Dual Cpu
PIIIpower
http://www.arstechnica.com/reviews/1q00/co...ppermine-5.html
"CPU IOQ 4 almost doubles the available memory bandwidth."
http://www.viahardware.com/viaguide31.shtm
"This controls the In Order Queue Depth, which determines how many operations can be queued before the CPU operates them. This basic form of pipelining can increase performance immensely, sometimes as much as 15%. There are two settings: 1 Level, and 4 Level. 4 Level is the higher performing of the two, and it is suggested you utilize that, unless you run into stability problems. Most of the high-end boards (Tyan Trinity 400, MSI 6309, ASUS P3V4X) come with this option enabled by default."
[ Denne Melding var redigert av: sof på 2002-02-15 10:03 ]
Hmmm. Det viste jeg ikke.
Min var skrudd på 4 som default.
Specs:
Software:
Windows 2000 pro
Servicepack 2
Nvidia Detonator 22.40
AMD Driverpack (include AGP driver)
Hardware:
2 x AMD MP 1800@1632 CPU
Tyan Tiger S2460 MP Motherboard
1 x 512 MB REG ECC RAM
Asus V8200 Deluxe (GeForce 3)
SoundBlaster Audigy player Soundcard
Addtron 10/100 NIC
WDC 100 GB 7200 RPM disk
WDC 40 GB 7200 RPM disk
WDC 80 GB 7200 RPM disk
Plextor 16/10/24 CD-burner
Sony 3,5" floppydisk
ChiefTech 340W Power supply
Image & Shapetek EYE910BB (Housing)
2 x Taisol CGK760092 with copper core(ca 40C idle)
2 x 120 mm YS-Tech fans
2 x 80 mm Coolermaster Fans
2 x 60 mm Ys-tech fans
Round IDE Cables
Slot HO FAN (cool down my Geforce 3)
Artic Silver
Input hardware:
Hansol 900P (Monitor)
Microsoft Intellimouse v 1.1
Logitech Cordless keybord pro
Altec Lansing 2 x speaker + 1 sub + Cerwin-Vega!
8181 In 3dmark 2001 http://gamershq.madonion.com/compare2k1.shtml?2259446
[email protected]
IRC: @EF-net on #hardware.no #casemod
Homepage: http://home.no/bizarre
