Synes dere om den ferdige portfolio siden min?
Du bør bruke PayPal (eller noe lignende) i tillegg til muligheten med å sende penger i posten. Dette vil gjøre det mye enklere for folk, og PayPal er gratis; kun et lite gebyr på mottatte pengebeløp, hvis du skal ta imot kredittkort-betalinger.
Og, helt til slutt, hvis det er noe man ikke har peiling på, holder man det stille for seg selv, og viser det ihvertfall ikke til potensielle kunder.
først og fremst, du tilbyr webdesign men siden din er stappa til randen med feil i html koden:
File:   cd.html
Encoding:  iso-8859-1
Doctype:  HTML 4.01 Transitional
Errors:  56
   * Line 28, column 130: cannot generate system identifier for general entity "nbspKontakt"
   * Line 34, column 144: cannot generate system identifier for general entity "nbspOm"
   * Line 39, column 149: cannot generate system identifier for general entity "nbspPortfolio"
   * Line 75, column 113: cannot generate system identifier for general entity "id"
   * Line 185, column 214: cannot generate system identifier for general entity "nbspHovedsiden"
   * Line 189, column 225: cannot generate system identifier for general entity "nbspTjenester"
   * Line 192, column 230: cannot generate system identifier for general entity "nbspF.A.Q"
This page is not Valid HTML 4.01 Transitional!
Below are the results of attempting to parse this document with an SGML parser.
  1. Line 4, column 6: required attribute "TYPE" not specified (explain...).
 <style>
  2. Line 28, column 130: cannot generate system identifier for general entity "nbspKontakt"
 ...ans-serif">&nbsp&nbsp&nbsp&nbsp&nbsp&nbspKontakt
  3. Line 28, column 130: general entity "nbspKontakt" not defined and no default entity (explain...).
  4. Line 28, column 141: reference to entity "nbspKontakt" for which no system identifier could be generated
 ...&nbsp&nbsp&nbsp&nbsp&nbsp&nbspKontakt
  5. Line 28, column 129: entity was defined here
 ...sans-serif">&nbsp&nbsp&nbsp&nbsp&nbsp&nbspKontakt
  6. Line 32, column 154: required attribute "ALT" not specified (explain...).
 ...if/strek2.gif" width="164" height="9"></div>
  7. Line 34, column 144: cannot generate system identifier for general entity "nbspOm"
 ...p&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspOm
  8. Line 34, column 144: general entity "nbspOm" not defined and no default entity (explain...).
  9. Line 34, column 150: reference to entity "nbspOm" for which no system identifier could be generated
 ...&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspOm
 10. Line 34, column 143: entity was defined here
 ...sp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspOm
 11. Line 37, column 154: required attribute "ALT" not specified (explain...).
 12. Line 39, column 149: cannot generate system identifier for general entity "nbspPortfolio"
 ...p&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspPortfolio&nbsp&nbsp&nbsp&nbsp&nbsp&n
 13. Line 39, column 149: general entity "nbspPortfolio" not defined and no default entity (explain...).
 14. Line 39, column 162: reference to entity "nbspPortfolio" for which no system identifier could be generated
 ...bsp&nbsp&nbsp&nbsp&nbsp&nbspPortfolio&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp
 15. Line 39, column 148: entity was defined here
 ...sp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspPortfolio&nbsp&nbsp&nbsp&nbsp&nbsp&
 16. Line 41, column 154: required attribute "ALT" not specified (explain...).
 17. Line 61, column 29: there is no attribute "HEIGHT" (explain...).
   <table width="100%" height="317" border="1" bordercolor="000000" background=".
 18. Line 61, column 58: there is no attribute "BORDERCOLOR" (explain...).
 ... height="317" border="1" bordercolor="000000" background="../gif/tabell_bkg.g
 19. Line 61, column 78: there is no attribute "BACKGROUND" (explain...).
 ...="1" bordercolor="000000" background="../gif/tabell_bkg.gif"cellpadding="0"ce
 20. Line 75, column 113: cannot generate system identifier for general entity "id"
 ...-2000.com/server.php?service=counter&id=flodhest"></script>
 21. Line 75, column 113: general entity "id" not defined and no default entity (explain...).
 22. Line 75, column 115: reference to entity "id" for which no system identifier could be generated
 ...000.com/server.php?service=counter&id=flodhest"></script>
 23. Line 75, column 112: entity was defined here
 ...g-2000.com/server.php?service=counter&id=flodhest"></script>
 24. Line 110, column 114: reference to entity "id" for which no system identifier could be generated
 ...2000.com/server.php?service=online&id=flodhest"></script>
 25. Line 75, column 112: entity was defined here
 26. Line 137, column 160: required attribute "ALT" not specified (explain...).
 ...r_banner.gif" width="679" height="36"></div>
 27. Line 151, column 55: required attribute "ALT" not specified (explain...).
   <img src="../gif/hoved2.gif" width="828" height="659">
 28. Line 163, column 11: ID "LAYER2" already defined (explain...).
   <div id="Layer2" style="position:absolute; left:669px; top:278px; width:100px;
 29. Line 137, column 9: ID "LAYER2" first defined here (explain...).
 <div id="Layer2" style="position:absolute; left:247px; top:26px; width:197px; he
 30. Line 178, column 9: ID "LAYER4" already defined (explain...).
 <div id="Layer4" style="position:absolute; left:652px; top:38px; width:210px; he
 31. Line 139, column 11: ID "LAYER4" first defined here (explain...).
   <div id="Layer4" style="position:absolute; left:237px; top:551px; width:365px;
 32. Line 178, column 122: "FONT" is not a member of a group specified for any attribute (explain...).
 ...13px; z-index:3"><font size="1" font color="#000000" face="Verdana, Arial, He
 33. Line 183, column 9: ID "LAYER6" already defined (explain...).
 <div id="Layer6" style="position:absolute; left:306px; top:189px; width:317px; h
 34. Line 165, column 11: ID "LAYER6" first defined here (explain...).
   <div id="Layer6" style="position:absolute; left:645px; top:223px; width:141px;
 35. Line 185, column 9: ID "LAYER7" already defined (explain...).
 <div id="Layer7" style="position:absolute; left:125px; top:352px; width:105px; h
 36. Line 152, column 9: ID "LAYER7" first defined here (explain...).
 <div id="Layer7" style="position:absolute; left:645px; top:340px; width:141px; h
 37. Line 185, column 214: cannot generate system identifier for general entity "nbspHovedsiden"
 ....php">&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspHovedsiden&nbsp&nbsp&nbsp&nbsp&nbsp&
 38. Line 185, column 214: general entity "nbspHovedsiden" not defined and no default entity (explain...).
 39. Line 185, column 228: reference to entity "nbspHovedsiden" for which no system identifier could be generated
 ...sp&nbsp&nbsp&nbsp&nbsp&nbspHovedsiden&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nb..
 40. Line 185, column 213: entity was defined here
 ...x.php">&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspHovedsiden&nbsp&nbsp&nbsp&nbsp&nbsp
 41. Line 187, column 153: required attribute "ALT" not specified (explain...).
 42. Line 188, column 9: ID "LAYER9" already defined (explain...).
 <div id="Layer9" style="position:absolute; left:116px; top:364px; width:160px; h
 43. Line 109, column 11: ID "LAYER9" first defined here (explain...).
   <div id="Layer9" style="position:absolute; left:12px; top:-9px; width:115px; h
 44. Line 188, column 153: required attribute "ALT" not specified (explain...).
 45. Line 189, column 225: cannot generate system identifier for general entity "nbspTjenester"
 ...>&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspTjenester&nbsp&nbsp&nbsp&nbsp&nbsp&n
 46. Line 189, column 225: general entity "nbspTjenester" not defined and no default entity (explain...).
 47. Line 189, column 238: reference to entity "nbspTjenester" for which no system identifier could be generated
 ...bsp&nbsp&nbsp&nbsp&nbsp&nbspTjenester&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp
 48. Line 189, column 224: entity was defined here
 ...">&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspTjenester&nbsp&nbsp&nbsp&nbsp&nbsp&
 49. Line 191, column 9: ID "LAYER11" already defined (explain...).
 <div id="Layer11" style="position:absolute; left:117px; top:382px; width:151px;
 50. Line 74, column 11: ID "LAYER11" first defined here (explain...).
   <div id="Layer11" style="position:absolute; left:24px; top:23px; width:36px; h
 51. Line 191, column 156: required attribute "ALT" not specified (explain...).
 52. Line 192, column 230: cannot generate system identifier for general entity "nbspF.A.Q"
 ...p&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspF.A.Q&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&
 53. Line 192, column 230: general entity "nbspF.A.Q" not defined and no default entity (explain...).
 54. Line 192, column 239: reference to entity "nbspF.A.Q" for which no system identifier could be generated
 ...sp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspF.A.Q&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp
 55. Line 192, column 229: entity was defined here
 ...sp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspF.A.Q&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp
 56. Line 194, column 154: required attribute "ALT" not specified (explain...).
Og hvorfor du bruker frames på en sånn side har jeg virkelig vanskelig for å forstå?
Når du skriver på forsiden at du ikke kan php eller html og at dette nesten ikke er nødvendig å kunne for du bruker DW da mista du ihvertfall meg som kunde med engang(jeg mekker riktignok alltid mine egne sider, men du forstår vel hva jeg mener), forøvrig hvis man absolutt må bruke det istedenfor å lære seg css, &nbsp må alltid avsluttes med semikolon.
Bare noen små tips til slutt, de fleste som søker hjelp til websidemekking gjør dette fordi de ikke har så mye greie på webting(fleste tilfellene ihvertfall) og når ip'en deres står på forsida kan de fort bli skremt bort eller ihvertfall begynne å lure på hva du driver med som tar ip'en deres, derimot en grei ting som jeg pleier å gjøre er å legge ip'en til besøkende inni <!-- --> nederst i scriptet og kanskje skrive noe skremmende siden de titter på koden min...
Brukere og Teller (hvis du absolutt må ha det der) gjør de ihvertfall mer diskre...
takker for svar!
Magikern: det holder sikkert med å si at det er feil i koden, behøver ikke quote dem alle.
Grunnen til at jeg sier jeg ikke er så flink til html og php er av den fornuftige grunn at jeg ikke vil få henvendelser om at jeg skal mekke avanserte og innviklete scripts og sånne ting. Jeg liker å ha det klart at det for det første er design jeg satser mest på, jeg driver ikke dette på profesjonell basis...bare en liten hobby jeg driver med, og hvorfor ikke prøve å tjene penger på hobbyen sin :p
jeg er fullt klar over at det skal en semikolon bak nbsp greia...dette skal rettes opp snarest...eventuelt lage en annen mouse over.
hm...mener dere alle at det gjør så mye med den ip saken altså? Da vurderer jeg å droppe det hvis det er SÅ ille.
takk for tipset om paypal rutebil!
_orion_: merkelig...er ikke sånn hos meg. Bruker IE.
takker alle for svar og konstrukiv kritikk, det er bare å komme med mer!
Helt ærlig så er det nok ingen som vil vite ip'en sin med mindre de har et spesielt behov og får tenning av å se den :-?
Angående siden synes jeg den ser flott ut.
PS: Jeg sier ifra når moroklatten er lansert slik at du kan legge il en link på logoen på portifoliosiden :wink:
(Takk for hjelpen)
EDIT: Innlegg nr. 300!
