Street Legal ERROR!!
Jeg har skaffet meg spillet Street Legal, har instalert d å alt gikk helt greit, men når jeg prøver å starte spillet får jeg følgende feil mld :
"D3DERR_INVALICALL" så når jeg trykker å OK kommer denne feil mld opp "Create hw 3d device FAILED" derreter fulgt av send feilrapport meldinga..... PLZ hjelp meg!! Vet street legal er gammalt , men alikavel!
Sender likså godt hele direct X fila inn... :)
Specs:
System Information
Time of this report: 10/3/2003, 12:36:11
Machine name: MOI
Operating System: Windows XP Professional (5.1, Build 2600) (2600.xpclient.010817-1148)
Language: Norwegian (Bokmål) (Regional Setting: Norwegian (Nynorsk))
System Manufacturer: MSI
System Model: MS-6712
BIOS: Version 07.00T
Processor: AMD Athlon XP 1900+, MMX, 3DNow, ~1.6GHz
Memory: 512MB RAM
Page File: 153MB used, 1097MB available
Windows Dir: C:WINDOWS
DirectX Version: DirectX 9.0b (4.09.0000.0902)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0001.0902 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce4 Ti 4200
Manufacturer: NVIDIA
Chip type: GeForce4 Ti 4200
DAC type: Integrated RAMDAC
Device Key: EnumPCIVEN_10DE&DEV_0253&SUBSYS_87021462&REV_A3
Display Memory: 128.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Panasonic LC50S (TX-D5L31F)
Monitor Max Res: 1024,768
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.4403 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 5/2/2003 15:19:00, 3180171 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 5/2/2003 15:19:00, 1312555 bytes
Device Identifier: {D7B71E3E-4113-11CF-E166-08A702C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0253
SubSys ID: 0x87021462
Revision ID: 0x00A3
Revision ID: 0x00A3
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Digitallydenhet for SB Live!
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCIVEN_1102&DEV_0002&SUBSYS_80641102&REV_07
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: emu10k1m.sys
Driver Version: 5.12.0001.3300 (English)
WHQL Logo'd: Yes
Date and Size: 8/17/2001 20:19:26, 283904 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 5000, 100000
Static/Strm HW Mix Bufs: 64, 62
Static/Strm HW 3D Bufs: 64, 62
HW Memory: 0
Voice Management: Yes
EAX 2.0 Listen/Src: Yes, Yes
I3DL2 Listen/Src: No, No
Sensaura ZoomFX: No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:WINDOWSSYSTEM32driversGM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
SB Live! MIDI UART, Hardware (Kernel Mode), Input, No DLS, External
SB Live! MIDI UART, Hardware (Kernel Mode), Output, No DLS, External
Digitallydenhet for SB Live!, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI-tilordning [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
B: SB Live! MIDI-synthesizer [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
A: SB Live! MIDI-synthesizer [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Live! MIDI UART [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Live! MIDI UART [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB rothub
| Vendor/Product ID: 0x1106, 0x3038
| Matching Device ID: usbroot_hub
| Service: usbhub
| Driver: usbhub.sys, 10/9/2001 12:00:00, 50688 bytes
| Driver: usbd.sys, 10/9/2001 12:00:00, 4736 bytes
+-+ Generisk USB-hub
| | Vendor/Product ID: 0x050F, 0x0003
| | Matching Device ID: usbclass_09
| | Service: usbhub
| +-+ Microsoft USB IntelliMouse Explorer 3.0
| | | Vendor/Product ID: 0x045E, 0x0047
| | | Matching Device ID: usbvid_045e&pid_0047
| | | Service: HidUsb
| | | Driver: hidusb.sys, 10/9/2001 12:00:00, 9600 bytes
| | | Driver: hidclass.sys, 10/9/2001 12:00:00, 33152 bytes
| | | Driver: hidparse.sys, 10/9/2001 12:00:00, 23680 bytes
| | | Driver: hid.dll, 10/9/2001 12:00:00, 22528 bytes
| | | | Matching Device ID: hidvid_045e&pid_0047
| | | | Service: mouhid
| | | | Driver: mouhid.sys, 10/9/2001 12:00:00, 12160 bytes
| | | | Driver: mouclass.sys, 10/9/2001 12:00:00, 22016 bytes
Gameport Devices
+ PCI-buss
| Matching Device ID: *pnp0a03
| Service: pci
| Driver: pci.sys, 10/9/2001 12:00:00, 62464 bytes
+-+ Spillport for Creative SBLive!
| | Matching Device ID: pciven_1102&dev_7002
| | Lower Filters: ctljystk
| | Service: gameenum
| | Driver: ctljystk.sys, 8/17/2001 20:19:20, 3712 bytes
| | Driver: gameenum.sys, 8/17/2001 22:02:32, 9728 bytes
PS/2 Devices
+ Standard 101-/102-tasters tastatur, eller Microsoft Natural PS/2-tastatur
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 10/9/2001 12:00:00, 50944 bytes
| Driver: kbdclass.sys, 10/9/2001 12:00:00, 23424 bytes
+ Tastaturdriver for Terminal Server
| Matching Device ID: rootrdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/18/2001 06:38:00, 37896 bytes
+ Musedriver for Terminal Server
| Matching Device ID: rootrdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0900)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0900)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: Generic SoftK56
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 IPX Service Provider: IPX Adapter 1 - (00000000,0010A71692A5)
DirectPlay8 TCP/IP Service Provider: Telenor - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech 8.6 kbit/s
DirectPlay Lobbyable Apps
Pro Bass Fishing 2003 (DX8) - Registry: OK, ExeFile: ProBass.exe (1.00.0000.0000) LauncherFile: (<File Missing>)
Streetracer (DX7) - Registry: OK, ExeFile: Outlaw.exe ()
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 6.6 GB
Total Space: 76.3 GB
File System: FAT32
Model: SAMSUNG SP8004H
Drive: D:
Model: SAMSUNG DVD-ROM SD-616F
Driver: c:windowssystem32driverscdrom.sys, 5.01.2600.0000 (Norwegian (Nynorsk)), 10/9/2001 12:00:00, 47488 bytes
Drive: E:
Model: Generic STEALTH DVD SCSI CdRom Device
System Devices
Device ID: PCIVEN_14F1&DEV_2F00&SUBSYS_02B0A0A0&REV_013&61AAA01&0&50
Driver: n/a
Name: VIA Tech CPU til AGP-kontroller
Device ID: PCIVEN_1106&DEV_B099&SUBSYS_00000000&REV_003&61AAA01&0&08
Driver: C:WINDOWSSystem32DRIVERSVIAAGP.SYS, 5.01.2600.0000 (English), 8/17/2001 21:58:02, 27392 bytes
Name: ISA-bro av PCI-standard
Device ID: PCIVEN_1106&DEV_3177&SUBSYS_00000000&REV_003&61AAA01&0&88
Driver: C:WINDOWSSystem32DRIVERSisapnp.sys, 5.01.2600.0000 (Norwegian (Bokmål)), 10/9/2001 12:00:00, 35968 bytes
Name: Universal Serial Bus (USB)-kontroller
Device ID: PCIVEN_1106&DEV_3104&SUBSYS_71201462&REV_823&61AAA01&0&83
Driver: n/a
Name: VIA Tech CPU til PCI-bro
Device ID: PCIVEN_1106&DEV_3099&SUBSYS_00000000&REV_003&61AAA01&0&00
Driver: n/a
Name: Lydkontroller for multimedia
Device ID: PCIVEN_1106&DEV_3059&SUBSYS_71201462&REV_503&61AAA01&0&8D
Driver: n/a
Name: VIA versjon 5 eller senere USB universell vertskontroller
Device ID: PCIVEN_1106&DEV_3038&SUBSYS_71201462&REV_803&61AAA01&0&82
Driver: C:WINDOWSsystem32driversusbuhci.sys, 5.01.2600.0000 (English), 10/9/2001 12:00:00, 18944 bytes
Driver: C:WINDOWSsystem32driversusbport.sys, 5.01.2600.0000 (English), 10/9/2001 12:00:00, 123264 bytes
Driver: C:WINDOWSSystem32usbui.dll, 5.01.2600.0000 (Norwegian (Bokmål)), 10/6/2001 14:02:38, 67072 bytes
Driver: C:WINDOWSsystem32driversusbhub.sys, 5.01.2600.0000 (English), 10/9/2001 12:00:00, 50688 bytes
Device ID: PCIVEN_1106&DEV_3038&SUBSYS_71201462&REV_803&61AAA01&0&81
Device ID: PCIVEN_1106&DEV_3038&SUBSYS_71201462&REV_803&61AAA01&0&80
Name: VIA Bus Master IDE-kontroller
Device ID: PCIVEN_1106&DEV_0571&SUBSYS_71201462&REV_063&61AAA01&0&89
Driver: C:WINDOWSSystem32DRIVERSviaide.sys, 1.00.0001.0000 (English), 10/9/2001 12:00:00, 4352 bytes
Driver: C:WINDOWSSystem32DRIVERSpciidex.sys, 5.01.2600.0000 (Norwegian (Nynorsk)), 10/9/2001 12:00:00, 23680 bytes
Driver: C:WINDOWSSystem32DRIVERSatapi.sys, 5.01.2600.0000 (English), 10/9/2001 12:00:00, 86656 bytes
Name: Spillport for Creative SBLive!
Device ID: PCIVEN_1102&DEV_7002&SUBSYS_00201102&REV_073&61AAA01&0&39
Driver: C:WINDOWSsystem32driversctljystk.sys, 5.01.2501.0000 (English), 8/17/2001 20:19:20, 3712 bytes
Driver: C:WINDOWSSystem32DRIVERSgameenum.sys, 5.01.2600.0000 (English), 8/17/2001 22:02:32, 9728 bytes
Name: Creative SB Live! Series (WDM)
Device ID: PCIVEN_1102&DEV_0002&SUBSYS_80641102&REV_073&61AAA01&0&38
Driver: n/a
Name: Realtek RTL8139 Family PCI Fast Ethernet-kort
Device ID: PCIVEN_10EC&DEV_8139&SUBSYS_D0101429&REV_103&61AAA01&0&40
Driver: C:WINDOWSSystem32DRIVERSRTL8139.sys, 5.396.0530.2001 (English), 8/17/2001 20:12:42, 23070 bytes
Name: NVIDIA GeForce4 Ti 4200
Device ID: PCIVEN_10DE&DEV_0253&SUBSYS_87021462&REV_A34&618BA55&0&0008
Driver: C:WINDOWSSystem32DRIVERSnv4_mini.sys, 6.14.0010.4403 (English), 5/2/2003 15:19:00, 1312555 bytes
Driver: C:WINDOWSSystem32nvinstnt.dll, 6.14.0010.4403 (Norwegian (Nynorsk)), 5/2/2003 15:19:00, 126976 bytes
Driver: C:WINDOWSSystem32nvsvc32.exe, 6.14.0010.4403 (English), 5/2/2003 15:19:00, 69632 bytes
Driver: C:WINDOWSSystem32nv4_disp.dll, 6.14.0010.4403 (English), 5/2/2003 15:19:00, 3180171 bytes
Driver: C:WINDOWSSystem32nvoglnt.dll, 6.14.0010.4403 (English), 5/2/2003 15:19:00, 3764224 bytes
Driver: C:WINDOWSSystem32nvcpl.dll, 6.14.0010.4403 (English), 5/2/2003 15:19:00, 4640768 bytes
Driver: C:WINDOWSSystem32nvmctray.dll, 6.14.0010.4403 (English), 5/2/2003 15:19:00, 49152 bytes
Driver: C:WINDOWSSystem32nview.dll, 6.14.0010.4403 (English), 5/2/2003 15:19:00, 835654 bytes
Driver: C:WINDOWSSystem32dmcpl.exe, 6.14.0010.4403 (English), 5/2/2003 15:19:00, 1323008 bytes
Driver: C:WINDOWSSystem32nvshell.dll, 6.14.0010.4403 (English), 5/2/2003 15:19:00, 467016 bytes
Driver: C:WINDOWSSystem32nvtuicpl.cpl, 6.14.0010.4403 (English), 5/2/2003 15:19:00, 143360 bytes
Driver: C:WINDOWSSystem32nwiz.exe, 6.14.0010.4403 (English), 5/2/2003 15:19:00, 323584 bytes
Driver: C:WINDOWSSystem32nviewimg.dll, 6.14.0010.4403 (English), 5/2/2003 15:19:00, 512000 bytes
Driver: C:WINDOWSSystem32keystone.exe, 6.14.0010.4403 (English), 5/2/2003 15:19:00, 286806 bytes
Driver: C:WINDOWShelpnvcpl.hlp, 5/2/2003 15:19:00, 50792 bytes
Driver: C:WINDOWShelpnvwcplen.hlp, 5/2/2003 15:19:00, 22977 bytes
Driver: C:WINDOWSnviewgeneric.tvp, 5/2/2003 15:19:00, 30902 bytes
Driver: C:WINDOWSSystem32nvrsar.dll, 6.14.0010.4403 (Arabic), 5/2/2003 15:19:00, 3403776 bytes
Driver: C:WINDOWSSystem32nvwrsar.dll, 6.14.0010.4403 (Arabic), 5/2/2003 15:19:00, 143360 bytes
Driver: C:WINDOWSSystem32nvrscs.dll, 6.14.0010.4403 (Czech), 5/2/2003 15:19:00, 249856 bytes
Driver: C:WINDOWSSystem32nvwrscs.dll, 6.14.0010.4403 (Czech), 5/2/2003 15:19:00, 159744 bytes
Driver: C:WINDOWSSystem32nvrsda.dll, 6.14.0010.4403 (Danish), 5/2/2003 15:19:00, 258048 bytes
Driver: C:WINDOWSSystem32nvwrsda.dll, 6.14.0010.4403 (Danish), 5/2/2003 15:19:00, 159744 bytes
Driver: C:WINDOWSSystem32nvrsde.dll, 6.14.0010.4403 (German), 5/2/2003 15:19:00, 266240 bytes
Driver: C:WINDOWSSystem32nvwrsde.dll, 6.14.0010.4403 (German), 5/2/2003 15:19:00, 176128 bytes
Driver: C:WINDOWSSystem32nvrsel.dll, 6.14.0010.4403 (Greek), 5/2/2003 15:19:00, 253952 bytes
Driver: C:WINDOWSSystem32nvwrsel.dll, 6.14.0010.4403 (Greek), 5/2/2003 15:19:00, 184320 bytes
Driver: C:WINDOWSSystem32nvrseng.dll, 6.14.0010.4403 (English), 5/2/2003 15:19:00, 258048 bytes
Driver: C:WINDOWSSystem32nvwrseng.dll, 6.14.0010.4403 (English), 5/2/2003 15:19:00, 147456 bytes
Driver: C:WINDOWSSystem32nvrses.dll, 6.14.0010.4403 (Spanish), 5/2/2003 15:19:00, 258048 bytes
Driver: C:WINDOWSSystem32nvwrses.dll, 6.14.0010.4403 (Spanish), 5/2/2003 15:19:00, 176128 bytes
Driver: C:WINDOWSSystem32nvrsesm.dll, 6.14.0010.4403 (Spanish), 5/2/2003 15:19:00, 282624 bytes
Driver: C:WINDOWSSystem32nvwrsesm.dll, 6.14.0010.4403 (Spanish), 5/2/2003 15:19:00, 147456 bytes
Driver: C:WINDOWSSystem32nvrsfi.dll, 6.14.0010.4403 (Finnish), 5/2/2003 15:19:00, 249856 bytes
Driver: C:WINDOWSSystem32nvwrsfi.dll, 6.14.0010.4403 (Finnish), 5/2/2003 15:19:00, 163840 bytes
Driver: C:WINDOWSSystem32nvrsfr.dll, 6.14.0010.4403 (French), 5/2/2003 15:19:00, 266240 bytes
Driver: C:WINDOWSSystem32nvwrsfr.dll, 6.14.0010.4403 (French), 5/2/2003 15:19:00, 172032 bytes
Driver: C:WINDOWSSystem32nvrshe.dll, 6.14.0010.4403 (Hebrew), 5/2/2003 15:19:00, 3391488 bytes
Driver: C:WINDOWSSystem32nvwrshe.dll, 6.14.0010.4403 (Hebrew), 5/2/2003 15:19:00, 139264 bytes
Driver: C:WINDOWSSystem32nvrshu.dll, 6.14.0010.4403 (Hungarian), 5/2/2003 15:19:00, 245760 bytes
Driver: C:WINDOWSSystem32nvwrshu.dll, 6.14.0010.4403 (Hungarian), 5/2/2003 15:19:00, 167936 bytes
Driver: C:WINDOWSSystem32nvrsit.dll, 6.14.0010.4403 (Italian), 5/2/2003 15:19:00, 270336 bytes
Driver: C:WINDOWSSystem32nvwrsit.dll, 6.14.0010.4403 (Italian), 5/2/2003 15:19:00, 172032 bytes
Driver: C:WINDOWSSystem32nvrsja.dll, 6.14.0010.4403 (Japanese), 5/2/2003 15:19:00, 3387392 bytes
Driver: C:WINDOWSSystem32nvwrsja.dll, 6.14.0010.4403 (Japanese), 5/2/2003 15:19:00, 106496 bytes
Driver: C:WINDOWSSystem32nvrsko.dll, 6.14.0010.4403 (Korean), 5/2/2003 15:19:00, 3383296 bytes
Driver: C:WINDOWSSystem32nvwrsko.dll, 6.14.0010.4403 (Korean), 5/2/2003 15:19:00, 102400 bytes
Driver: C:WINDOWSSystem32nvrsnl.dll, 6.14.0010.4403 (Dutch), 5/2/2003 15:19:00, 262144 bytes
Driver: C:WINDOWSSystem32nvwrsnl.dll, 6.14.0010.4403 (Dutch), 5/2/2003 15:19:00, 167936 bytes
Driver: C:WINDOWSSystem32nvrsno.dll, 6.14.0010.4403 (Norwegian (Bokmål)), 5/2/2003 15:19:00, 258048 bytes
Driver: C:WINDOWSSystem32nvwrsno.dll, 6.14.0010.4403 (Norwegian (Bokmål)), 5/2/2003 15:19:00, 159744 bytes
Driver: C:WINDOWSSystem32nvrspl.dll, 6.14.0010.4403 (Polish), 5/2/2003 15:19:00, 245760 bytes
Driver: C:WINDOWSSystem32nvwrspl.dll, 6.14.0010.4403 (Polish), 5/2/2003 15:19:00, 163840 bytes
Driver: C:WINDOWSSystem32nvrspt.dll, 6.14.0010.4403 (Portuguese), 5/2/2003 15:19:00, 249856 bytes
Driver: C:WINDOWSSystem32nvwrspt.dll, 6.14.0010.4403 (Portuguese), 5/2/2003 15:19:00, 176128 bytes
Driver: C:WINDOWSSystem32nvrsptb.dll, 6.14.0010.4403 (Portuguese), 5/2/2003 15:19:00, 266240 bytes
Driver: C:WINDOWSSystem32nvwrsptb.dll, 6.14.0010.4403 (Portuguese), 5/2/2003 15:19:00, 172032 bytes
Driver: C:WINDOWSSystem32nvrsru.dll, 6.14.0010.4403 (Russian), 5/2/2003 15:19:00, 262144 bytes
Driver: C:WINDOWSSystem32nvwrsru.dll, 6.14.0010.4403 (Russian), 5/2/2003 15:19:00, 176128 bytes
Driver: C:WINDOWSSystem32nvrssk.dll, 6.14.0010.4403 (Slovak), 5/2/2003 15:19:00, 245760 bytes
Driver: C:WINDOWSSystem32nvwrssk.dll, 6.14.0010.4403 (Slovak), 5/2/2003 15:19:00, 167936 bytes
Driver: C:WINDOWSSystem32nvrssl.dll, 6.14.0010.4403 (Slovenian), 5/2/2003 15:19:00, 253952 bytes
Driver: C:WINDOWSSystem32nvwrssl.dll, 6.14.0010.4403 (Slovenian), 5/2/2003 15:19:00, 155648 bytes
Driver: C:WINDOWSSystem32nvrssv.dll, 6.14.0010.4403 (Swedish), 5/2/2003 15:19:00, 258048 bytes
Driver: C:WINDOWSSystem32nvwrssv.dll, 6.14.0010.4403 (Swedish), 5/2/2003 15:19:00, 159744 bytes
Driver: C:WINDOWSSystem32nvrstr.dll, 6.14.0010.4403 (Turkish), 5/2/2003 15:19:00, 262144 bytes
Driver: C:WINDOWSSystem32nvwrstr.dll, 6.14.0010.4403 (Turkish), 5/2/2003 15:19:00, 163840 bytes
Driver: C:WINDOWSSystem32nvrszhc.dll, 6.14.0010.4403 (Chinese), 5/2/2003 15:19:00, 217088 bytes
Driver: C:WINDOWSSystem32nvwrszhc.dll, 6.14.0010.4403 (Chinese), 5/2/2003 15:19:00, 86016 bytes
Driver: C:WINDOWSSystem32nvrszht.dll, 6.14.0010.4403 (Chinese), 5/2/2003 15:19:00, 217088 bytes
Driver: C:WINDOWSSystem32nvwrszht.dll, 6.14.0010.4403 (Chinese), 5/2/2003 15:19:00, 86016 bytes
Driver: C:WINDOWShelpnvcpar.hlp, 5/2/2003 15:19:00, 77671 bytes
Driver: C:WINDOWShelpnvwcpar.hlp, 5/2/2003 15:19:00, 22833 bytes
Driver: C:WINDOWShelpnvcpcs.hlp, 5/2/2003 15:19:00, 85508 bytes
Driver: C:WINDOWShelpnvwcpcs.hlp, 5/2/2003 15:19:00, 24777 bytes
Driver: C:WINDOWShelpnvcpda.hlp, 5/2/2003 15:19:00, 54358 bytes
Driver: C:WINDOWShelpnvwcpda.hlp, 5/2/2003 15:19:00, 23275 bytes
Driver: C:WINDOWShelpnvcpde.hlp, 5/2/2003 15:19:00, 56415 bytes
Driver: C:WINDOWShelpnvwcpde.hlp, 5/2/2003 15:19:00, 24155 bytes
Driver: C:WINDOWShelpnvcpel.hlp, 5/2/2003 15:19:00, 96427 bytes
Driver: C:WINDOWShelpnvwcpel.hlp, 5/2/2003 15:19:00, 24017 bytes
Driver: C:WINDOWShelpnvcpeng.hlp, 5/2/2003 15:19:00, 50690 bytes
Driver: C:WINDOWShelpnvwcpeng.hlp, 5/2/2003 15:19:00, 20453 bytes
Driver: C:WINDOWShelpnvcpes.hlp, 5/2/2003 15:19:00, 52949 bytes
Driver: C:WINDOWShelpnvwcpes.hlp, 5/2/2003 15:19:00, 21880 bytes
Driver: C:WINDOWShelpnvcpesm.hlp, 5/2/2003 15:19:00, 53497 bytes
Driver: C:WINDOWShelpnvwcpesm.hlp, 5/2/2003 15:19:00, 21907 bytes
Driver: C:WINDOWShelpnvcpfi.hlp, 5/2/2003 15:19:00, 55946 bytes
Driver: C:WINDOWShelpnvwcpfi.hlp, 5/2/2003 15:19:00, 23322 bytes
Driver: C:WINDOWShelpnvcpfr.hlp, 5/2/2003 15:19:00, 54995 bytes
Driver: C:WINDOWShelpnvwcpfr.hlp, 5/2/2003 15:19:00, 23262 bytes
Driver: C:WINDOWShelpnvcphe.hlp, 5/2/2003 15:19:00, 78982 bytes
Driver: C:WINDOWShelpnvwcphe.hlp, 5/2/2003 15:19:00, 23449 bytes
Driver: C:WINDOWShelpnvcphu.hlp, 5/2/2003 15:19:00, 58809 bytes
Driver: C:WINDOWShelpnvwcphu.hlp, 5/2/2003 15:19:00, 26819 bytes
Driver: C:WINDOWShelpnvcpit.hlp, 5/2/2003 15:19:00, 53182 bytes
Driver: C:WINDOWShelpnvwcpit.hlp, 5/2/2003 15:19:00, 23297 bytes
Driver: C:WINDOWShelpnvcpja.hlp, 5/2/2003 15:19:00, 80143 bytes
Driver: C:WINDOWShelpnvwcpja.hlp, 5/2/2003 15:19:00, 32944 bytes
Driver: C:WINDOWShelpnvcpko.hlp, 5/2/2003 15:19:00, 87057 bytes
Driver: C:WINDOWShelpnvwcpko.hlp, 5/2/2003 15:19:00, 33084 bytes
Driver: C:WINDOWShelpnvcpnl.hlp, 5/2/2003 15:19:00, 53770 bytes
Driver: C:WINDOWShelpnvwcpnl.hlp, 5/2/2003 15:19:00, 23097 bytes
Driver: C:WINDOWShelpnvcpno.hlp, 5/2/2003 15:19:00, 54358 bytes
Driver: C:WINDOWShelpnvwcpno.hlp, 5/2/2003 15:19:00, 22919 bytes
Driver: C:WINDOWShelpnvcppl.hlp, 5/2/2003 15:19:00, 57780 bytes
Driver: C:WINDOWShelpnvwcppl.hlp, 5/2/2003 15:19:00, 23937 bytes
Driver: C:WINDOWShelpnvcppt.hlp, 5/2/2003 15:19:00, 53072 bytes
Driver: C:WINDOWShelpnvwcppt.hlp, 5/2/2003 15:19:00, 23662 bytes
Driver: C:WINDOWShelpnvcpptb.hlp, 5/2/2003 15:19:00, 53767 bytes
Driver: C:WINDOWShelpnvwcpptb.hlp, 5/2/2003 15:19:00, 23494 bytes
Driver: C:WINDOWShelpnvcpru.hlp, 5/2/2003 15:19:00, 57406 bytes
Driver: C:WINDOWShelpnvwcpru.hlp, 5/2/2003 15:19:00, 24149 bytes
Driver: C:WINDOWShelpnvcpsk.hlp, 5/2/2003 15:19:00, 86673 bytes
Driver: C:WINDOWShelpnvwcpsk.hlp, 5/2/2003 15:19:00, 24389 bytes
Driver: C:WINDOWShelpnvcpsl.hlp, 5/2/2003 15:19:00, 55756 bytes
Driver: C:WINDOWShelpnvwcpsl.hlp, 5/2/2003 15:19:00, 23455 bytes
Driver: C:WINDOWShelpnvcpsv.hlp, 5/2/2003 15:19:00, 54457 bytes
Driver: C:WINDOWShelpnvwcpsv.hlp, 5/2/2003 15:19:00, 23253 bytes
Driver: C:WINDOWShelpnvcpth.hlp, 5/2/2003 15:19:00, 72751 bytes
Driver: C:WINDOWShelpnvwcpth.hlp, 5/2/2003 15:19:00, 33425 bytes
Driver: C:WINDOWShelpnvcptr.hlp, 5/2/2003 15:19:00, 60678 bytes
Driver: C:WINDOWShelpnvwcptr.hlp, 5/2/2003 15:19:00, 25634 bytes
Driver: C:WINDOWShelpnvcpzhc.hlp, 5/2/2003 15:19:00, 65219 bytes
Driver: C:WINDOWShelpnvwcpzhc.hlp, 5/2/2003 15:19:00, 26129 bytes
Driver: C:WINDOWShelpnvcpzht.hlp, 5/2/2003 15:19:00, 64921 bytes
Driver: C:WINDOWShelpnvwcpzht.hlp, 5/2/2003 15:19:00, 26920 bytes
DirectX Components
ddraw.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 284160 bytes
ddrawex.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 24064 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 10/9/2001 12:00:00 10496 bytes
d3d8.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1177600 bytes
d3d8thk.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 8192 bytes
d3d9.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1634304 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 10/9/2001 12:00:00 436224 bytes
d3dim700.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 797184 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 10/9/2001 12:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 10/9/2001 12:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 10/9/2001 12:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 10/9/2001 12:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 Norwegian (Bokmål) Final Retail 10/9/2001 12:00:00 33040 bytes
dplayx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 217600 bytes
dpmodemx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 77824 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 10/9/2001 12:00:00 42768 bytes
dpwsockx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 76800 bytes
dplaysvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 28160 bytes
dpnsvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 16896 bytes
dpnet.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 723968 bytes
dpnlobby.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpnaddr.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpvoice.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 381952 bytes
dpvsetup.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 80896 bytes
dpvvox.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 112128 bytes
dpvacm.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 19968 bytes
dpnhpast.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 32768 bytes
dpnhupnp.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 68096 bytes
dpserial.dll: 5.00.2134.0001 Norwegian (Bokmål) Final Retail 10/9/2001 12:00:00 53520 bytes
dinput.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:40:00 648704 bytes
dinput8.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:40:00 667648 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 10/9/2001 12:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 467968 bytes
joy.cpl: 5.01.2600.1106 English Final Retail 8/29/2002 03:41:00 208896 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 223232 bytes
pid.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:41:00 31744 bytes
gameenum.sys: 5.01.2600.0000 English Final Retail 8/17/2001 22:02:32 9728 bytes
dsound.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 355328 bytes
dsound3d.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1294336 bytes
dswave.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18432 bytes
dsdmo.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 186880 bytes
dsdmoprp.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 491520 bytes
dmusic.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 116736 bytes
dmband.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 27136 bytes
dmcompos.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 58368 bytes
dmime.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 171520 bytes
dmloader.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 33280 bytes
dmstyle.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 98816 bytes
dmsynth.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 100864 bytes
dmscript.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 76800 bytes
dx7vb.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 602624 bytes
dx8vb.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1189888 bytes
dxdiagn.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1675264 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 10/9/2001 12:00:00 924432 bytes
mfc42.dll: 6.00.8665.0000 English Beta Retail 10/9/2001 12:00:00 995383 bytes
wsock32.dll: 5.01.2600.0000 Norwegian (Bokmål) Final Retail 10/9/2001 12:00:00 22528 bytes
amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 64512 bytes
devenum.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 132608 bytes
dxmasf.dll: 6.04.0009.1120 Norwegian (Bokmål) Final Retail 10/9/2001 12:00:00 498205 bytes
mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 34304 bytes
mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 136192 bytes
msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 13312 bytes
encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18944 bytes
qasf.dll: 9.00.0000.2980 English Final Retail 12/11/2002 17:34:40 241664 bytes
qcap.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 257024 bytes
qdv.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 311808 bytes
qdvd.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 449024 bytes
qedit.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 1798144 bytes
qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 733184 bytes
quartz.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 1962496 bytes
strmdll.dll: 4.01.0000.3925 Norwegian (Bokmål) Final Retail 10/9/2001 12:00:00 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 10/9/2001 12:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 10/9/2001 12:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 10/9/2001 12:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 10/9/2001 12:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 10/9/2001 12:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 10/9/2001 12:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 10/9/2001 12:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 10/9/2001 12:00:00 154624 bytes
mswebdvd.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 324096 bytes
msdvdopt.dll: 5.01.2600.0000 Norwegian (Bokmål) Final Retail 10/9/2001 12:00:00 74240 bytes
ks.sys: 5.03.0000.0900 Norwegian (Nynorsk) Final Retail 12/12/2002 00:14:32 130304 bytes
ksproxy.ax: 5.03.0000.0900 Norwegian (Nynorsk) Final Retail 12/12/2002 00:14:32 117248 bytes
ksuser.dll: 5.03.0000.0900 Norwegian (Nynorsk) Final Retail 12/12/2002 00:14:32 4096 bytes
stream.sys: 5.03.0000.0900 Norwegian (Nynorsk) Final Retail 12/12/2002 00:14:32 45696 bytes
mspclock.sys: 5.03.0000.0900 Norwegian (Nynorsk) Final Retail 12/12/2002 00:14:32 5248 bytes
mspqm.sys: 5.01.2600.0000 Norwegian (Nynorsk) Final Retail 8/23/2001 05:00:00 4608 bytes
mskssrv.sys: 5.03.0000.0900 Norwegian (Nynorsk) Final Retail 12/12/2002 00:14:32 7424 bytes
swenum.sys: 5.03.0000.0900 Norwegian (Nynorsk) Final Retail 12/12/2002 00:14:32 4096 bytes
mstee.sys: 5.03.0000.0900 Norwegian (Nynorsk) Final Retail 12/12/2002 00:14:32 5504 bytes
bdaplgin.ax: 5.03.0000.0900 Norwegian (Nynorsk) Final Retail 2/17/2003 10:16:26 16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:26 52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 30208 bytes
ipsink.ax: 5.03.0000.0900 Norwegian (Nynorsk) Final Retail 2/17/2003 10:16:26 14848 bytes
mpeg2data.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:26 57856 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 10112 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 14976 bytes
msvidctl.dll: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 1230336 bytes
slip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 16384 bytes
vbisurf.ax: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:30 27648 bytes
msyuv.dll: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 16896 bytes
kstvtune.ax: 5.03.0001.0902 English Final Retail 6/4/2003 10:30:32 274432 bytes
ksxbar.ax: 5.03.0001.0902 English Final Retail 6/4/2003 09:18:28 39424 bytes
kswdmcap.ax: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:32 226304 bytes
vfwwdm32.dll: 5.01.2600.0000 Norwegian (Bokmål) Final Retail 10/6/2001 14:02:38 49664 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:32 18688 bytes
wstdecod.dll: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:32 47104 bytes
msdv.sys: 5.01.2600.0000 English Final Retail 2/17/2003 10:21:50 52096 bytes
DirectShow Filters
WDM Streaming VBI Codecs:
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.0000.0900
CC Decoder,0x00200000,2,1,,5.03.0000.0900
WST Codec,0x00200000,1,1,,5.03.0000.0900
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
SonyCDSrcWriter,0x00200000,1,0,SonyCDSrcWriter.ax,3.00.0003.3110
ffdshow MPEG-4 Video Decoder,0x00800002,1,1,ffdshow.ax,
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.0001.0902
OpenMG Async. File Source,0x00400000,0,1,OmgAfs.ax,3.00.0003.3110
DV Muxer,0x00400000,0,0,qdv.dll,6.05.0001.0900
Sony Audio CD Source Filter,0x00600000,0,1,cdsrc.ax,3.00.0003.3110
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.0001.0902
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.2980
SAL Output Converter,0x00200000,1,0,saloconv.ax,3.00.0003.3110
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.0001.0902
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.0001.0902
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4477
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
DivX for Blizzard Decoder Filter,0x00800000,1,1,blizzard.ax,5.00.0002.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4477
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.0001.0902
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.0001.0900
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.0001.0902
File Source (Netshow URL),0x00400000,0,1,dxmasf.dll,6.04.0009.1120
DV Splitter,0x00600000,1,2,qdv.dll,6.05.0001.0900
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4477
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.0001.0902
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Still Image Capture,0x00200000,1,1,CTStillCapture.ax,1.00.0001.0002
Windows Media Multiplexer,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASX file Parser,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASX v.2 file Parser,0x00600000,1,0,dxmasf.dll,6.04.0009.1120
NSC file Parser,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.0001.0902
Windows Media source filter,0x00600000,0,2,dxmasf.dll,6.04.0009.1120
Video Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.0001.0902
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.0001.0902
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.0000.0900
Video Renderer,0x00400000,1,0,quartz.dll,6.05.0001.0902
OpenMG Audio Decrypt Splitter,0x00600000,1,1,omgdec.ax,3.00.0003.3110
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mp4sds32.ax,8.00.0000.0344
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.2980
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.0000.0900
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4477
OpenMG OmgSource Filter,0x00600000,0,1,omgsrc.ax,3.00.0003.3110
File writer,0x00200000,1,0,qcap.dll,6.05.0001.0900
Creative Snapshot In Place,0x00200000,1,1,P1001Dex.ax,1.50.0000.0020
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.0001.0902
GraphicEq,0x00200000,1,1,GraphicEq.ax,1.00.0000.7120
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.0001.0902
SonyMSAConverter,0x00200000,1,0,SonyMSAConverter3.ax,3.00.0003.3110
AVI Draw,0x00600064,9,1,quartz.dll,6.05.0001.0902
Sony IpScope2,0x00200000,1,1,IpScope2.ax,2.02.0000.8090
Creative Video Decoder (EP),0x00600000,1,2,P1001Dex.ax,1.50.0000.0020
.RAM file Parser,0x00600000,1,0,dxmasf.dll,6.04.0009.1120
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.0001.0900
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,dxmasf.dll,6.04.0009.1120
ASF DIB Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASF ACM Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASF ICM Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASF URL Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASF JPEG Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASF DJPEG Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
ASF embedded stuff Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1120
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.0001.0900
Null Renderer,0x00200000,1,0,qedit.dll,6.05.0001.0900
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.0001.0900
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
WMP CD Filter,0x00600000,0,1,wmpcd.dll,8.00.0000.4477
Smart Tee,0x00200000,1,2,qcap.dll,6.05.0001.0900
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.0001.0902
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.0001.0902
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.0001.0902
Wave Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
File stream renderer,0x00400000,1,1,quartz.dll,6.05.0001.0902
XML Playlist,0x00400000,1,0,dxmasf.dll,6.04.0009.1120
AVI Mux,0x00200000,1,0,qcap.dll,6.05.0001.0900
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.0001.0902
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.0001.0902
File Source (URL),0x00400000,0,1,quartz.dll,6.05.0001.0902
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.0001.0900
SAL Input Converter,0x00200000,0,1,saliconv.ax,3.00.0003.3110
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.0001.0900
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.0001.0902
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.0000.0900
WDM Streaming Data Transforms:
Fjerning av akustisk ekko for Microsoft Kernel,0x00200000,2,2,,5.03.0000.0900
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DLS-synthesizer,0x00200000,1,1,,5.03.0000.0900
DRM-lyddekoder for Microsoft Kernel,0x00200000,1,1,,5.03.0000.0900
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.0001.0900
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.0001.0902
Aox Video Decompressor,0x00200000,1,1,qcap.dll,6.05.0001.0900
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo® Video R3.2,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.0001.0900
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft MPEG-4 Video Codec V2,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft MPEG-4 Video Codec V1,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.0001.0900
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.0001.0902
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902
ACELP.net,0x00200000,1,1,quartz.dll,6.05.0001.0902
DSP Group TrueSpeech,0x00200000,1,1,quartz.dll,6.05.0001.0902
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.0001.0902
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.0001.0902
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.0001.0902
ATRAC3,0x00200000,1,1,quartz.dll,6.05.0001.0902
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.0001.0902
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.0001.0902
Audio Capture Sources:
Digitallydenhet for SB Live!,0x00200000,0,0,qcap.dll,6.05.0001.0900
Midi Renderers:
A: SB Live! MIDI-synthesizer,0x00200000,1,0,quartz.dll,6.05.0001.0902
B: SB Live! MIDI-synthesizer,0x00200000,1,0,quartz.dll,6.05.0001.0902
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.0001.0902
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.0001.0902
SB Live! MIDI UART,0x00200000,1,0,quartz.dll,6.05.0001.0902
WDM Streaming Capture Devices:
,0x00000000,0,0,,
,0x00000000,0,0,,
SB Live! MIDI UART,0x00200000,3,2,,5.03.0000.0900
Digitallydenhet for SB Live!,0x00200000,3,2,,5.03.0000.0900
WDM Streaming Rendering Devices:
A: SB Live! MIDI-synthesizer,0x00200000,1,1,,5.03.0000.0900
B: SB Live! MIDI-synthesizer,0x00200000,1,1,,5.03.0000.0900
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,5.03.0000.0900
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Video Capture Sources:
Creative WebCam (VFW),0x00200000,0,0,qcap.dll,6.05.0001.0900
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.0001.0900
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.0001.0900
WDM Streaming Mixer Devices:
Microsoft Kernel Wave lydmikser,0x00200000,2,2,,5.03.0000.0900
WDM Streaming Communication Transforms:
Audio Renderers:
Digitallydenhet for SB Live!,0x00200000,1,0,quartz.dll,6.05.0001.0902
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.0001.0902
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.0001.0902
DirectSound: Digitallydenhet for SB Live!,0x00200000,1,0,quartz.dll,6.05.0001.0902
WDM Streaming System Devices:
A: SB Live! MIDI-synthesizer,0x00200000,11,2,,5.03.0000.0900
Digitallydenhet for SB Live!,0x00200000,13,2,,5.03.0000.0900
BDA Receiver Component:
BDA Slip De-Framer,0x00600000,1,1,,5.03.0000.0900
d3d, altså feil med skjermort... vil gjette driver.
last ned nyeste detonator driver fra http://www.nvidia.com og prøv på nytt. Evt legg inn directX på nytt.
Har selv GF4Ti4200, og SL funker fint på maskinen min (har de nyeste detonator driverne)
har ikke testa på wxp enda, men tror det skal funke der uten noen store oppdateringer (sp1 og sånn) veit at det funka for brodern, men han har et annet skjermort da, så man veit jo aldri :shrug:
