Configurere Split VPN av normal VPN
Rudde
  • 2 uker senere...
Jeg antar Windows, så hva sier 'netstat -rn' når du har koblet opp VPN klienten? Dersom klienten benytter den ordinære rutingtabellen burde det ikke være noe problem å få det ordnet med et par kommandoer etter at tunnelen er opprettet.
Hei Zerge, netstat -rn
C:\Users\Rudde>netstat -rn
Grensesnittliste
 25...00 05 9a 3c 7a 00 ......Cisco AnyConnect Secure Mobility Client Virtual Mi
niport Adapter for Windows x64
 13...00 23 54 88 6d 71 ......Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Contr
oller #2
 11...00 23 54 88 65 98 ......Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Contr
oller
 17...08 00 27 00 e4 30 ......VirtualBox Host-Only Ethernet Adapter
 18...00 50 56 c0 00 01 ......VMware Virtual Ethernet Adapter for VMnet1
 19...00 50 56 c0 00 08 ......VMware Virtual Ethernet Adapter for VMnet8
  1...........................Software Loopback Interface 1
 16...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
 12...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
 14...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2
 15...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #3
 20...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #4
 21...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #5
 27...00 00 00 00 00 00 00 e0 Microsoft 6to4 Adapter
IPv4 rutetabell
Aktive ruter:
Nettverksmål   Nettverksmaske          Gateway     Grensesnitt Metrikk
          0.0.0.0          0.0.0.0      192.168.0.1     192.168.0.98      2
          0.0.0.0          0.0.0.0     128.39.140.1   128.39.140.234      2
        127.0.0.0        255.0.0.0         Ved LAN         127.0.0.1    306
        127.0.0.1  255.255.255.255         Ved LAN         127.0.0.1    306
  127.255.255.255  255.255.255.255         Ved LAN         127.0.0.1    306
      128.39.49.5  255.255.255.255      192.168.0.1     192.168.0.98      2
     128.39.140.0    255.255.254.0         Ved LAN    128.39.140.234    257
   128.39.140.234  255.255.255.255         Ved LAN    128.39.140.234    257
   128.39.141.255  255.255.255.255         Ved LAN    128.39.140.234    257
     192.168.0.98  255.255.255.255         Ved LAN      192.168.0.98    257
     192.168.56.1  255.255.255.255         Ved LAN      192.168.56.1    276
     192.168.78.1  255.255.255.255         Ved LAN      192.168.78.1    276
    192.168.197.1  255.255.255.255         Ved LAN     192.168.197.1    276
        224.0.0.0        240.0.0.0         Ved LAN         127.0.0.1    306
        224.0.0.0        240.0.0.0         Ved LAN      192.168.56.1    276
        224.0.0.0        240.0.0.0         Ved LAN      192.168.0.98    257
        224.0.0.0        240.0.0.0         Ved LAN      192.168.78.1    276
        224.0.0.0        240.0.0.0         Ved LAN     192.168.197.1    276
        224.0.0.0        240.0.0.0         Ved LAN    128.39.140.234    257
  255.255.255.255  255.255.255.255         Ved LAN         127.0.0.1    306
  255.255.255.255  255.255.255.255         Ved LAN      192.168.56.1    276
  255.255.255.255  255.255.255.255         Ved LAN      192.168.0.98    257
  255.255.255.255  255.255.255.255         Ved LAN      192.168.78.1    276
  255.255.255.255  255.255.255.255         Ved LAN     192.168.197.1    276
  255.255.255.255  255.255.255.255         Ved LAN    128.39.140.234    257
Faste ruter:
  Nettverksadresse          Nettverksmaske  Gateway-adresse  Metrisk
IPv6 rutetabell
Aktive ruter:
 Gr Metr.  Nettv.  Mål              Gateway
  1    306 ::1/128                  Ved LAN
 27   1010 2002::/16                Ved LAN
 27    266 2002:8027:8cea::8027:8cea/128
                                    Ved LAN
 18    276 fe80::6459:5f77:48d0:a71d/128
                                    Ved LAN
 19    276 fe80::9d77:3624:25e1:67ed/128
                                    Ved LAN
 17    276 fe80::a1f8:5994:a69c:96f0/128
                                    Ved LAN
  1    306 ff00::/8                 Ved LAN
 17    276 ff00::/8                 Ved LAN
 18    276 ff00::/8                 Ved LAN
 19    276 ff00::/8                 Ved LAN
Faste ruter:
  Ingen
Men den skulle det ja, hvordan skal jeg konfigurere det?
Jeg antar at LANet ditt er 192.168.0.0/24?
Gitt at IPn din alltid er 192.168.0.98 og at du bruker et av Marvell Yukon kortene, burde følgende kommando etter oppkobling av VPN løse problemet ditt:
"route add 192.168.0.0 mask 255.255.255.0 0.0.0.0 METRIC 25 IF 11"
Alternativt, dersom IF 11 ikke er riktig Marvell kort:
"route add 192.168.0.0 mask 255.255.255.0 0.0.0.0 METRIC 25 IF 13"
Tusen takk for tilbakemelding Zerge! Men jeg fikk det ikke til å fungere :/ Jeg antar det skal la lokal komme gjennom. Er det mulig å få IP'er bak VPN'en rettet mot den da jeg vet IP-rangen jeg trenger? 128.39.0.0/16
La inn kommandoen etter jeg koblet til VPN på korrekt IF men får fortsatt ikke pinga lokale IP'er
Jeg kjenner ikke klienten spesielt, men kanskje den har lagt inn et annet filter i tillegg?
Har du sjekket network bindings og provider order? Du kommer dit ved å gå inn i Control Panel\Network and Internet\Network Connections og å ta frem menyen; Advanced\Advanced settings
