Real Estate Finance Workassignment.
Just a casual thread to discuss ELE 3736.
Workassignment correct answere:
Problem 1:
i = 8.41
Problem 2:
FV = 68,439
Problem 3:
i = 8.66
Problem 4:
PMT = -32,209
Problem 5:
4,031,749
Problem 6:
Problem 7:
FV = 195,413
Problem 8:
FV = 203,230
Problem 9:
n = 144
Problem 10:
i = 12.96
Havent found a solution to problem 6. (EDIT: solved problem 5.)
Endret av Robstraw
  • 2 uker senere...
  • 4 uker senere...
Assuming you are referring to WA#3?
10. PV= 90', I/Y=6 (P/Y=12), N=120, FV= -20' --> CPT(PMT) = -877.1435
--> PV = 90' x 0.98 = 88,200 --> CPT(I/Y) = 6.39 --> 0.0639
12. Use LB(48) from Problem 11 = 66,892.46187 --> FV = -66,892.46187, PV = 88,200, N = 48, PMT = -877.1435 --> CPT(I/Y) = 6.6448% --> 0.0664
