Hei, jeg har kodet en del i det siste men har støt borti noen errors, og siden dette er noe jeg har satt på prøve etter kraftig anbefaling av en venn. Det det handler om er Pircbot. Jeg får et par errors i konsollen
18:49:42 [iNFO] This server is running CraftBukkit version git-Bukkit-1.5.2-R1.0
-27-gdc25312-b2815jnks (MC: 1.6.2) (Implementing API version 1.6.2-R0.1-SNAPSHOT
18:49:43 [sEVERE] Could not load 'plugins\Demita.jar' in folder 'plugins'
org.bukkit.plugin.InvalidPluginException: java.lang.NoClassDefFoundError: org/ji
bble/pircbot/NickAlreadyInUseException
at org.bukkit.plugin.java.JavaPluginLoader.loadPlugin(JavaPluginLoader.j
ava:184)
at org.bukkit.plugin.SimplePluginManager.loadPlugin(SimplePluginManager.
java:305)
at org.bukkit.plugin.SimplePluginManager.loadPlugins(SimplePluginManager
.java:230)
at org.bukkit.craftbukkit.v1_6_R2.CraftServer.loadPlugins(CraftServer.ja
va:239)
at org.bukkit.craftbukkit.v1_6_R2.CraftServer.<init>(CraftServer.java:21
7)
at net.minecraft.server.v1_6_R2.PlayerList.<init>(PlayerList.java:56)
at net.minecraft.server.v1_6_R2.DedicatedPlayerList.<init>(SourceFile:11
at net.minecraft.server.v1_6_R2.DedicatedServer.init(DedicatedServer.jav
a:106)
at net.minecraft.server.v1_6_R2.MinecraftServer.run(MinecraftServer.java
:391)
at net.minecraft.server.v1_6_R2.ThreadServerApplication.run(SourceFile:5
82)
Caused by: java.lang.NoClassDefFoundError: org/jibble/pircbot/NickAlreadyInUseEx
ception
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
ava:173)
... 9 more
Caused by: java.lang.ClassNotFoundException: org.jibble.pircbot.NickAlreadyInUse
Exception
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at org.bukkit.plugin.java.PluginClassLoader.findClass0(PluginClassLoader
.java:80)
at org.bukkit.plugin.java.PluginClassLoader.findClass(PluginClassLoader.
java:53)
at java.lang.ClassLoader.loadClass(Unknown Source)
... 12 more
Trenger du source til noe kontakt meg eller så vil jeg legge det ut på github senere
Ser ut som pircbot ikke inneholder noen definisjon for NickAlreadyInUseException og Demita.jar kan derfor ikke lastes ettersom den er avhengig av denne klassen.
 public void ircBot() {
  bot.setVerbose(false);
  try {
	  bot.connect("irc.minecraft.no");
	  getLogger().info("Bot connected.");
  } catch (NickAlreadyInUseException e) {
	  bot.setAutoNickChange(true);
	  // e.printStackTrace();
  } catch (IOException e) {
  } catch (IrcException e) {
  bot.sendMessage("NickServ", "identify msg123");
  bot.joinChannel("#Demita");
  bot.joinChannel("#Demita_ll");
  bot.joinChannel("#Demita_mm");
  bot.joinChannel("#Demita_el");
Hmm...?
