Graphic card - which adapter do i need?
I just got a new graphic card, GTX 670 Gigabyte. I want to use two monitors but it seems i need another adapter to plug in my secondary monitor but i dont know what it's called?
Here's a picture;
http://images.bit-tech.net/content_images/2012/11/gigabyte-geforce-gtx-670-2gb-review/gigabyte670-4b.jpg
I use a normal DVI adapter for the lower one, but it doesnt fit the upper input. Does anyone know which adapter i need?
(You can reply in norwegian if you want to)
