Det eneste assert gjør er å evaluere et utrykk, skrive ut et en feilmelding og stoppe programmet hvis utrykket er lik 0 (false).
assert blir typisk fjernet av kompilatoren i "release builds". Dette blir gjort ved å definere NDEBUG, noe de fleste kompilatorer gjør automatisk når du velger release (el. tilsvarende). assert blir med andre ord oftest brukt til debugging og er svært nyttig :) Bruker assert ganske hyppig selv...
ASSERT(3)                                                 Linux Programmer's Manual                                                 ASSERT(3)
NAME
      assert - abort the program if assertion is false
SYNOPSIS
      #include <assert.h>
      void assert(scalar expression);
DESCRIPTION
      If the macro NDEBUG was defined at the moment <assert.h> was last included, the macro assert() generates no code, and hence does noth-
      ing at all.  Otherwise, the macro assert() prints an error message to standard output and terminates the program by calling abort() if
      expression is false (i.e., compares equal to zero).
      The  purpose  of  this macro is to help the programmer find bugs in his program. The message "assertion failed in file foo.c, function
      do_bar(), line 1287" is of no help at all to a user.
RETURN VALUE
      No value is returned.
CONFORMING TO
      ISO9899 (ANSI C).  In the 1990 standard, expression is required to be of type int and undefined behavior results if it is not, but  in
      the 1999 standard it may have any scalar type.
BUGS
      assert()  is  implemented  as  a  macro;  if  the expression tested has side-effects, program behaviour will be different depending on
      whether NDEBUG is defined.  This may create Heisenbugs which go away when debugging is turned on.
SEE ALSO
      exit(3), abort(3), assert_perror(3)
C99                                                               2002-08-25                                                        ASSERT(3)
