Prossesor til redigering
Fra Adobe Lightroom sin "Optimize Performance" guide :
Options that can help increase performance include:
  • 64-bit, multiple-core processor (for best performance, up to six cores. The extra power is especially important if you use multiple or high-resolution monitors which require more power).
En rimelig i7 prosessor vil vel passe fint til slikt bruk? Evt en dyr en om du har ubegrenset med penger :)
