Factory reset på en AC Ryan Playon HD mini
Det ser ikke ut til at den støtter en slik reset. Det nærmeste jeg finner er denne oppskriften:
1. Recover the unit by safe-mode flashing with firmware 3875
a. Download the firmware 3875 and unzip the downloaded file.
b. Copy install.img to the root directory of a USB flash drive and connect it to any USB host port of the unit.
c. Switch off the main power to the unit.
d. Press and hold on to the power button on the front panel of the unit.
e. Switch on the main power.
f. Release the power button when the firmware update starts flashing on your display in a moment and will automatically reboot when update is completed.
g. You should be able to recover the unit after the unit reboots.
2. Upgrade the bootloader using firmware v7.3.x.r3582 with USB upgrade method
a. Download the firmware 3582 and unzip the downloaded file.
c. Go to SETUP > SYSTEM > SYSTEM UPDATE > SYSTEM UPGRADE.
d. The system will reboot to install the firmware. Once the installation is completed, it will automatically reboot.
3. Upgrade to latest official firmware as per normal
a. Download the latest official firmware 7317 and unzip the downloaded file.
IMPORTANT:
Do not switch off the power during firmware update.
Note 1:
If you have issues updating the firmware, please try to format the USB flashdrive to FAT32 file system or use a different USB flashdrive and try again.
