Hvordan kan jeg få mindre lagg når jeg spiller Minecraft?
Selvfølgelig har jeg eksempler! :)
Det første du må gjøre er å trykke på ESC -> Video-innstillinger
Så gjør du følgende:
- Ta "Grafikk" på "rask"
- Ta "Rendringsavstand" på "kort" eller "mini"
- Ta "Ytelse" på "Maks FPS"
- Ta av "Skyer"
- Og ta "Partikler" på minimalt
Nå har jeg Minecraft på norsk da, som du sikkert ser. Burde iallefall minske hakkinga, hvis du ikke allerede har satt disse innstillingene.
Last ned Optifine :)
http://optifine.net/downloads.php
Features
  • FPS boost (examples)
    - doubling the FPS is common
    - decreases lag spikes and smooths gameplay
  • Support for HD Textures (info)
    - HD textures and HD fonts (MCPatcher not needed)
    - custom terrain and item textures
    - animated terrain and item textures
    - custom HD Font character widths
    - custom colors
    - custom block color palettes
    - custom lighting
    - unlimited texture size
  • Variable Render Distance (example)
    - from Tiny to Extreme (2 x Far) in 16m steps
    - sun, moon and stars are visible in Tiny and Short distance
  • Configurable Smooth Lighting (examples)
    - from 1% - smooth lighting without shadows
    - to 100% - smooth lighting with full shadows
  • Performance: VSync
    Synchronizes framerate with monitor refresh rate to remove split frames and smooth gameplay
  • Smart Advanced OpenGL
    - more efficient, less artifacts
    - Fast - faster, some artifacts still visible
    - Fancy - slower, avoids visual artifacts
  • Fog control
    - Fog: Fancy, Fast, OFF
    - Fog start: Near, Far
  • Mipmaps (examples)
    - Visual effect which makes distant objects look better by smoothing the texture details
    - Mipmap level - OFF, 1, 2, 3, Max
    - Mipmap type - Nearest, Linear
  • Anisotropic Filtering (examples)
    - Restores details in mipmapped textures
    - AF level - OFF, 2, 4, 8, 16 (depends on hardware support)
  • Antialiasing (examples)
    - Smooths jagged lines and sharp color transitions
    - AA level - OFF, 2, 4, 6, 8, 12, 16 (depends on hardware support)
  • Better Grass
    Fixes grass blocks side texture to match surrounding grass terrain
  • Better Snow (examples, credit)
    Fixes transparent blocks textures to match surrounding snow terrain
  • Clear Water (examples)
    Clear, transparent water with good visibility underwater
  • Random Mobs
    Use random mob textures if available in the texture pack
  • Connected Textures (examples)
    Connects textures for glass, glass panes, sandstone and bookshelf blocks which are next to each other.
  • Natural Textures (examples, idea)
    Removes the gridlike pattern created by repeating blocks of the same type. Uses rotated and flipped variants of the base block texture.
  • FPS control
    - Smooth FPS - stabilizes FPS by flushing the graphics driver buffers (examples)
    - Smooth Input - fixes stuck keys, slow input and sound lag by setting correct thread priorities
  • Chunk Loading Control
    - Load Far - loads the world chunks at distance Far, allows fast render distance switching
    - Preloaded Chunks - defines an area in which no new chunks will be loaded
    - Chunk Updates per Frame - allows for faster world loading
    - Dynamic Updates - loads more chunks per frame when the player is standing still
  • Configurable Details
    - Clouds - Default, Fast, Fancy
    - Cloud Height - from 0% to 100%
    - Trees - Default, Fast, Fancy
    - Grass - Default, Fast, Fancy
    - Water - Default, Fast, Fancy
    - Rain and Snow - Default, Fast, Fancy
    - Sky - ON, OFF
    - Stars - ON, OFF
    - Sun & Moon - ON, OFF
    - Depth Fog - ON, OFF
    - Weather - ON, OFF
    - Swamp Colors - ON, OFF
    - Smooth Biomes - ON, OFF
    - Custom Fonts - ON, OFF
    - Custom Colors - ON, OFF
    - Show Capes - ON, OFF (supports HD capes)
  • Configurable animations
    - Water Animated - OFF, Dynamic, ON
    - Lava Animated - OFF, Dynamic, ON
    - Fire Animated - OFF, ON
    - Portal Animated - OFF, ON
    - Redstone Animated - OFF, ON
    - Explosion Animated - OFF, ON
    - Flame Animated - OFF, ON
    - Smoke Animated - OFF, ON
    - Void Particles - OFF, ON
    - Water Particles - OFF, ON
    - Rain Splash - OFF, ON
    - Portal Particles - OFF, ON
    - Dripping Water/Lava - OFF, ON
    - Terrain Animated - OFF, ON
    - Items Animated - OFF, ON
  • Fast Texturepack Switching
    Switch the current Texturepack without leaving the world
  • Fullscreen Resolution
    Configurable fullscreen resolution
  • Debug
    - Fast Debug Info - removes lagometer from debug screen
    - Debug Profiler - removes profiler from debug screen
  • Time Control
    Default, Day Only or Night Only - works in only in Creative mode
  • Autosave
    - Configurable Autosave interval
    - A fix for the famous Lag Spike of Death
Endret av Lakus
Du mener jeg bare skal laste ned Optifine? Skjønte ikke poenget med det andre du skrev :) Men ja, etter å ha fulgt Tastens tips merker jeg litt mindre lagg en vanligvis :) Jeg skal laste ned Optifine, og se om det blir enda mindre lagg. Jeg mener å ha klart å få pcen opp i 120fps på Creative bare så det er sagt, men det forventer jeg ikke nå. Fps har jo ikke så mye å si heller.
Endret av flamethower1234
