Gjest medlem-332567 Skrevet 28. februar 2014 Rapporter Del Skrevet 28. februar 2014 Usually installing any antivirus will slow down any system, so be wise and choose an antivirus which is effective but light on the system as well.Everyone has a different favorite antivirus program. For example, some say Norton Antivirus 2011 is one of the best on the market, and allows you to run fully protected while taking up almost no system resources. Others say Norton has at least 3 to 4 separate processes running and slows the system down. Before making a big investment, talk to a few people and do some online research. Try out some of the programs individually first, if possible. Whatever you choose, make sure you have backups of your important files though. Vet noen om en bra antivirus some ikke " slower down system, eller tar all system resources." ? Lenke til kommentar
Axxxy Skrevet 28. februar 2014 Rapporter Del Skrevet 28. februar 2014 Jeg bruker AVG Free, funker helt fint den. Kan gjøre PCen litt treig om du skanner etter virus, men uten om det så har jeg aldri hatt problemer. -Daniel Lenke til kommentar
Gjest medlem-332567 Skrevet 28. februar 2014 Rapporter Del Skrevet 28. februar 2014 Takk, Daniel! Noen andre forslag? Lenke til kommentar
