HL2 LEAKED
Gjest Slettet-80wCWpIM
his is a bunch of .cpp/.h files. You cant compile them or make anything with them. At best you can learn from it and see how they programmed certain parts of the game. I dont know or think the full source is included, as gunhero said, the files are protected. Meaning they arent on that copy, they are stored on a protected server that you connect to when you compile.
You cant place dummy files in place of the models etc cus it just wont work. Especially models, being that most of them contain animation information and if it doesnt match the game it wont work.
This is a lot of stuff, and it looks too good to be fake. Its a lot, a LOT of files, about 2500 of .cpp and 2500 .h files. There is a rar floating around, and of course asking for the file name or asking for it will result in a ban.
Plain and simple, you cant do anything with this code unless you are a programmer. Will it help people cheat? I dont know, I dont know if the core engine is included.
Dette har ingenting med Hardware å gjøre.
Posten stenges.
En klok man skrev:
Tråder skal ha et beskrivende emnefelt. Om du lurer på noe om hovedkortet ditt så skal emnefeltet være "Problemer med Epox5k3+ hovedkortet mitt". Tråden skal også være postet i rett kategori. Emnfefelt med kun store bokstaver, overdrevent bruk av !? og lite beskrivende vil bli stengt. Eksempel på dårlig emnefelt er "HJEEEEEELP!!!!HVA GJØR JEG NÅ????????".
Gjest
