ns på 9600pro
Thombr86
K4D26323RA
1M x 32Bit x 4 Banks Double Data Rate Synchronous DRAM
General Description
FOR 1M x 32Bit x 4 Bank DDR SDRAM
The 4Mx32DDR SDRAM is 134,217,728 bits of hyper synchronous data rate Dynamic RAM organized as 4 x1,048,976 words by 32 bits, fabricated with SAMSUNG's high performance CMOS technology. Synchronous features with Data Strobe allow extremely high performance up to 2.8GB/s/chip. I/O transactions are possible on both edges of the clock cycle. Range of operating frequencies, programmable burst length and programmable latencies allow the device to be useful for a variety of high performance memory system applications.
Features
2.8V ± 5% power supply for device operation
2.8V ± 5% power supply for I/O interface
SSTL_2 compatible inputs/outputs
4 banks operation
MRS cycle with address key programs
- Read latency 3,4 (clock)
- Burst length (2, 4, 8 and Full page)
- Burst type (sequential & interleave)
Full page burst length for sequential burst type only
Start address of the full page burst should be even
All inputs except data & DM are sampled at the positive
going edge of the system clock
Differential clock input
No Wrtie-Interrupted by Read Function
4 DQS’s ( 1DQS / Byte )
Data I/O transactions on both edges of Data strobe
DLL aligns DQ and DQS transitions with Clock transition
Edge aligned data & data strobe output
Center aligned data & data strobe input
DM for write masking only
Auto & Self refresh
32ms refresh period (4K cycle)
144-Ball FBGA
Maximum clock frequency up to 350MHz
Maximum data rate up to 700Mbps/pin
Dette her hadde du og funnet hadde du søkt litt på google...
