Hvordan hacke passord-database?
Yamato47
Jeg gjentar, md5 kan ikke knekkes med dagens teknologi, med mindre du vil vente i flere år på at rett passord skal finnes da ;)
Legg ut et kryptert passord fra passordfila di da vel, så kan vi prøve å motbevise deg!
Hvis du velger et med bare lowcaps bokstaver, og under 8 tegns lengde, som alle mine ftp-brukere har, hvor lang tid tror du det tar å knekke koden?
Knock yourself out... :wink:
/etc/passwd:
root:x:0:0:root:/root:/bin/bash
bin:x:1:1:bin:/bin:/bin/bash
daemon:x:2:2:Daemon:/sbin:/bin/bash
lp:x:4:7:Printing daemon:/var/spool/lpd:/bin/bash
mail:x:8:12:Mailer daemon:/var/spool/clientmqueue:/bin/false
games:x:12:100:Games account:/var/games:/bin/bash
wwwrun:x:30:65534:WWW daemon apache:/var/lib/wwwrun:/bin/bash
named:x:44:44:Nameserver daemon:/var/named:/bin/bash
nobody:x:65534:65533:nobody:/var/lib/nobody:/bin/bash
ftp:x:40:49:FTP account:/srv/ftp:/bin/bash
man:x:13:62:Manual pages viewer:/var/cache/man:/bin/bash
news:x:9:13:News system:/etc/news:/bin/bash
uucp:x:10:14:Unix-to-Unix CoPy system:/etc/uucp:/bin/bash
sshd:x:71:65:SSH daemon:/var/lib/sshd:/bin/false
at:x:25:25:Batch jobs daemon:/var/spool/atjobs:/bin/bash
postfix:x:51:51:Postfix Daemon:/var/spool/postfix:/bin/false
ntp:x:74:65534:NTP daemon:/var/lib/ntp:/bin/false
drdoogie:x:500:100:"Kjøttleif Olsen":/home/drdoogie:/bin/bash
irc:x:39:65534:IRC daemon:/usr/lib/ircd:/bin/bash
mysql:x:60:2:MySQL database admin:/var/lib/mysql:/bin/false
ldap:x:76:70:User for OpenLDAP:/var/lib/ldap:/bin/bash
pop:x:67:100:POP admin:/var/lib/pop:/bin/false
squid:x:31:65534:WWW-proxy squid:/var/cache/squid:/bin/false
mailman:x:72:67:GNU mailing list manager:/var/lib/mailman:/bin/bash
gdm:x:50:15:Gnome Display Manager daemon:/var/lib/gdm:/bin/bash
snort:x:73:68:Snort network monitor:/var/lib/snort:/bin/bash
amanda:x:37:6:Amanda admin:/var/lib/amanda:/bin/bash
temp:x:501:100::/home/tempuser:/bin/bash
postgres:x:502:100::/home/postgres:/bin/bash
lfs:x:503:100::/home/lfs:/bin/bash
+::0:0:::
/etc/shadow:
root:687UyLeRiLif.:12201:0:10000::::
bin:*:8902:0:10000::::
daemon:*:8902:0:10000::::
lp:*:8902:0:10000::::
mail:*:8902:0:10000::::
games:*:8902:0:10000::::
wwwrun:*:8902:0:10000::::
named:*:8902:0:10000::::
nobody:*:8902:0:10000::::
ftp:*:8902:0:10000::::
man:*:8902:0:10000::::
news:*:8902:0:10000::::
uucp:*:8902:0:10000::::
sshd:!:12130:0:99999:7:::
at:!:12130:0:99999:7:::
postfix:!:12130:0:99999:7:::
ntp:!:12130:0:99999:7:::
drdoogie:dkT.cLhc8hyJw:12130:0:99999:7:::
irc:!:12130:0:99999:7:::
mysql:!:12130:0:99999:7:::
ldap:!:12130:0:99999:7:::
pop:!:12130:0:99999:7:::
squid:!:12130:0:99999:7:::
mailman:!:12130:0:99999:7:::
gdm:!:12130:0:99999:7:::
snort:!:12145:1:99999:14:::
amanda:!:12151:1:99999:14:::
temp:VGlYDcROpeovA:12201:1:32767:14:::
postgres:!:12235:1:99999:14:::
lfs:MnscP0x6RNRwo:12242:1:99999:14:::
EDIT: Good God! Tok meg mer tid å skrive inn kommandoene enn programmet brukte på å cracke dette!
Skal vi nå slå fast at:
- ordboksøk er mulig på dårlige passord (på vanlig DES kan john the ripper sjekke 170000 passord i sekundet på min pc)
- salting brukes bare for at to brukere som har samme passord ikke skal se dette ved å f.eks. titte på de to krypterte versjonene av passordene sine (saltet står i klartekst i begynnelsen av passordstrengen i shadow)
- et bra passord inneholder ingen ord, dvs. er en tilfeldig kombinasjon av tall og bokstaver a.la. H2ksUl5 (nei, dette er bare tilfeldig. Jeg bruker ikke dette noen plass, så bare glem det)
MD5 er ikke en kryptering, men en hashing og den er ikke reversibel.
Du kan jo f.eks. lage en hashfil for en iso, slik at når du har lasta ned fila kan du sjekke at den ikke er endra eller det er feil i den.
Men hvis du kunne reversert MD5 hadde du laget verdens mest geniale komprimeringsfunksjon (zip, gz, bzip osv. kunne godt hjem å lagt seg :-) ).
Skjønner?
Hvordan skriver man om md5 hashen i shadow fila for å være kompatibel med mdcrack ?
root]# mdcrack $1$wAYdDY.s$s98x.iXU77PuAp9CCQSQw/
<<System>> MDcrack v1.2 is starting.
<<Error>> A md5 digest must have 16 bytes length (32 ascii digits from 0 to F).
Bruk John the Ripper istedet. Meget bra og kjapt program.
Trodde forresten det var DES og ikke MD5 som var brukt i shadow-fila
