Nvidia drivere
Jeg installerte TuxRacer på pc'en, det hakket så mye at jeg bestemte meg for å installere nvidia driverne til GeForce kortet mitt. Men når jeg skulle starte TuxRacer etterpå så får jeg bare en feilmelding :( Noen som vet hvordan dette kan fikses?
Feilmeldingen:
[lystig@localhost lystig]$ tuxracer
Tux Racer 0.61 -- a Sunspire Studios Production (http://www.sunspirestudios.com)
(c) 1999-2000 Jasmin F. Patry <[email protected]>
"Tux Racer" is a trademark of Jasmin F. Patry
Tux Racer comes with ABSOLUTELY NO WARRANTY. This is free software,
and you are welcome to redistribute it under certain conditions.
See http://www.gnu.org/copyleft/gpl.html for details.
Xlib:  extension "GLX" missing on display ":0.0".
*** tuxracer error: Couldn't initialize video: Couldn't find matching GLX visual (Success)
If you already have an XF86Config file working with a different driver
(such as the 'nv' or 'vesa' driver), then all you need to do is find
the relevant Device section and replace the line:
       Driver "nv"
   (or Driver "vesa")
with
       Driver "nvidia"
In the Module section, make sure you have:
       Load   "glx"
You should also remove the following lines:
       Load  "dri"
       Load  "GLcore"
