Gjennomsiktig bakgrunn øker pr klikk
Jeg driver å lager et lite program med noen klikkefunksjoner med gjennomsiktig bakgrunn. Bakgrunnen innholder to knapper, men når man klikker på bakgrunnen, så blir gjennomsiktigheten mørkere. Hva er løsningen på dette, slik at bakgrunnen blir statisk?
import java.awt.BorderLayout;
import java.awt.Color;
import java.awt.Dimension;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import javax.swing.JButton;
import javax.swing.JFrame;
import javax.swing.JLayeredPane;
import javax.swing.JPanel;
import javax.swing.border.Border;
import javax.swing.border.LineBorder;
public class Main {
    private JFrame       frame      = new JFrame();
    private JLayeredPane lpane      = new JLayeredPane();
    private JPanel       bgPanel    = new JPanel();
    private JPanel       fieldPanel = new JPanel();
    private JButton      editButton = new JButton("EN");
    private JButton      addButton  = new JButton("TO");
    private Border border = new LineBorder(Color.WHITE, 0);
    static  Color  bg     = new Color(0,0,0,40);
    public Main() {
    	frame.setBackground(bg);
        frame.setPreferredSize(new Dimension(500, 140));
        frame.setLayout(new BorderLayout());
        frame.add(lpane, BorderLayout.CENTER);
        frame.pack();
        frame.setVisible(true);
        bgPanel.setBounds(0, 0, 500, 140);
        bgPanel.setOpaque(false);
        bgPanel.setLayout(new BorderLayout(0, 0));
        editButton.setForeground (Color.red);
        editButton.setPreferredSize(new Dimension(500, 140));
        editButton.setBounds(0, 0, 60, 40);
        editButton.setBorder(border);
        editButton.addActionListener(new ActionListener() {
          public void actionPerformed(ActionEvent e) {
            System.out.println("Klikk edit");
            editButton.setVisible(false);
            addButton.setVisible(true);
            bgPanel.add(addButton);
        bgPanel.add(editButton);
        addButton.setPreferredSize(new Dimension(500, 140));
        addButton.setBounds(0, 0, 60, 40);
        addButton.setBorder(border);
        addButton.setVisible(false);
        addButton.addActionListener(new ActionListener() {
          public void actionPerformed(ActionEvent e){
            System.out.println("Klikk add");
            editButton.setVisible(true);
        fieldPanel.setBackground(Color.GREEN);
        fieldPanel.setBounds(20, 14, 200, 100);
        fieldPanel.setOpaque(true);
        lpane.setBounds(0, 0, 500, 140);
        lpane.add(bgPanel, new Integer(0), 0);
        lpane.add(fieldPanel, new Integer(1), 0);
    public static void main(String[] args) {
        new Main();
Endret av webbylix
