Okay, mysteriet med Corsair AX 1200i er løst. Det var ikke PSU'en som pep, men derimot Arcea 1224-8i kortet pga et array er "Degraded. En HDD er visst død virker det som, så må nok investere i ny HDD. Blir ikke Seagate denne gangen.
Så feil kan man altså ta. :blush:
Men kjekt slik sett, lettere å skifte en HDD enn røske ut en PSU og sette inn ny.
LOL !
Den pipinga har jeg også hatt noen ganger :p Fra Arecaen altså
Fikk litt info i dag ang RM serien til Corsair.
RM 750 og 850 var det som strøk hos HardOCP. Nå har Corsair byttet ut komponentene som gjor at den strøyk og har passert HardOCP sin test.
Editor's Note II: Corsair has verified changes made to RM units that would address the shutdown issues we experienced. These changes would very likely earn the Corsair RM series at the very least a "HardOCP PASS."
The RM Series PSUs, like all Corsair PSUs, are designed and tested using methodologies that closely simulate the environment of an enthusiast/gaming PC under heavy, sustained workloads. Our testing has proven that the cooling system of the RM Series will engage and provide the necessary cooling during heavy real world use.
That said, we’re enthusiasts, too. We understand why Kyle and Paul came to the conclusions they did, and based on their feedback, we’ve implemented a design change that will allow our RM Series PSUs to go the extra mile and endure the extreme synthetic test conditions of the HardOCP test lab.
We have changed the value of the resistor between the thermistor and the fan controller so the fan turns on much sooner than the temperature that would trigger OTP. Therefore the fan should always turn on before OTP is triggered; preventing the PSU from shutting down before it is necessary.
This change has been implemented in all RM PSUs produced since mid October. While we honestly believe even extreme users will never run into the issue encountered during HardOCP’s synthetic test, those end users that want to know if their RM can endure HardOCP’s torture test can identify the updated PSUs by a lot code of 1341 or higher.
Endret av sveibuen
Fikk smake litt på AX1200i sin OCP her nå :p
Satte 1,35 vcore på begge 780 Ti Classyene + 4,7 GHz og 1,35 vcore på CPU. Startet Firestrike Extreme og hard shutdown i det første GPU-test startet. LOL
Justerte så ned vcore på GPU'ene til 1,3V, da klarte den å kjøre igjennom FSE med total last på 1320W
Hvor mye trekker de stock?
Får 2 og skal sette dem i en ax 860i :hmm:
Med CPU(4960X) på 4,7 GHz 1,35 vcore så trekker hele riggen 720W med GPU'ene på stock(1,117 vcore tror jeg det er)
En økning til 1,25Vcore gir en økning på 150W pr kort fra 720W til 1020W.
Alle målinger er gjort i Firestrike Extreme der høyeste måling alltid kommer i den første GPU-testen
Ser ikke ut til at 1400MHz på core på GPU'ene er mulig med kun en 1200W PSU.
Endret av Minhund
What? Riggen min trekker ca 860W med 2 x Titan og 4960X (ved folding). Lett OC på Titan kortene, men CPU er ikke klokket i det hele tatt. Forbruk målt fra veggkontakt.
Men jeg har også 32 GB G.Skill TridentX 2400 MHz RAM pluss 7 HDD og 2 SSD'er, og et Areca 1224-8I kort.
Mulig 16 stk Vifter på fullt og 2 stk 35x pumper trekker litt men ja det drar unna med OC på både CPU og GPU'er.
Maks beregnet TDP på stoc:
GPU - 500w
CPU - 130W
Vifter - 30w
HDD - 50-100W (sjelden med kontinuerlig last)
Resten - 70w
Totalt: 780-830W maks last på alt.
Fra veggen blir det: 850-905W
Du kjører du ikke alt maks på samme tid, og TDP er jo ikke alltid mulig å nå på stock med gode brikker. Men med en mild OC på skjermkortene så havner du allikevel rundt disse resultatene.
Kortene til Minhund trekker nok fort rundt det dobbelte. (900-1000W alene)
Og med grei clock på CPU så betviler jeg ikke at OCP på PSUen slår ut. :p
Endret av Andrull
Gikk vifta for fullt? Var det tempen som gjor at den slo seg av?
For høy last for PSU, spratt vel fort opp over 1500-1600W i det FSE startet
Det var nå litt :)
Alltid kjekt å se at sikkerhetsfunksjonene faktisk fungerer slik dem skal :)
Ja er enig i det, var vel også min egen feil siden jeg burde ha vist at det kom til å skje men med nytt HK og CPU sammen med GPU'ene så tenkte jeg ikke på det. Får koble på Antec 1200W TPQ i tillegg når jeg kommer hjem.
Liten oppdatering på første post :)
Ser det kan være litt forvirrende med dem som trenger en billig PSU, så lagde egen "seksjon" til dette.
Hva synes dere ?
Vil si den passer til midrang oppsett :) (altså 280x gtx770 i5 4670k i7 4770k osv)
Ser ut som JonnyGuru har testet denne "nye" versjonen og han er ikke fornøyd. Så da blir det heller ikke å se denne serien i første post.
Link til Jonnyguru sin test
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=369
