Know your flamers: Enkel innføring i forum-psykologi :)
Fra sida http://www.winternet.com/~mikelr/flame1.html har vi da i fleng:
Ferrus Cranus
Ferrous Cranus is utterly impervious to reason, persuasion and new ideas, and when engaged in battle he will not yield an inch in his position regardless of its hopelessness. Though his thrusts are decisively repulsed, his arguments crushed in every detail and his defenses demolished beyond repair he will remount the same attack again and again with only the slightest variation in tactics. Sometimes out of pure frustration Philosopher will try to explain to him the failed logistics of his situation, or Therapist will attempt to penetrate the psychological origins of his obduracy, but, ever unfathomable, Ferrous Cranus cannot be moved.
L'Enfant Provocateur
L'Enfant Provocateur likes to stir up trouble because...because, well...just because. This species of Flame Warrior is almost always young and male - it could be just a hormone thing.
Filibuster
Filibuster and his pet topic form an endless loop. If his first thrust doesn't win the day, he will try to gain ground with a second, third, fourth ... nth repetition. He may even make a good initial attack, but his monotonous hectoring and prodigious output rapidly clears the field of other Warriors. Filibuster eventually lands in everyone's killfile .
Rebel Leader has an uncanny ability to upset the settled order of a discussion forum. Other Warriors may be excellent in mano a mano combat, but Rebel Leader's charisma, political instincts and verbal skills enable him to rally a collective assult that can overthrow the Royals and even silence Cyber Sisters. Depending on the issue Rebel Leader uses to advance his attack he may draw allies from almost any of the other Warrior classes, but he can usually count on Loopy in the early stages of the conflict and Sycophant once the revolution is well underway. Once the revolution has succeeded, however, Rebel Leader quickly loses interest in the cause. As is the case with false King-Fu Masters, the bones of soi-disant Rebel Leaders litter the battlefields.
Issues has an issue and she wants it to be everyone's issue. The discussion could be about fondue pots and Issue would rage about the multinational corporate conspiracy to exploit fondue pot workers. Of course, Issues is found among all ideological persuasions - anti-gun mothers, gun totin' mothers, bloodthirsty feminists, troglodyte misogynists, politically correct, politically incorrect, lefties, righties, vegetarians, carnivores, radical Rotarians - it doesn't matter. HINT: An effective tactic to employ against Issues is indifference.
