GeForce GTX Titan Z
Ca samme pris som 2x titan black hvis man ser bort ifra moms etc som blir lagt til her i Norge.
Dette er jo et billig proffkort, som faktisk er veldig billig i forhold til Quadro korta. Titan støtter double precicion, og derfor velger mange Titan som et billig alternativ til Quadro.
Over at the GTC in the USA Jen Hsun Huang (CEO of NVIDIA) has unveiled a new addition to the Titan line-up, the GeForce GTX TITAN Z. That graphics card comes with 12 GB of graphics memory. It is a dual-GPU solution, so that would be 2x 6GB. The Shader processor count doubles up as well at a cool 5,760 CUDA cores.
This will give the GeForce Titan Z a cool 8 TeraFLOPS of performance. Here's the downside, the card will cost a whopping $2999.
Built around two Kepler GPUs and 12GB of dedicated frame buffer memory, TITAN Z is engineered for next-generation 5K and multi-monitor gaming. With two GK110 chips, TITAN Z is powered by a total of 5,760 processing cores, or 2,880 cores per GPU.
Unlike traditional dual-GPU cards, Titan Z’s twin GPUs are tuned to run at the same clock speed, and with dynamic power balancing. So neither GPU creates a performance bottleneck. And that performance is delivered in a card that is cool and quiet, rather than hot and loud. Low-profile components and ducted baseplate channels minimize turbulence and improves acoustic quality.
“If you’re in desperate need of a supercomputer that you need to fit under your desk, we have just the card for you,” Jen-Hsun said.
http://www.guru3d.com/news_story/geforce_titan_z_has_12gb_graphics_memory.html
Endret av Nizzen
Det koster tre ganger så mye som et Titan Black, med mindre man trenger mer enn tre GPUer i en maskin virker det som et litt meningsløst produkt...
For en gjennomsnittlig gamer er det i det minste 100% meningsløst å kjøpe det, men jeg tviler ikke et øyeblikk på at EK/Koolance/etc. vil komme med vannblokk :p
er dette i stede for 790 tro eller vil 790 også komme lurer jeg på...
700 serien vil vel bli byttet ut med 800 serien/maxwell om ikke så lenge , så en 790 tror jeg nok neppe vi får se i denne generasjonen. Må dog si at det var skuffende at de ikke kom med noe info om maxwell under presentasjonen :(
Om det ikke var lenge til noe nytt av Maxwell (kraftigere brikker og/eller ny produksjonsnode) hadde Nvidia nevnt noe om dette i dag, det gjorde de ikke og det er derfor rimelig å anta at det er minst 4 måneder til vi ser snurten av Maxwell.
Endret av N o r e n g
Om det ikke var lenge til Maxwell hadde Nvidia nevnt noe om disse GPUene i dag, det gjorde de ikke og det er derfor rimelig å anta at det er minst 4 måneder til vi ser snurten av Maxwell.
Du får kjøpt Maxwell i dag... ;) Kortene heter GTX 750Ti og GTX750... :)
At de store Maxwell-kortene ikke dukker opp på denne siden av sommeren en riktig anntakelse ja!
blir spennende å se åssen GeForce GTX Titan Z gjør det på tester fremover og åssen frekvenser det blir å kjøre på
Spennende er det jo ikkje. All info har vi allerede. Eneste som ikkje er kjent er gpu frekvens, men den kan jo settes nesten som man vil +/- 1000mhz.
Tja, vi vet at det skal yte 8 TFLOPS, det betyr at base-frequency (før boost) vil ligge på ca 700 MHz. En så lav frekvens tyder på at kortet ligger på rundt 375W TDP, så får vi se hvor høyt Power Limit kan settes i praksis, uansett vil nok ytelsen være minst 20% lavere enn 2 stk Titan Black.
alltid spennende med noe nytt vet du hehe ;)
Like spennende som GTX690 var. Altså samme gpu som GTX 680 men med lavere frekvens. Dårligere overklokkingspotensiale. Altså veldig kjedelig, med mindre man bare har plass til ett skjermkort i datamaskinen.
Når 780 Ti Classified eksisterer er det liten grunn til å velge dette kortet, det er ren ønsketenkning å tro at Nvidia kommer til å tillate mer enn 10% økning på power limit, og med stock-frekvens 20-30% lavere enn et 780 Ti vil det knapt klare å matche et skikkelig overklokket 780 Ti Classified.
har aldri hatt sansen for dissu dual gpu kortene. og dette forandrer ikke på det. er som noreng sier 20% lavere ytelse til en mye høyere prislapp.
