Cool and quiet
Her er hk og cpu.
AMD Athlon 64 X2 6000+
ASUSTeK Computer INC. M2N-E SLI (Socket AM2 )
Jeg har kjørt Vista på denne maskinen og da virket det.
Men etter at jeg gikk over til XP står den på fullt hele tiden.
Har hørt at det ble slik etter SP3.
Gikk hit og hentet driver:
http://www.userdrivers.com/Motherboard/AMD-Cool-n-Quiet-Driver-2-18-03-for-Windows-XP/download/
Virket ikke da heller
Som sagt.
For Vista og senere trenger man det ikke , mens man må for XP og driver
Jeg synes du skal laste den ned fra Asus tilfelle det er noe knytning til ditt M2N-E brikkesett.
Se :
http://support.asus.com/faq/detail.aspx?SLanguage=en&p=1&m=M2N-E%20SLI&s=24&hashedid=NJ8fkR6ufRM9XvFC&os=&no=08071BB2-C5AF-03A6-AE60-BB8CC7A44FF9
I would like to enable AMD Cool'n'Quiet Technology without knowing how.
Can you please kindly advice on how to do so?
Solution
Please kindly follow the instructions below to enable AMD Cool'n'Quiet Technology:
1. Enter CMOS setup screen, and set "Advanced-->CPU Configuration-->AMD Cool'n'Quiet Technology" to [Enabled].
2. Windows XP users, please install the driver from the link below:
http://dlsvr04.asus.com/pub/ASUS/mb/socketAM2/M2N8-VMX/AMD.zip
Driver installation is not required for VISTA users.
3. Set "Power Scheme" to "Max Battery" or "Minimal Power Management".
4. Done
Du må ha riktig processor driver for xp ja.
Enable i bios.
Og , du må enable i control panel - riktig - power profil
Bruk pdf hjelpefilen fra AMD herfra
http://www.amd.com/US/PRODUCTS/TECHNOLOGIES/COOL-N-QUIET/Pages/cool-n-quiet.aspx
Cool'n'Quiet Technology Installation Guide for AMD Athlon processor-based systems
This document is a step-by-step guide to enable Cool'n'Quiet Technology functionality on an AMD Athlon processor-based system. It outlines the correct components to be used, as well as instructions for obtaining and installing the correct driver software.Download the Cool'n'Quiet Technology Installation Guide PDF
Endret av syar2003
