Minidump Analyse
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa8009966028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000be200000, High order 32-bits of the MCi_STATUS value.
Arg4: 000000000005110a, Low order 32-bits of the MCi_STATUS value.
Kjører !errrec på argument 2 for og se hvor feilen ligger.
2: kd> !errrec fffffa8009966028
Common Platform Error Record @ fffffa8009966028
Record Id     : 01cf2422c1cca503
Severity      : Fatal (1)
Length        : 928
Creator       : Microsoft
Notify Type   : Machine Check Exception
Timestamp     : 2/7/2014 21:42:41 (UTC)
Flags         : 0x00000000
Section 0     : Processor Generic
Descriptor    @ fffffa80099660a8
Section       @ fffffa8009966180
Offset        : 344
Length        : 192
Flags         : 0x00000001 Primary
Severity      : Fatal
Proc. Type    : x86/x64
Instr. Set    : x64
Error Type    : Cache error
Operation     : Generic
Flags         : 0x00
Level         : 2
CPU Version   : 0x00000000000306a9
Processor ID  : 0x0000000000000004
Section 1     : x86/x64 Processor Specific
Descriptor    @ fffffa80099660f0
Section       @ fffffa8009966240
Offset        : 536
Length        : 128
Flags         : 0x00000000
Severity      : Fatal
Local APIC Id : 0x0000000000000004
CPU Id        : a9 06 03 00 00 08 10 04 - bf e3 9a 7f ff fb eb bf
                00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00
Proc. Info 0  @ fffffa8009966240
Section 2     : x86/x64 MCA
Descriptor    @ fffffa8009966138
Section       @ fffffa80099662c0
Offset        : 664
Length        : 264
Flags         : 0x00000000
Severity      : Fatal
Error         : GCACHEL2_ERR_ERR (Proc 2 Bank 6)
  Status      : 0xbe2000000005110a
  Address     : 0x0000000080ae6b00
  Misc.       : 0x0000001080000086
Legg merke til "Fatal" dette interne feil som skjer i CPU.
Du må teste CPU,prime-95(velge small FFTs)følg med på temp.
IntelBurnTest er også grei og bruke.
Sjekk for nyeste BIOS.
Lenge siden gjort rent for støv?
