Was elle were i dette tilfellet?
dorge
Jeg vet at was skal brukes der substantivet er entall, og were skal brukes der substantivet er flertall, i denne setningen, skal det være was eller were her? "There was\were both a king and a queen"
Takk
Interessant spørsmål. Jeg søkte det opp, og det var ingen bred enighet, men jeg kan sitere en senior medlem av wordreference.com:
Whether to say there is or there are depends on the notional meaning of the subject, on whether the words are written or spoken, and on the importance of the "flow" of the sentence ("there's" is faster and simpler to say than "there are" or even "there're").
If a(n) implies "one" and and means "plus", then a man and a woman = 1 + 1 = 2, which is plural.
However, if and means "with", then a man and a woman = a man with a woman = 1 (with another) = 1, which is singular. I have already mentioned other singular notions that can be expressed as "a man and a woman". With a singular notion, there is is the right choice.
I hope all this helps you pick the right verb for your context.
Så det blir nok riktig å bruke were her. Both er jo flertall i sin natur, så det er litt rart hvis det skal bli behandla som entall.
Was for entall, were for flertall.
There was a boy who lived in the woods
There were three boys who lived in the woods
There was a king and a queen who lived in a castle
There were two princes and princesses who lived in a Castle
Er du sikker på dette? Mener du da at begge disse setningene er korrekte?
There was a king and two queens in the castle.
There were two queens and one king in the castle.
Gjest Bruker-182691
Jeg hadde gått for disse på en eventuell grammar-test.
There was both a king and a queen.
(There = it)
It was
_ _ _ _ _ _ _
They were both kings and queens (ikke at den setningen gir noen mening)
They were
Slik jeg forstår det.
Endret av HaxyQ
Jeg ville sannsynligvis også ha gjort det dersom jeg ikke tenkte meg om, fordi disse høres mest naturlige ut i mitt hode. Men innlegget til victrixx tilsier vel noe annet?
HaxyQ: Hvorfor er ikke "a king and a Queen" = "they"?
Language is fluid and dynamic. As a native speaker myself, it just sounds right even though it ma y break old grammatical rules. You language also has general rules but with many exceptions
Really hard for foreigners to learn, eh?
Do you agree that "there were a king and two queens in the castle" is correct?
Vi snakker fortsatt flertall, så ja. "A king and two queens" kan omtales som "they".
Så hvorfor er ikke "there were a king and a queen who lived in a castle" riktig? Vi snakker fortsatt flertall.
Yesiree! 2 Queens cinches the deal!
