Mumriken Skrevet 29. april 2018 Del Skrevet 29. april 2018 Da var 2700X i hus. Ryzen 2700X stock - 3400CL16 - W10 64bit Singel:181 Multi:1819 Lik 5960x overklokket Poste resultat når du får jazzet den opp litt Lenke til kommentar
kla3torsk1 Skrevet 3. november 2018 Del Skrevet 3. november 2018 7940X @ 4.7ghz på alle kjerner Lenke til kommentar
kla3torsk1 Skrevet 25. november 2018 Del Skrevet 25. november 2018 (endret) I9 - 7940X @ 4900mhz (1.385v-core) fikk opp scoren ganske mye fra sist ved å leke litt med Meshe`n Endret 25. november 2018 av kla3torsk1 Lenke til kommentar
mer-hw Skrevet 6. mars 2019 Del Skrevet 6. mars 2019 Da har MAXON kommet med en ny og oppdatert programvare. Cinebench R20 Benchmark Maxon Tuesday unveiled its Cinebench R20 benchmark designed to test CPU performance at photorealistic rendering using the company's Cinema 4D R20 technology. The benchmark runs on any PC with at least 4 GB of memory and SSE3 instruction-set support, although it can scale across any number of cores, memory, and supports exotic new instruction-sets such as AVX2. Maxon describes Cinebench R20 as using four times the memory, and eight times the CPU computational power as Cinebench R15. The benchmark implements Intel Embree ray-tracing engine. Maxon is distributing Cinebench R20 exclusively through the Microsoft Store on the Windows platform.Unlike its predecessor, Cinebench R20 lacks a GPU test. The CPU test scales by the number of CPU cores and SMT units available. It consists of a tiled rendering of a studio apartment living room scene by Render Baron, which includes ray-traced elements, high resolution textures, illumination, and reflections. The number of logical processors available determines the number of rendering instances. The benchmark does indeed have a large memory footprint, and rewards HTT or SMT and high clock-speeds, as our own quick test shows. A 4-core/8-thread Core i7-7700K beats our Core i5-9400F 6-core/6-thread processor. https://www.techpowerup.com/253317/maxon-releases-cinebench-r20-benchmark Ny tråd eller oppdatering av første post og overskrift Nizzen? Lenke til kommentar
Nizzen Skrevet 6. mars 2019 Forfatter Del Skrevet 6. mars 2019 Da har MAXON kommet med en ny og oppdatert programvare. Cinebench R20 Benchmark https://www.techpowerup.com/253317/maxon-releases-cinebench-r20-benchmark Ny tråd eller oppdatering av første post og overskrift Nizzen? Ny tråd laget https://www.diskusjon.no/index.php?showtopic=1839892 Lenke til kommentar
kla3torsk1 Skrevet 6. mars 2019 Del Skrevet 6. mars 2019 Testet litt Cinebench R15 med 10 år gamle Xeon`s, 2stk Xeon X5675 @ 4.31ghz, ganske fornøyd med den scoren, men er mere i de, må bare finne frem litt mere mot! Lenke til kommentar
mer-hw Skrevet 18. november 2019 Del Skrevet 18. november 2019 Ryzen 3600 stock 3600 CL16 stock. Kun valgt xmp profil på minne. Ingen PBO eller annen biostukling. Kjøling H110i. AGESA versjon 1.0.0.3 da Asrock ikke har oppdatert B450 Pro4 kortene med siste versjon. Lenke til kommentar
