Ideal Skrevet 13. august 2013 Del Skrevet 13. august 2013 Hos meg virker det som at http://avpixlat.info/ har vært nede i to dager, funker den hos dere? Er det DDOS angrep eller hva? Lenke til kommentar
Ideal Skrevet 13. august 2013 Forfatter Del Skrevet 13. august 2013 surt det er jo den eneste brukbare "nettavisen" Lenke til kommentar
*F* Skrevet 13. august 2013 Del Skrevet 13. august 2013 Error 521 https://support.clou...95448-Error-521 An Error 521 means that the origin web server refused the connection from CloudFlare. There are two main reasons why this would occur. In both cases, work with your hosting provider to help resolve the issue. 1) The origin web server is not turned on 2) Something on the web server or hosting provider's network is blocking CloudFlare's requests. Since CloudFlare acts as a reverse proxy, all connections to your server come from a CloudFlare IP. Since the same amount of traffic now comes from a smaller number of IPs, server-side security solutions can mistake the increase in connections from this smaller set of IPs as an attack, when they are legitimate. As soon as you can identify what is blocking CloudFlare's requests, the issue will be resolved. Here are the four common places to look: Make sure that you're not blocking CloudFlare IPs in .htaccess, iptables , or your firewall. Make sure your hosting provider isn't rate limiting or blocking IP requests from the CloudFlare IPs and ask them to whitelist the IP addresses found here: www.cloudflare.com/ips Make sure that you're operating off of the most recent versions of Bad Behavior or mod_security. You want to ensure that mod_security's core rules aren't blocking CloudFlare requests. If you are running custom Apache modules, such as mod_antiloris and mod_reqtimeout, disable and unload the modules. These modules will block any time an IP that connects more than 22 times. Since all connections are now coming from a CloudFlare IP, you will definitely hit the limit causing the error page. As soon as you unload the module, the issue will disappear. Lenke til kommentar
Ideal Skrevet 14. august 2013 Forfatter Del Skrevet 14. august 2013 Avpixlat bekrefter ddos attack: Som de flesta av er sannolikt känner till har Avpixlat legat nere de senaste dagarna som en konsekvens av att antidemokratiska krafter utsatt oss för en extremt massiv DDoS-attack. Inget ont som inte har något gott med sig dock. Med lite mer tid än vanligt till vårt förfogande till följd av avbrottet har vi passat på att slutföra arbetet med vår nya design, vilken egentligen inte var planerad att lanseras förrän om en månad. Nå funker forsiden, men om man trykker på en nyhetslink får man 521... Lenke til kommentar
Akrapovic Skrevet 14. august 2013 Del Skrevet 14. august 2013 Funker fortsatt ikke til meg. Lenke til kommentar
