Problem med og melde inn en XP Pro klient i NT4 domene
SteinarS
JEg sliter med å få godtatt en XP klient i NT domenet.
Har skrudd av Kerberos (sikre kanaldata) i lokale sikkerthetsinnstillinger.
Serveren som står der jeg holder til er en BDC, og vi har WAN kopling til PDC`en som står i en annen by.
Får pinget gjennom nettet, noen som har tips?
Noen som har lyst til å skrive en kort (gjerne lang) intro til domene? Har ikke skjønt dette enda...
Being a Domain member:
When you are a domain member, the domain priviledges take precedence over the workstation priviledges. You log into the domain and the domain sets up all the variables for you. The domain sets up all your network connections, whereas on a workstation you would have to supply / map passwords for all resources across a network, and therefore must be mapped on each server accordingly (each must have your account / group priviledges).
The domain could set up your email account to be saved / accessed on the domain server, your wallpaper would be saved on the domain server, your documents would be saved on the domain server, your bookmarks would be saved on the domain server.
If you as a domain *member* accessed your account from another machine, all your data is there. Whereas if you are merley a workstation *accessing* the domain, all your files can only be accessed on your workstation.
Accessing a domain:
As a workstation *accessing* a domain you would have to supply / map passwords for all resources accross a network, and therefore must be mapped on each server accordingly (each must have your account / group priviledges). As mentioned before, as a workstation all your files can only be accessed on your workstation.
Tusen takk for alle savr!
Problemet lot seg løse, fikk tid til å sette med ned fora BDC-serveren og se over konfigurasjonen.
Problemet var nettverksprotokollene, NW Link stod øverst!, så NetBeUi og nederst TCP/IP. Fikk flyttet denne øverst så virket det greit.
mvh
SS
