Den store Grand Theft Auto Online tråden.
Uoffisiell info om heist (spoilere!!):
Heist kart
Koder:
"char":0,"charcon":0,"cmpts":0,"cshr":80000,"ctsc":0,"dec":["Get a team together and break into the vault of Vinewood's Maze"," Bank and steal the gold held there. You'll need a hacker, a co","uple of crack shots and your best getaway driver. You'll also n","eed to get some wheels which can outrun the cops."],"endtype":0,"gpmn":0,"ivm":-1,"ltm":261632,"menubs":442,"min":4,"minNu":4,"mtnum":1,"musx":0,"nm":"Ornate Bank Heist","num":6,"optbs":16,"ownerid":"ChrisMissionsRSN","photo":true,"rad":0.0,"rank":60,"start":{"x":1150.559326,"y":-1269.708374,"z":33.627712},"subtype":1,"time":0,"tnum":4,"trel":66125823,"type":0,"vcpr":{"x":2.729982,"y":5E-06,"z":39.458408},"xpr":1140}
"txt0":["Go to the ~y~bank.~s~","Go to the ~y~area behind the teller's line.~s~","Go to the ~g~terminal.~s~","Go to the ~g~terminal.~s~","Steal the ~g~gold.~s~"],"txt1":["Go to the ~y~bank.~s~","Hold the cops back at the ~y~bank enterance.~s~","Steal the ~g~gold.~s~"],"txt10":["","","Hack the ~g~terminal.~s~","Hack the ~g~terminal.~s~","Deliver the ~g~gold~s~ to Lester's ~y~warehouse.~s~"],"txt11":["","Keep the bank ~y~enterance~s~ clear of cops.","Deliver the ~g~gold~s~ to Lester's ~y~warehouse.~s~"],"txt12":["","Keep the ~y~enterance~s~ clear of cops.","Deliver the ~g~gold~s~ to Lester's ~y~warehouse.~s~"],"txt13":["","Hack the ~g~terminal.~s~","","","Deliver the ~g~gold~s~ to Lester's ~y~warehouse.~s~"],"txt2":["Go to the ~y~bank.~s~","Hold back the cops at the ~y~enterance.~s~","Steal the ~g~gold.~s~"],"txt20":["","","Defend your teammate while they hack the ~g~terminal.~s~","Defend your teammate while they hack the ~g~terminal.~s~","Help deliver the ~g~gold~s~ to the ~y~warehouse.~s~"],"txt21":["","Help your teammate hold the ~y~enterance.~s~","Help deliver the ~g~gold~s~ to Lester's ~y~warehouse.~s~"],"txt22":["","Help your teammate hold the ~y~enterance~s~ of the bank.","Help deliver the ~g~gold~s~ to Lester's ~y~warehouse.~s~"],"txt23":["","Defend your teammate while they hack the ~g~terminal.~s~","Defend your teammate while they hack the ~g~terminal.~s~","","Help deliver the ~g~gold~s~ to Lester's ~y~warehouse.~s~"],"txt3":["Go to the ~y~parking lot.~s~","Go to the ~g~terminal.~s~","Steal the ~b~armored cars.~s~","Wait for your team at the ~y~bank.~s~","Steal the ~g~gold.~s~"],"txt30":["Bank","Teller's Line","Terminal","Terminal","Gold"],"txt31":["Bank","Bank enterance","Gold"],"txt32":["Bank","Bank Enterance","Gold"],"txt33":["Parking Lot","Terminal","Armored Cars","Bank","Gold"],"txt40":["the bank","the teller's line","the terminal","the terminal","the gold"],"txt41":["the bank","the bank enterance","the gold"],"txt42":["the bank","the bank enterance","the gold"],"txt43":["parking lot","the terminal","a armored car","the bank","the gold"]
cashr = Cash
xpr = RP
min = Min Players For Heist
minNu = Same min
num = Max Players For Heist
ownerid = Heist Owner
rank = Required Rank For Heist
start = Coordinates For Start Location
80 000$ som blir delt på 4-6 personer, altså mellom 20 000$-13 333$ på et ran. Ser også ut som det er kun er 1140 RP, men håper virkelig R* øker RP og penger.
"Get a team together and break into the vault of Vinewood's Maze Bank and steal the gold held there. You'll need a hacker, a couple of crack shots and your best getaway driver. You'll also need to get some wheels which can outrun the cops."
Found string: TEAM 1
Found string: TEAM 2
Found string: TEAM 3
Found string: TEAM 4
Found string: Transporters
Found string: Snipers
Found string: Lookouts
Found string: Defenders
Found string: Attackers
Found string: Hackers
Found string: Demolition
Found string: Runner
Found string: Gunmen
Found string: Bodyguards
Found string: Pilots
Found string: Drivers
Found string: SAFE_CRACK
Found string: mini@safe_cracking
Found string: MPSafeCracking
Found string: SAFE_CRACK_SOUNDSET
Found string: SAFE_DOOR_OPEN
Found string: SAFE_DOOR_CLOSE
team 1 = gunmen
team 2 = hackers
team 3 = drivers
team 4 = pilots or bodyguards.
De forskjellige lagene blir sannsynligvis det samme som "snipers" og "gunmen" i "Parking Garage" av Lester
Bilder:
Gjest Slettet+130498
hei, har de fikset problemene med teksturloading på psn utgaven? begynner å få litt gta abstinenser, men ser jo ikke ut som R* vil slippe det på de andre konsollene eller pc med det aller første...
