BHJM Skrevet 6. oktober 2003 Del Skrevet 6. oktober 2003 Hei!! 2 VB program kjører på samme maskin samtidig, hvordan kan man utveksle data mellom disse programmene. Jeg vil ikke mellomlagre data på fil, men ha "tilgang" til variabel verdiene direkte i det ene programmet fra det andre. :o Lenke til kommentar
aadnk Skrevet 7. oktober 2003 Del Skrevet 7. oktober 2003 Lim dette inn i en modul: Option Explicit Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long Declare Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, lParam As Any) As Long Declare Function SetWindowLong Lib "user32" Alias "SetWindowLongA" (ByVal hwnd As Long, ByVal nIndex As Long, ByVal dwNewLong As Long) As Long Declare Function CallWindowProc Lib "user32" Alias "CallWindowProcA" (ByVal lpPrevWndFunc As Long, ByVal hwnd As Long, ByVal Msg As Long, ByVal wParam As Long, ByVal lParam As Long) As Long Declare Sub CopyMemory Lib "kernel32" Alias "RtlMoveMemory" (Destination As Any, Source As Any, ByVal Length As Long) Public Const WM_MESSAGE = &H11223 Public Const GWL_WNDPROC = (-4) Dim PrevProc As Long Public Sub HookForm(F As Form) PrevProc = SetWindowLong(F.hwnd, GWL_WNDPROC, AddressOf WindowProc) End Sub Public Sub UnHookForm(F As Form) SetWindowLong F.hwnd, GWL_WNDPROC, PrevProc End Sub Public Function WindowProc(ByVal hwnd As Long, ByVal uMsg As Long, ByVal wParam As Long, ByVal lParam As Long) As Long Dim Buff$ WindowProc = CallWindowProc(PrevProc, hwnd, uMsg, wParam, lParam) If uMsg = WM_MESSAGE Then Buff = Space(wParam) CopyMemory Buff, ByVal lParam, wParam MsgBox Buff End If End Function Public Sub Send(WindowClass As String, WindowCaption As String, Data As String) Dim Wnd& Wnd = FindWindow(WindowClass, WindowCaption) If Wnd = 0 Then Exit Sub SendMessage Wnd, WM_MESSAGE, LenB(Data), Data End Sub Start så ved å legge til Hookform Me i Form_Load i formen som skal mota dataen. I Form_Unload skal dette legges til: Unhookform Me Gjør så det samme i det andre prosjektet. For å sende data må du bruke sub-en Send som skal brukes slik: Send "ThunderFormDC", <den andre formens caption>, <tekst> Ersatt "MsgBox Buff" med de kodene du trenger. Buff er på det tidspunktet dataen du sente. Lenke til kommentar
BHJM Skrevet 19. oktober 2003 Forfatter Del Skrevet 19. oktober 2003 takk takk.... Lenke til kommentar
