medlem-68510 Skrevet 4. januar 2014 Del Skrevet 4. januar 2014 For IPv6 på en av mine servere har jeg valg å konfigurere både en 6in4-bro fra Hurricane Electric, og en 6to4-bro. Problemet er at de ikke vil fungere samtidig. Begge IPv6-adressene kan pinges utenfra, så lenge bare ett av interfacene er oppe av gangen. uname -a Linux mikros.flaten.it 3.2.0-4-amd64 #1 SMP Debian 3.2.51-1 x86_64 GNU/Linux cat /etc/network/interfaces # The loopback network interface auto lo iface lo inet loopback # The primary network interface allow-hotplug eth0 iface eth0 inet dhcp # 6to4 IPv6 tunnel auto tun6to4 iface tun6to4 inet6 v4tunnel address 2002:b923:b870::1 netmask 16 gateway ::192.88.99.1 endpoint any local 185.35.184.112 # Hurricane Electric IPv6 tunnel auto tun6in4 iface tun6in4 inet6 v4tunnel address 2001:470:27:8bf::2 netmask 64 endpoint 216.66.80.90 local 185.35.184.112 ttl 255 gateway 2001:470:27:8bf::1 # Hurricane Electric IPv6 public address iface tun6in4 inet6 static address 2001:470:28:8bf::1 netmask 64 ifconfig eth0 Link encap:Ethernet HWaddr 6a:fb:00:87:57:86 inet addr:185.35.184.112 Bcast:185.35.184.112 Mask:255.255.255.255 inet6 addr: fe80::68fb:ff:fe87:5786/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:854 errors:0 dropped:0 overruns:0 frame:0 TX packets:236 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:67190 (65.6 KiB) TX bytes:42826 (41.8 KiB) Interrupt:24 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:1 errors:0 dropped:0 overruns:0 frame:0 TX packets:1 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:28 (28.0 B) TX bytes:28 (28.0 B) tun6in4 Link encap:IPv6-in-IPv4 inet6 addr: fe80::b923:b870/128 Scope:Link inet6 addr: 2001:470:28:8bf::1/64 Scope:Global inet6 addr: 2001:470:27:8bf::2/64 Scope:Global UP POINTOPOINT RUNNING NOARP MTU:1480 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) tun6to4 Link encap:IPv6-in-IPv4 inet6 addr: ::185.35.184.112/128 Scope:Compat inet6 addr: 2002:b923:b870::1/16 Scope:Global UP RUNNING NOARP MTU:1480 Metric:1 RX packets:6 errors:0 dropped:0 overruns:0 frame:0 TX packets:6 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:624 (624.0 B) TX bytes:624 (624.0 B)Har noen ærfaring med dette? Lenke til kommentar
medlem-68510 Skrevet 4. januar 2014 Forfatter Del Skrevet 4. januar 2014 Her er forøvrig brannmuren min https://gist.github.com/Jckf/8260875 Men jeg tviler på at den er problemet. Lenke til kommentar
medlem-68510 Skrevet 4. januar 2014 Forfatter Del Skrevet 4. januar 2014 Når begge er oppe får jeg sendt trafikk over 6to4, men ikke nådd den adressen utenfra. Motsatt får jeg ikke sendt trafikk over 6in4, men når den adressen utenfra. Lenke til kommentar
medlem-68510 Skrevet 5. januar 2014 Forfatter Del Skrevet 5. januar 2014 (endret) IPv4 ruting http://pastie.org/8603906 IPv6 ruting http://pastie.org/8603904 Endret 5. januar 2014 av medlem-68510 Lenke til kommentar
