510152] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 10.656462] input: HDA NVidia Headphone as /devices/pci0000:00/0000:00:05.0/sound/card0/input4
[ 10.656911] ACPI: PCI Interrupt Link [LNEA] enabled at IRQ 17
[ 10.656933] hda_intel: Disabling MSI
[ 10.656983] snd_hda_intel 0000:02:00.1: setting latency timer to 64
[ 11.508016] HDMI status: Codec=0 Pin=5 Presence_Detect=0 ELD_Valid=0
[ 11.540014] HDMI status: Codec=1 Pin=5 Presence_Detect=0 ELD_Valid=0
[ 11.572015] HDMI status: Codec=2 Pin=5 Presence_Detect=0 ELD_Valid=0
[ 11.604015] HDMI status: Codec=3 Pin=5 Presence_Detect=0 ELD_Valid=0
[ 11.620139] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:09.0/0000:02:00.1/sound/card1/input5
[ 11.620625] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:09.0/0000:02:00.1/sound/card1/input6
[ 11.621745] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:09.0/0000:02:00.1/sound/card1/input7
[ 11.622783] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:09.0/0000:02:00.1/sound/card1/input8
[ 14.156349] Adding 4190204k swap on /dev/sda5. Priority:-1 extents:1 across:4190204k
[ 14.175764] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 14.452054] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 14.652072] loop: module loaded
[ 16.406755] RPC: Registered named UNIX socket transport module.
[ 16.406759] RPC: Registered udp transport module.
[ 16.406761] RPC: Registered tcp transport module.
[ 16.406763] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 16.477439] FS-Cache: Loaded
[ 16.540774] FS-Cache: Netfs 'nfs' registered for caching
[ 16.560429] Installing knfsd (copyright © 1996 [email protected]).
[ 18.236788] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
[ 18.246526] NFSD: starting 90-second grace period
[ 20.965057] Bluetooth: Core ver 2.16
[ 20.965088] NET: Registered protocol family 31
[ 20.965091] Bluetooth: HCI device and connection manager initialized
[ 20.965096] Bluetooth: HCI socket layer initialized
[ 20.965099] Bluetooth: L2CAP socket layer initialized
[ 20.965105] Bluetooth: SCO socket layer initialized
[ 21.003571] Bluetooth: RFCOMM TTY layer initialized
[ 21.003579] Bluetooth: RFCOMM socket layer initialized
[ 21.003581] Bluetooth: RFCOMM ver 1.11
[ 21.714117] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 21.714121] Bluetooth: BNEP filters: protocol multicast
[ 23.498179] lp0: using parport0 (interrupt-driven).
[ 23.632727] ppdev: user-space parallel port driver
[ 23.836179] r8169 0000:01:07.0: eth0: link down
[ 23.836597] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 24.137687] forcedeth 0000:00:07.0: irq 43 for MSI/MSI-X
[ 35.624024] eth1: no IPv6 routers present
[ 2304.049858] kjournald starting. Commit interval 5 seconds
[ 2304.050687] EXT3-fs (sdb1): using internal journal
[ 2304.050693] EXT3-fs (sdb1): mounted filesystem with ordered data mode
[ 2615.568062] ata4.00: exception Emask 0x10 SAct 0x0 SErr 0x1950000 action 0xe
[ 2615.568070] ata4: SError: { PHYRdyChg CommWake Dispar LinkSeq TrStaTrns }
[ 2615.568075] sr 3:0:0:0: CDB: Get event status notification: 4a 01 00 00 10 00 00 00 08 00
[ 2615.568088] ata4.00: cmd a0/00:00:00:08:00/00:00:00:00:00/a0 tag 0 pio 16392 in
[ 2615.568090] res 51/04:00:00:08:00/00:00:00:00:00/a0 Emask 0x10 (ATA bus error)
[ 2615.568094] ata4.00: status: { DRDY ERR }
[ 2615.568102] ata4: hard resetting link
[ 2615.568104] ata4: nv: skipping hardreset on occupied port
[ 2616.440039] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2616.456123] ata4.00: class mismatch 3 != 1
[ 2616.456126] ata4.00: revalidation failed (errno=-19)
[ 2616.456131] ata4: limiting SATA link speed to 1.5 Gbps
[ 2621.440022] ata4: hard resetting link
[ 2621.440026] ata4: nv: skipping hardreset on occupied port
[ 2621.908034] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2621.924123] ata4.00: class mismatch 3 != 1
[ 2621.924126] ata4.00: revalidation failed (errno=-19)
[ 2621.924131] ata4.00: disabled
[ 2626.908022] ata4: hard resetting link
[ 2627.788032] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2627.796222] ata4.00: ATA-7: WDC WD2500JS-08NCB1, 10.02E01, max UDMA/133
[ 2627.796226] ata4.00: 488397168 sectors, multi 0: LBA48 NCQ (depth 0/32)
[ 2627.804220] ata4.00: configured for UDMA/133
[ 2627.804235] ata4: EH complete
[ 2627.804251] sr 3:0:0:0: rejecting I/O to offline device
[ 2627.804283] ata4.00: detaching (SCSI 3:0:0:0)
[ 2627.805820] scsi 3:0:0:0: Direct-Access ATA WDC WD2500JS-08N 10.0 PQ: 0 ANSI: 5
[ 2627.806013] sd 3:0:0:0: [sdc] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[ 2627.806063] sd 3:0:0:0: [sdc] Write Protect is off
[ 2627.806066] sd 3:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 2627.806087] sd 3:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2627.806405] sd 3:0:0:0: Attached scsi generic sg1 type 0
[ 2627.844983] ldm_parse_tocblock(): Cannot find TOCBLOCK, database may be corrupt.
[ 2627.844991] ldm_parse_tocblock(): Cannot find TOCBLOCK, database may be corrupt.
[ 2627.869236] sdc: [LDM] sdc1 sdc2
[ 2627.869783] sd 3:0:0:0: [sdc] Attached SCSI disk
[ 2767.241532] EXT4-fs (sdc): VFS: Can't find ext4 filesystem
[ 2767.256278] EXT3-fs (sdc): error: can't find ext3 filesystem on dev sdc.
[ 2775.847326] EXT4-fs (sdc): VFS: Can't find ext4 filesystem
[ 2775.864233] EXT3-fs (sdc): error: can't find ext3 filesystem on dev sdc.
[ 2859.314293] fuse init (API version 7.17)
[ 2974.934685] EXT4-fs (sdc): VFS: Can't find ext4 filesystem
[ 2981.895374] EXT4-fs (sdc): VFS: Can't find ext4 filesystem
[ 2985.124308] EXT3-fs (sdc): error: can't find ext3 filesystem on dev sdc.
[ 3368.864040] ata4.00: exception Emask 0x10 SAct 0x0 SErr 0x1990000 action 0xe frozen
[ 3368.864047] ata4: SError: { PHYRdyChg 10B8B Dispar LinkSeq TrStaTrns }
[ 3368.864052] ata4.00: failed command: READ DMA
[ 3368.864059] ata4.00: cmd c8/00:20:00:00:00/00:00:00:00:00/e0 tag 0 dma 16384 in
[ 3368.864061] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x14 (ATA bus error)
[ 3368.864064] ata4.00: status: { DRDY }
[ 3368.864072] ata4: hard resetting link
[ 3368.864074] ata4: nv: skipping hardreset on occupied port
[ 3369.590248] ata4: SATA link down (SStatus 0 SControl 300)
[ 3374.588028] ata4: hard resetting link
[ 3374.588032] ata4: nv: skipping hardreset on occupied port
[ 3374.910242] ata4: SATA link down (SStatus 0 SControl 300)
[ 3374.910251] ata4: limiting SATA link speed to 1.5 Gbps
[ 3379.908045] ata4: hard resetting link
[ 3379.908050] ata4: nv: skipping hardreset on occupied port
[ 3380.230245] ata4: SATA link down (SStatus 0 SControl 300)
[ 3380.230254] ata4.00: disabled
[ 3380.230263] ata4.00: device reported invalid CHS sector 0
[ 3380.230272] sd 3:0:0:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 3380.230276] sd 3:0:0:0: [sdc] Sense Key : Aborted Command [current] [descriptor]
[ 3380.230281] Descriptor sense data with sense descriptors (in hex):
[ 3380.230283] 72 0b 00 00 00 00 00 0c 00 0a 80 00 00 00 00 00
[ 3380.230290] 00 00 00 00
[ 3380.230294] sd 3:0:0:0: [sdc] Add. Sense: No additional sense information
[ 3380.230299] sd 3:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 00 00 00 20 00
[ 3380.230306] end_request: I/O error, dev sdc, sector 0
[ 3380.230311] Buffer I/O error on device sdc, logical block 0
[ 3380.230316] Buffer I/O error on device sdc, logical block 1
[ 3380.230319] Buffer I/O error on device sdc, logical block 2
[ 3380.230323] Buffer I/O error on device sdc, logical block 3
[ 3380.230332] sd 3:0:0:0: rejecting I/O to offline device
[ 3380.230336] sd 3:0:0:0: killing request
[ 3380.230340] ata4: EH complete
[ 3380.230349] ata4.00: detaching (SCSI 3:0:0:0)
[ 3380.231545] sd 3:0:0:0: [sdc] Synchronizing SCSI cache
[ 3380.231587] sd 3:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 3380.231592] sd 3:0:0:0: [sdc] Stopping disk
[ 3380.231599] sd 3:0:0:0: [sdc] START_STOP FAILED
[ 3380.231602] sd 3:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Det virker som om det er en del feilmeldinger som kommer opp når jeg kobler til disken?
Basert på de feilmeldingene ser det ut som en død disk eller dårlig kabel. Prøv en annen kabel og en annen SATA-port. Hvis det fortsatt ikke virker har nok disken tatt kvelden.
Den surrer og går, og har fungert bare for et par uker siden.
Får prøve det og håpe på det beste..
