AMD Radeon R200-tråden - Diskusjon og spekulasjon
Aerow
Jeg har vært plaget av dette når jeg hadde 7950 i CF med 2 broer og 144Hz.
Fikset problemet med å skru ned til 120Hz og skru av HW acceleration for Adobe Flash.
Men du forklarer ikke hva du gjør på PCen når du for rød skjerm. Info er kilden til gode svar tilbake :)
  • 2 uker senere...
AMD Catalyst 14.4 RC1 Linux (14.100.0.0)
Windows versjonen er også ute.http://station-drivers.com/index.php/forum/news/510-amd-catalyst-14-4-rc1
AMD Catalyst 14.4 RC1 (14.100.0.0000)
www2.ati.com/drivers/amd-catalyst-14.4-r....0-windows-apr17.exe
DriverVer=04/15/2014, 14.100.0.0000
Catalyst: 14.4 RC1
CCC: 2014.0415.2225.38428
D3D: 9.14.10.01029
OGL: 6.14.10.12874
OCL: 10.0.1445.5
Mantle: 9.1.10.0013
support.amd.com/en-us/kb-articles/Pages/...st-windows-beta.aspx
Feature Highlights of The AMD Catalyst 14.4 Release Candidate Driver for Windows
Support for the AMD Radeon R9 295X
CrossFire fixes enhancements:
Crysis 3 frame pacing improvements
Far Cry 3 3 and 4 GPU performance improvements at high quality settings, high resolution settings
Anno 2070 Improved CrossFire scaling up to 34%
Titanfall Resolved in game flickering with CrossFire enabled
Metro Last Light Improved Crossfire scaling up to 10%
Eyefinity 3x1 (with three 4K panels) no longer cuts off portions of the application
Stuttering has been improved in certain applications when selecting mid-Eyefinity resolutions with V-sync Enabled
Full support for OpenGL 4.4
OpenGL 4.4 supports the following extensions:
ARB_buffer_storage
ARB_enhanced_layouts
ARB_query_buffer_object
ARB_clear_texture
ARB_texture_mirror_clamp_to_edge
ARB_texture_stencil8
ARB_vertex_type_10f_11f_11f_rev
ARB_multi_bind
ARB_bindless_texture
ARB_spare_texture
ARB_seamless_cubemap_per_texture
ARB_indirect_parameters
ARB_compute_variable_group_size
ARB_shader_draw_parameters
ARB_shader_group_vote
Mantle beta driver improvements:
BattleField 4: Performance slowdown is no longer seen when performing a task switch/Alt-tab
BattleField 4: Fuzzy images when playing in rotated SLS resolution with an A10 Kaveri system
Endret av Nizzen
Sapphire AMD FirePro W9100 16GB GDDR5 PCI-Express 3.0, 6x mini-DisplayPort, 1 x 3D Connector, 512-bit
29.995,-
Jeg syns litt synd på meg som ikke fikk oppleve de eldre dager da man kunne kjøpe et slikt kort og programmere om til gaming-versjon. Mon tro om noen forsøker å programmere dette om til å se ut som et Radeon-kort? Men så var det dette med optimalisering av drivere da...
29.995,-
Det var jo ingen som tok proffkort og softmodda de til Radeon-kort, det var mer populært å gå motsatt vei ;)
Vet inte hur länge det håller eller om det är verklighet, men R9 270X till under tusenlappen..
http://www.prisjakt.no/product.php?p=2266045
Köpte 7850 som var kung på billigt midrange för 2 år sedan, men detta ger en ökning på uppemot 40% mot 7850.
Osäker på crossfire ytelsen, men två av de till under två tusen låter billigt.
De er ikkje på lager. Samme kort som 7950, altså ikkje verdt mere. Brukte 7970 går nå for rundt 1000lappen.
