 Nå har også Corsair lansert en ny RMi  serie :
Computex 2015 - Corsair has just announced a new PSU range with its RMi Series, which is offering 80 Plus Gold efficiency, silent operation with a 'silent Zero-RPM' fan, Corsair Link operation, and much more.
45553_08_corsair-intros-rmi-series-psus-
Corsair will be offering its new RMi Series PSUs in 650W, 750W, 850W and 1000W capacities. Corsair has built the new RMi Series PSUs from the ground up to offer 80 PLUS Gold energy efficiency, with 105C rated Japanese capacitors, so that gamers don't need to worry about using power hungry components with the RMi Series PSUs.
Inside, the RMi Series PSUs will feature a 140mm fluid dynamic bearing equipped cooling fan which runs in "Zero RPM" fan mode, only spinning up when the PSU only needs it. The Corsair RMi Series PSUs are fully modular, making them much easier on cable management inside of your PC.
Here are the full specs on the Corsair RMi Series PSUs:
  • 80 PLUS Gold certified: High efficiency operation for less excess heat and lower operating costs
  • 100% all Japanese 105°C capacitors: Premium internal components ensure solid power delivery and long-term reliability
  • Zero RPM Fan Mode: Allows for virtually silent operation at low and medium loads
  • Configurable +12V rail options: Can be run in the default multi-rail +12V mode, or toggled to single-rail operation
  • Corsair Link Digital: Advanced desktop application lets users monitor and log fan speed, voltages and power consumption, as well as control fan speed and toggle the +12V rail from multi-rail to a single +12V rail
  • Seven year warranty: A guarantee of reliable operation that will last across several system builds
As for pricing, here's the breakdown:
  • 650W - $129.99 MSRP
  • 750W - $139.99 MSRP
  • 850W - $159.99 MSRP
  • 1000W - $189.99 MSRP
Read more at http://www.tweaktown.com/news/45553/corsair-intros-rmi-series-psus-650w-1000w/index.html
Tilbake til topic: Denne er vel et godt kjøp nå som den er på tilbud?
Bygd av Seasonic såvidt jeg vet.
https://www.komplett.no/cooler-master-v1000-1000w-psu/791776?cks=ASS&assoc=26FB581C-3DAA-4F6A-AEA0-8720D71DBD87
Faktisk veldig godt tilbud.
Kjøpte den selv tidligere når den var på tilbud til 1195kr, fantastisk god PSU, får veldig mye skryt hos JonnyGuru, du kan lese testen her:
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=344
Enesten "minuset" er at ene sata kablen kunne vert en smule lengre :p
Endret av sveibuen
Njæ prøver å ligge på 50-60% load.
Typisk 2 og 2 gpuer pr pc
9serien til nvidia er jo en sikker vinner, 2x 970 litt klokket i en i5rigg med 100% load kun på gpuer er 270w fra veggen.
De eneste psuene som har døtt og tatt med seg hele pcen er en qtec som tok fyr og en coolermaster 1000w som lagde fyrverkeri i alle kontaktene.
Men det er jo ikke noe problem, det tar 2 dager å skaffe ny hardware
Bah ... Der døde den ene Antec 1300'n min.
Den klarer ikke levere mer enn rundt 650 - 700W kan det virke som.
Ved full last slår maskinen seg umiddelbart av. Jeg vet jeg trekker i område 1000-1050W fra veggen da.
Satte inn den andre enheten og maskinen fungerer fint igjen.
Surt :\ Hadde håpt denne skulle klart seg lenger. Den er vært i 24/7 bruk i ca 14 måneder nå med en last på mellom 30 - 75%.
