Reklametvang på Hardware.no
Gjest Slettet-t8fn5F
Nå har de jaggu funnet ut at man må ha javascript aktivert for å lese extra artikler.
En annen finurlighet er at ordet javascript ikke er lovt til å søke på her på forumet.
Fant en enkel vei rundt det også, men fremdeles ikke lovt til å søke på ordet javascript...
Endret av Slettet-t8fn5F
  • Liker 3
Jepp, Jepp, helt idiotisk av de å han inntekt, latterlig gjort :no:
De greide seg fint med den inntekten de hadde før, uten å tvinge brukerne inn på noe annet.
  • Liker 3
Ser ut til at det er denne koden som blokkerer for Adblock nå:
(function($) {
var _0xa465=["\x73\x75\x62\x73\x74\x72\x69\x6E\x67","","\x72\x65\x70\x6C\x61\x63\x65","\x72\x61\x6E\x64\x6F\x6D","\x66\x6C\x6F\x6F\x72","\x3C\x69\x6D\x67\x20\x73\x72\x63\x3D\x22\x2F\x61\x64\x73\x2F\x0D\x61\x64\x2E\x6A\x70\x67\x22\x20\x2F\x3E","\x68\x74\x6D\x6C","\x62\x6F\x64\x79","\x61\x70\x70\x65\x6E\x64\x54\x6F","\x3C","\x20\x73\x74\x79\x6C\x65\x3D\x22\x64\x69\x73\x70\x6C\x61\x79\x3A\x20\x62\x6C\x6F\x63\x6B\x3B\x20\x70\x6F\x73\x69\x74\x69\x6F\x6E\x3A\x20\x61\x62\x73\x6F\x6C\x75\x74\x65\x3B\x20\x74\x6F\x70\x3A\x20\x2D\x31\x30\x30\x30\x30\x70\x78\x3B\x20\x6C\x65\x66\x74\x3A\x20\x2D\x31\x30\x30\x30\x30\x70\x78\x3B\x20\x6F\x70\x61\x63\x69\x74\x79\x3A\x20\x30\x3B\x20\x68\x65\x69\x67\x68\x74\x3A\x20\x32\x30\x70\x78\x3B\x20\x77\x69\x64\x74\x68\x3A\x20\x32\x30\x70\x78\x3B\x22\x20\x69\x64\x3D\x22","\x22\x20\x63\x6C\x61\x73\x73\x3D\x22\x61\x64\x2D\x70\x6C\x61\x63\x65\x68\x6F\x6C\x64\x65\x72\x22\x20\x2F\x3E","\x61\x62\x45","\x69\x73\x68\x49\x64","\x63\x6F\x6E\x66\x69\x67","\x74\x72\x61\x63\x6B\x56\x69\x65\x77","\x69\x73\x68","\x53\x74\x61\x74\x73","\x6C\x6F\x63\x61\x6C\x53\x74\x6F\x72\x61\x67\x65","\x62\x6C\x6F\x63\x6B","\x67\x65\x74\x49\x74\x65\x6D","\x73\x65\x74\x49\x74\x65\x6D","\x61\x63\x63\x65\x73\x73","\x70\x75\x62\x6C\x69\x63","\x77\x69\x64\x74\x68","\x70\x6F\x70\x75\x70","\x61\x64\x42\x6C\x6F\x63\x6B\x4D\x65\x73\x73\x61\x67\x65","\x62\x69\x6E\x64","\x6C\x65\x6E\x67\x74\x68","\x23","\x64\x69\x73\x70\x6C\x61\x79","\x63\x73\x73","\x6E\x6F\x6E\x65","\x20\x69\x6D\x67","\x63\x6C\x61\x73\x73","\x61\x74\x74\x72","\x74\x72\x69\x67\x67\x65\x72","\x72\x65\x6D\x6F\x76\x65","\x69\x65","\x62\x72\x6F\x77\x73\x65\x72","\x70\x75\x73\x68","\x72\x65\x61\x64\x79","\x61\x64\x62\x6C\x6F\x63\x6B","\x75\x6E\x64\x65\x66\x69\x6E\x65\x64","\x6F\x6E\x6C\x6F\x61\x64"];var aa=Math[_0xa465[3]]().toString(36)[_0xa465[2]](/(\d+)/g,_0xa465[1])[_0xa465[0]](2,9),bb=aa+Math[_0xa465[4]](Math[_0xa465[3]]()*1111122);$(_0xa465[9]+aa+_0xa465[10]+bb+_0xa465[11])[_0xa465[8]](_0xa465[7])[_0xa465[6]](_0xa465[5]);$(window)[_0xa465[27]](_0xa465[12],function (){Tek[_0xa465[17]][_0xa465[16]][_0xa465[15]]({req:9,pid:Tek[_0xa465[14]][_0xa465[13]]});if(!!window[_0xa465[18]]){var _0x30b0x3=parseInt(window[_0xa465[18]][_0xa465[20]](_0xa465[19]))+1||1;window[_0xa465[18]][_0xa465[21]](_0xa465[19],_0x30b0x3);if(_0x30b0x3>=2&&article[_0xa465[22]]==_0xa465[23]){Tek[_0xa465[17]][_0xa465[16]][_0xa465[15]]({req:99,pid:Tek[_0xa465[14]][_0xa465[13]]});if(screen[_0xa465[24]]>750){Tek[_0xa465[26]](_0xa465[25]);} ;} ;} ;} );Tek[_0xa465[41]][_0xa465[40]](function (_0x30b0x4){function _0x30b0x5(){if(!_0x30b0x4(_0xa465[29]+bb)[_0xa465[28]]||_0x30b0x4(_0xa465[29]+bb)[_0xa465[31]](_0xa465[30])==_0xa465[32]||_0x30b0x4(_0xa465[29]+bb+_0xa465[33])[_0xa465[31]](_0xa465[30])==_0xa465[32]||_0x30b0x4(_0xa465[29]+bb+_0xa465[33])[_0xa465[35]](_0xa465[34])){_0x30b0x4(window)[_0xa465[36]](_0xa465[12]);} ;_0x30b0x4(_0xa465[29]+bb)[_0xa465[37]]();_0x30b0x4(window)[_0xa465[27]](_0xa465[12],null);} ;if(!Tek[_0xa465[39]][_0xa465[38]]){_0x30b0x5();} else {setTimeout(function (){_0x30b0x5();} ,1000);} ;} );Tek[_0xa465[44]][_0xa465[40]](function (_0x30b0x4){function _0x30b0x6(_0x30b0x7){if((!false&&(window[_0xa465[42]]|| typeof (adblock)==_0xa465[43]))&&!Tek[_0xa465[39]][_0xa465[38]]){_0x30b0x4(window)[_0xa465[36]](_0xa465[12]);} ;} ;_0x30b0x6();} );
})(jQuery);
</script>
Så da må man nok ta i bruk GreaseMonkey eller tilsvarende som fjerner\overstyrer den javascript-koden. Noen som har litt erfaring ang. det? :)
||static.tek.no/js/*
funker grei nok
Endret av preddy
Fint? De gikk faktisk i kraftig underskudd
De fleste årene jeg har vært her inne, så har det gått helt fint uten å tvinge reklame på brukerne. Helt fint....
Men å kjøre en webside i grøfta økonomisk er overhode ingen tryllekunst. Bare len deg godt tilbake å se hvordan dette ender....
  • Liker 4
Om de har gått i underskudd har det jo ikke gått så fint vel, eller?
Man kjører en webside i grøfta når man har mer utgifter enn inntekter, noe de tar grep for å gjøre noe med nå.
Det er vel fordi at den tiden du har vært her så har adblock-andelen gått fra 0% til 50%. Som forklarer ganske betraktelig fall i reklameinntekter.
Jepp. Når inntektene ikke øker, så må utgiftene reduseres. Helt normal logisk tankegang.
Vennligst les det jeg skriver og ikke det du tror jeg skriver.
Jeg skrev at de fleste årene jeg har vært her inne, har det gått helt fint.
  • Liker 3
men det henger jo ikke sammen for som du kan se i økonomi rapporten som ble lagt ut tidligere så var det ingen av tallene som hadde gått ned men heller økt fra fjoråret så du kan ikke si at inntektene har minket på noen måte.
  • Liker 3
Man kan enten øke inntektene eller redusere utgiftene.
Med reklametvang øker de inntektene.
De fleste årene har det gått helt fint ja, men blokkering av reklame tar seg opp...
Inntektene økte med 5,5 millioner fra 2011 til 2012, så nå må utgiftene ned.
Lønnsutgiftene økte med 3 millioner samme perioden.
Haha ja.. Det er jo faktisk helt sykt..
  • Liker 3
