[Løst] Dual 144hz oppsett
NamNam93
Har aldri sett en aktiv dp-> DL-DVI-adapter som ikke trenger ekstra strøm fra USB, og det er ikke noe feedback heller.
Jeg hadde vært skeptisk til den der.
Så en sånn en ville fungert?
http://www.amazon.com/Accell-B087B-003J-UltraAV-miniDisplayPort-Dual-Link/dp/B0030XMREG/ref=sr_1_2?ie=UTF8&qid=1378382132&sr=8-2&keywords=ks30008-131
Bare at den koster skjorta og jeg ville sannsynligvis kommet bedre ut med å oppgradere mitt 7950 skjermkort til et skjermkort med 2 dual link DVI koblinger? :)
The test system used for this review uses an Nvidia Geforce GTX 780 connected to the monitor using the Dual-Link DVI cable provided by AOC. The image provided by DisplayPort is very similar on this monitor and it should also support the maximum (144Hz) refresh rate. Unfortunately that was not the case during our testing on the GTX 780. The following screenshot shows the options that were available to us using a good quality DisplayPort cable (that has been used to run other monitors at 120Hz and 144Hz).
As you can see ‘1080p’ is listed as an HD/SD resolution which is limited to 60Hz. The PC resolutions below this should feature 1920 x 1080 with 100Hz, 120Hz and 144Hz selectable – but that isn’t the case. Creating a custom resolution for 144Hz (we also tried 120Hz and 143Hz) caused a bouncing box to appear on the monitor that read ‘Input not support’. We’ve reported this to AOC and hope that it will be addressed on future monitor revisions. HDMI is only supposed to support 60Hz on this monitor and although you may be able to go higher using a ‘custom resolution’ the bouncing box of doom will thwart your efforts. Just stick with Dual-Link DVI as we did and you’ll be fine.
  • Liker 3
Tusen takk for et svar som svarte på mine spørsmål! :)
Suger litt men da vet jeg at jeg må bruke Dual Link DVI for å nå 144hz på skjermen.
Det virker jo som dette er en bug - du kan evt kontakt AOC og høre om de kommer med en oppdatering e.l.
Når jeg går inn på kontakt område inne på hjemmesiden dems så kommer ikke den modellen opp når jeg skal velge den... Tror jeg må prøve å sende en mail til RMA avdelingen fordi det er den eneste eposten jeg finner.
Jeg har mer tro på den adapteren ja.
Problemet med å oppgradere skjermkortet ditt til et med to DL-DVI-koblinger er at DVI er på vei ut (Intel og AMD skal fjerne støtte for DVI innen 2015,) det er ikke engang sikkert at Maxwell-baserte skjermkort fra Nvidia vil komme med to stykk DL-DVI-porter. Dette er også hovedgrunnen til at jeg fraråder kjøp av 120Hz-monitorer som ikke støtter displayport.
Jeg ser at GTX 700-serien har 2 Dual-Link DVI hvis jeg ikke tar helt feil så det kan ikke være helt ute da :)
Det er ikke ute enda nei, det jeg prøver å fortelle deg er at DVI er på vei ut. Kjøper du et GTX 780 nå vil du få kjørt begge skjermene på 144Hz, men hva skjer når du skal oppgradere skjermkort om et par år? Plutselig får du ikke satt full oppdateringsfrekvens fordi det ikke finnes skjermkort med DVI-porter.
Okei! Takk for infoen, fint å vite noe jeg ikke visste :)
Takk for svar og forslag alle sammen! Jeg kontakter AOC når jeg får tid så ser jeg hva jeg kommer fram til.
Takk igjen :)
Endret av NamNam93
Er mest sannsynlig snakk om hvordan de har laget internkretsene, da løses det ikke med fastvareoppdatering.
Men, DisplayPort støtter native HDMI/DVI- og VGA-signaler, så med en adapter vil nok dette fortsatt fungere?
Men jo, ser poenget ditt. Jeg er veldig irritert over at Asus-skjermen (VG278HR) min ikke har DP-tilkobling (ei heller swivel-mulgihet)...
Husk å fortelle dem at de må begynne å utnytte DisplayPort-teknologien bedre, også internt. :p Endret av Stian Aarskaug
