Sletting av spill, men ikke savegame på ps4
kiss1979
Du kan jo laste save games opp til Cloud hvis du er PS+ medlem.
Eller du kan kopiere savegames til USB-pinne.
http://youtu.be/5QlwHrL9M80?t=1m5s
På IGN står det forøvrig.
Ok, I accidentally deleted Call of Duty: Ghosts of my PS4. What had happened is that I had CoD running, but I was on the Homescreen, and I went to close the game, but some how, don't ask me how, I clicked "delete" instead of "close application". I freaked out because I though all my data would be gone, that means my classes and everything would be erased. But, I took out the game and put it back in so it would install. When I did, the current patch and my "Free-Fall" map started downloading too, I got really scared because that means my Add-Ons and Patches were erased, meaning my data probably was too. But nope, when I started the game my classes and everything was still there. This is cool because that means you should probably be able to un-install a game, but keep your saved files if you ever wanted to install it back on your PS4. So if you hit that max 500GBs in the future, you should be able to take off some games you don't play anymore, but keep it's data so if still ever wanted to play it again in the future, you could.
Save Data is separate from Game Data.
Unless you delete your Save Data, you won't lose anything. This has been the same with PS3...
Endret av Tor Rasmussen
