Splinter Cell - Blacklist. For oss som spiller på PC
Patchnote v1.02
Tom Clancy's Splinter Cell Blacklist Patch Notes v1.02
August 2013
crash fixes:
- fix for crash on startup on DX11 with certain monitors
- fix memory leak in DX11 constant buffer system
- fix for hang on controller disconnect in loading screens
- fix for hang in customize gear screen
- fix rare crash with host disconnect
- fix crash in loading screen after getting killed in the tunnel
- fix hang in coop after checking computers and disconnecting
- fix crash when equipping tri-rotor in customize gear menu
- fix coop crash in loading screen
- fix popup crash in lobbies
- fix potential audio crash in preload
- fix crash with exclusive skins in co-op
- fix for potential hang after pausing cutscene
- fix frag grenade crash
gameplay:
- fix issues with rogue agent scoring
- fix input for interrogation scenes
- fix co-op interactions with missing prompts
- fix for players reaching out of world location in certain missions
- fix for player getting stuck in kobin back alley
- fix capture the intel objectives when maximum intel is acquired by one team
- fix bad spawns during transitions
- fix getting stuck in door on a specific point on a map
- fix for exploits in SvsM
- fix for spy getting out of map
- fix for merc getting stuck
- fix for intel getting stuck on gun
- fix door replication on a specific map in co-op
- fix some invisible collisions
- fix some crate collisions
- fix for objects falling out of world
- fix getting stuck in corner with crossbow
- fix for spy weapon abuse
- fix for getting stuck in transition area in co-op
- fix for getting stuck in co-op on disconnect
- balance tweaks for frontal attacks
online:
- reduce host migration failures
- fix clients getting stuck in sessions with multiple simultaneous host migrations
- improvements to game migration
- improve speed of getting into game
controls:
- fix controller detection when multiple input devices are connected
- allow gamepad input even if window has no focus
- debounce use key so holding it down doesn't trigger sequence of actions
- fix issue where player can get stuck in sprint mode
graphics:
- fix trirotor explosion
- fix visible scope during cinematics
- support for super widescreen aspect ratios
- fix character rendering on customization screens on high resolution displays
- optimise flash depth stencil buffer allocations
- fix broken tv state
- fix for targets appearing in bind pose
- fix merc animation
- fix issue with unknown resolutions
UI:
- remove duplicated back button in dead drops sub menu
- fix erroneous Joy1/Joy2 button prompts when using keyboard
- fix incorrect message displayed after deploying tri rotor
- fix mouse auto centering when buying items
- fix for hud sometimes missing during mark & execute
- fix with UI getting stuck in customize gear screen whilst upgrading a weapon
- fix controller selection wheel flicker when you don't have focus
- fix mouse clipping issue when lowering resolution below monitor's native resolution
- fix loadout screen missing locks
- fix weapon placement in customize gear screen
- fix preview in coop lobby
- fix view match settings during countdown
- fix gone dark hint display
- fix for leaderboard display corruption
sound:
- fix sound loop for mouse over animations in the SMI
- fix for trirotor sounds in co-op
- fix lost sound on pause menu in coop
- fix for audio during controller reconnection
engine:
- make file save system more robust
- gracefully handle corrupted save game files
- optimise engine to improve performance on older AMD cpus
Tom Clancy's Splinter Cell Blacklist Patch Notes v1.01
August 2013
crash fixes
- AAR screen
- Loading into CO-OP match
- fix alt-tab crashes
- fix alt-tab on windows 8
- fix alt-tab issues on machines with multiple GPUs
- fix window minimization issues
- fix texture crash on incorrect texture info
- fix crash on thread storage release
- fix active sound crash
- fixed crash when resolution is less than 2x2
- fixed device lost crash
- fix crash in paladin
- fix asset load crash
- fix crash when running and defending the teammate who had the intel
- fix deadlock between ui and loading
- fix loading hang
- fix crash opening doorway to hallway leading to tunnel
- fix host crash in hadron collider
- fix crash in voron station
- fix hang in AAR screen in multiplayer
- fix getting stuck in shadownet interface
- fix crash after falling under elevator
- fix crash sliding down ladder
- fix crash on quit to desktop
- fix crash with multithreaded physics
- fix crash on checkpoint reload
- fix crash in silo
controls
- fix hold not activating vision modes
- don't allow WASD/mouse when controller is on
- mercenaries no longer prioritize capturing over killing when using mouse & keyboard
- allow back button when input is blocked for MP scoreboard
- fix reset to default for gamepad
- allow controller connection on SMI screen
- mouse position no longer reset every tick
- scrollbars can now be dragged by mouse
- set correct scrollbar positions in friends party list and key bindings
- fix for not being able to melee in certain locations
- fix intel grab priority
- fix for losing control of input when disconnecting controller during loading
- fix for not being able to switch weapons during countdown
- fix windows key usage
ui
- hide mouse cursor between transitions
- select button removed when mouse and keyboard are default controllers
- hook up mouse clicks correctly in co-op lobby
- mouse movement no longer triggers skip prompt
- quit to desktop option added for ADV/COOP modes
- fixed flicker on selection wheel when using mouse/keyboard
- prevent overlap in chat text
- fix gadget ui
- show clan tags in text chat
- fix mouse interaction with gamma slider
- fix missing button prompt
- fix rogue agent messaging
- fix back button alignment
- fix loadout display visibility on controller disconnection
- fix missing skip prompts
- fix tutorial buttons
- fix text in progress menu
- fix disappearing ui when resetting to defaults
- correctly localise video settings
- update mode option on mission preview when cycling through modes
- fix loadout menu
- fix geotips getting clamped
- fix pulsing icons
graphics
- fix erroneous camera movement when moving mouse and exiting SMI
- fix slowdown when SSAO and MSAA is on
- fix object flickering
- fix white outlines on particles in MSAA mode
- fix vision mode with occlusion system
- fix MSAA causing some objects to have black squares in DX11
- fix field AO flickering in DX11
- fix bullet casing flickering in DX11
- fix SSAO glow on characters in DX11
- fix black textures in DX9
- fix occlusion flickers
- fix laser dot sight
- fix refresh rate issues
- fix character rendering on customization screen in MSAA modes
- fix streamable texture issues
- fix incorrect viewport sizing on first launch
Optimisations
- low spec CPU optimisation
- multi-GPU optimisations
- fix framerate drop issues
configuration
- detect outdated drivers
- correctly set resolution based on system validation
misc
- fix music sequencing in ADV modes
- fix erroneous audio restart when alt-tabbing during video playback
- fix achievement unlocks
- fix assist scoring
- fix ladder playlists
- network replication fixes
Personlig mangler spillet 2 stor ting!
UI:
Remove Radar on highest difficulty (so that the game actually can be challenging)
Gameplay:
Remove the 10 meters hearing & sight limit on the enemy so that they actually can see/hear you when you are 10,5 meters away and not go like...."what was that? ohh, I must be seeing things"
Veldig skuffet over spillet :-(
Endret av Bahamut
Er fornøyd så langt, men lurer på om det er mulig å "snike saktere". Er i crouch, men føler at det lager mye støy når jeg beveger meg og varsler fiender på lang avstand.
Prøvde med gamepad også, uten at jeg merket noen forskjell.
Du kan trykke på Caps Lock så veksler du mellom rask snik og langsom snik. Eller du kan endre til en annen tast på tastatur/mus.
Jeg er så møkka lei ubisoft... JEg forstår ikke hvorfor jeg fortsetter med å støtte de.
Alle spillene jeg har spilt siden AC2 har vært noe dritt!
Flere timer gaming forsvinner pga CLOUD ikke fungerer, lyder mangler, og nååå... NÅ var skjermen i Splinter Cell Blacklist fryst fast gjennom hele forbanna sluttfilmen. ARAJRGHAJIrhjasdhdfksd
Tror jeg har spilt alle splinter cell spillene - synes faktisk dette er litt vanskelig. Synes fienden er mer på tå og hev.
Lurer på en ting i et av de første oppdragene - der du sendes til en ambassade i Jemen? og må stå mot flere angrepsbølger. Har om sider klart det (hater de hundene). Men jeg kommer ikke ut - det står noe om at jeg skal trykke joy2 for å kunne ut.
Spiller med tastatur og mus, og fatter ikke hva som er joy2 - så jeg blir stuck i ambassaden. PLEASE..?..
En liten ting til - KLEBEKAMERA - får kastet det ut, men får ingen glede av det for jeg skjønner ikke hvilke knapper som betjener dette....
Bruker selv Joy2, og du må nok ha rebinda den og så glemt det av eller lignende. Joy2 er knappen mellom Shift og Z ("<>").
Edit: Rettelse, jeg hadde JoyZ og ikke Joy2.
Endret av _NympH
  • 3 uker senere...
  • 1 måned senere...
Gjest Slettet-x7D6du0Hjb
Er det noen som har peiling på om det er mulig å laste ned kjappere med Autopatch? Bruker jo en time på en update..
Synd jeg ikke kunne laste ned patch'ene på egenhånd. Men nå har jeg 1.0.3 installert.
Endret av Slettet-x7D6du0Hjb
Jeg er imponert over hva Ubisoft har fått til med dette spillet. Ikke er det bare rå gameplay, men også føles det som Splinter Cell. Selv har jeg ikke spilt mange av de gamle spillene (eier mange av dem på PC), men jeg vet med sikkerhet at Conviction ikke var et spill som en kan kalle et skikkelig Splinter cell. Jeg er fascinert over grafikken, og lydeffektene, så vel som skuespillerne, de gjør en usedvanlig god jobb!
Det eneste jeg synes er synd er at det er en del våpen og lignende som en må kjøpe gjennom DLC. Det er noe jeg ikke kan fordra. Når jeg kjøper et spill, forventer jeg at jeg kan bruke alt som er i spillet av våpen. Jeg forventer ikke å må kjøpe våpen gjennom DLC. DLC synes jeg er greit dersom det er flere oppdrag o.l, men å ha våpen DLC gjør meg egentlig bare irritert.
