sprengt CPU `?
felge
Not electrically conductive.
Arctic Silver 3 was formulated to conduct heat, not electricity. It is only electrically conductive in a thin layer under extreme compression.
(While much safer than electrically conductive silver and copper greases, Arctic Silver 3 should be kept away from electrical traces, pins, and leads. While it is not electrically conductive, the compound is slightly capacitive and could potentially cause problems if it bridges two close-proximity electrical paths.)
Men jeg ville ha vert på den sikre siden, så prøv å unngå det :)
