Skifte CPU
kjetilbmoe
For å si det sånn: fortell meg om hovedkortet ditt så skal jeg fortelle deg om CPU'en din ;)
Okeeeei;
Motherboard Properties
Motherboard ID 51-2300-000000-00101111-030199-$D845PT
Motherboard Name Intel Pendleton D845PT
Front Side Bus Properties
Bus Type Intel NetBurst
Bus Width 64-bit
Real Clock 100 MHz (QDR)
Effective Clock 400 MHz
Bandwidth 3200 MB/s
Memory Bus Properties
Bus Type DDR SDRAM
Bus Width 64-bit
Real Clock 133 MHz (DDR)
Effective Clock 267 MHz
Bandwidth 2133 MB/s
Chipset Bus Properties
Bus Type Intel Hub Interface
Bus Width 8-bit
Real Clock 67 MHz (QDR)
Bandwidth 267 MB/s
Motherboard Physical Info
CPU Sockets/Slots 1
Expansion Slots 3 PCI, 1 AGP
RAM Slots 2 DIMM
Integrated Devices Audio
Form Factor Micro ATX
Motherboard Size 210 mm x 240 mm
Motherboard Chipset i845D
... vil dette passe til cpu'en som johndoe foreslo?
