Noen spørsmål angående Chillispot og nettverkskort
Hvordan skal /etc/network(interfaces se ut?
/etc/network/interfaces ser slik ut
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
# The loopback network interface
auto lo
iface lo inet loopback
# The network interfaces that you want to start
auto eth0 eth1
# The primary network interface
iface eth0 inet dhcp
# The secondary network interface
iface eth1 inet static ?
Så spørsmål nummer 2 ettersom bare ett kort blir detektert
lspci gir meg
00:00.0 Host bridge: Intel Corporation N10 Family DMI Bridge (rev 02)
00:02.0 VGA compatible controller: Intel Corporation N10 Family Integrated Graphics Controller (rev 02)
00:1b.0 Audio device: Intel Corporation N10/ICH 7 Family High Definition Audio Controller (rev 01)
00:1c.0 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 1 (rev 01)
00:1c.1 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 2 (rev 01)
00:1c.2 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 3 (rev 01)
00:1c.3 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 4 (rev 01)
00:1d.0 USB controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #1 (rev 01)
00:1d.1 USB controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #2 (rev 01)
00:1d.2 USB controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #3 (rev 01)
00:1d.3 USB controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #4 (rev 01)
00:1d.7 USB controller: Intel Corporation N10/ICH 7 Family USB2 EHCI Controller (rev 01)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e1)
00:1f.0 ISA bridge: Intel Corporation NM10 Family LPC Controller (rev 01)
00:1f.2 SATA controller: Intel Corporation N10/ICH7 Family SATA Controller [AHCI mode] (rev 01)
00:1f.3 SMBus: Intel Corporation N10/ICH 7 Family SMBus Controller (rev 01)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 03)
Mangler da intel kortet
dmesg | grep e1000 gir meg
[55281.476907] e1000e: Intel® PRO/1000 Network Driver - 2.0.0-k
[55281.476919] e1000e: Copyright© 1999 - 2012 Intel Corporation.
[55288.763971] e1000: Intel® PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[55288.763979] e1000: Copyright © 1999-2006 Intel Corporation
Så er spørsmålet hvordan få intel kortet opp og kjøre
Spørsmål 3 er hvordan du legger til eller sletter bruker chilli ettersom den klager på bruker chilli mot MySQL.
Spørsmål 4 vil jeg avvente ettersom jeg tror dette henger sammen med spørsmål 1
Endret av Lindsay
Kjører på 3.5.0-31-generic på ubuntu 12.04.
easyhotspot som er et annet alternativ kjører på ubuntu 9.04 som i og for seg er greit, men da blir det kun å benytte denne til en oppgave som captive portal.
Så easyhotspot ser jeg ikke på som et alternativ ennå.
Skal se over konfigurasjonsfilene om det er noe jeg har utelatt
Fordelen med easyhotspot er att hele sullamitten er satt opp som default
Endret av Lindsay
Kortet fungerer i en smoothwall som kjører kernel 2.6.32 men du må kjøre detect på hver interface du vil benytte 3 soner + internet.
Skal sette opp eth1som eth0 og se om det ikke kommer opp på et annen VLAN bare for å ha testet det
