armanite Skrevet 7. juni 2013 Forfatter Rapporter Del Skrevet 7. juni 2013 (endret) Gått en stund nå uten at PCen frøs eller at jeg hadde bluescreen, selv når jeg har hatt Flash osv. oppe. Hadde kun kjørt error check på harddiskene og etter det testet meg litt sakte fram, uten at noe skjedde. Men idag så fikk jeg bluescreen igjen, dette skjedde mens jeg hadde Football Manager oppe og var inne på Google Maps på Chrome for å sjekke noe. DRIVER_IRQL_NOT_LESS_OR_EQUAL BCCode: d1 BCP1: FFFFCE8043995002 BCP2: 00000000000000002 BCP3: 00000000000000000 BCP4: FFFFF88007578B7D OS Version: 6_1_7601 Service Pack: 1 Product: 256_1 *** nvlddmkm.sys Og her er bugcheck analysen fra MEMORY.DMP filen. DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1) An attempt was made to access a pageable (or completely invalid) address at an interrupt request level (IRQL) that is too high. This is usually caused by drivers using improper addresses. If kernel debugger is available get stack backtrace. Arguments: Arg1: ffffce8043995002, memory referenced Arg2: 0000000000000002, IRQL Arg3: 0000000000000000, value 0 = read operation, 1 = write operation Arg4: fffff88007578b7d, address which referenced memory Debugging Details: ------------------ READ_ADDRESS: ffffce8043995002 CURRENT_IRQL: 2 FAULTING_IP: nvlddmkm+352b7d fffff880`07578b7d 488b7c2450 mov rdi,qword ptr [rsp+50h] DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT BUGCHECK_STR: 0xD1 PROCESS_NAME: chrome.exe TAG_NOT_DEFINED_c000000f: FFFFF880009B0FB0 TRAP_FRAME: fffff880009b09e0 -- (.trap 0xfffff880009b09e0) NOTE: The trap frame does not contain all registers. Some register values may be zeroed or incorrect. rax=0000000000000000 rbx=0000000000000000 rcx=fffffa8008305000 rdx=0000000000610024 rsi=0000000000000000 rdi=0000000000000000 rip=fffff88007578b7d rsp=fffff880009b0b70 rbp=fffff880009b0ba0 r8=0000000000000020 r9=fffff880009b0b08 r10=fffff880073dde34 r11=0000000000000002 r12=0000000000000000 r13=0000000000000000 r14=0000000000000000 r15=0000000000000000 iopl=0 nv up ei ng nz na po nc nvlddmkm+0x352b7d: fffff880`07578b7d 488b7c2450 mov rdi,qword ptr [rsp+50h] ss:fffff880`009b0bc0=0050300880faffff Resetting default scope LAST_CONTROL_TRANSFER: from fffff800030cc1a9 to fffff800030ccc00 STACK_TEXT: fffff880`009b0898 fffff800`030cc1a9 : 00000000`0000000a ffffce80`43995002 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx fffff880`009b08a0 fffff800`030cae20 : fffff880`00000000 00000000`00000002 fffffa80`08305000 fffffa80`076d2000 : nt!KiBugCheckDispatch+0x69 fffff880`009b09e0 fffff880`07578b7d : fffffa80`00000000 00000000`00000000 00000000`00000000 fffff880`00000000 : nt!KiPageFault+0x260 fffff880`009b0b70 fffff880`07577ad0 : fffffa80`076d2000 00000000`00000008 fffffa80`08305000 fffff880`07578435 : nvlddmkm+0x352b7d fffff880`009b0bb0 fffff880`075778c7 : fffffa80`096e2910 fffffa80`00000014 fffffa80`076d2000 fffffa80`084e4ec0 : nvlddmkm+0x351ad0 fffff880`009b0c10 fffff880`07577ce3 : 00000000`00000000 fffffa80`08305000 fffffa80`076d2000 00000000`00000100 : nvlddmkm+0x3518c7 fffff880`009b0c50 fffff880`0765660a : fffffa80`08305000 fffffa80`083052dc fffffa80`076d2000 fffffa80`076d2000 : nvlddmkm+0x351ce3 fffff880`009b0c80 fffff880`073b3e0b : fffffa80`08305000 00000000`00000000 00000000`00000000 fffffa80`07a64000 : nvlddmkm+0x43060a fffff880`009b0cb0 fffff880`072de91d : fffffa80`07a64000 fffffa80`07a640c8 fffffa80`07a640c8 00000000`00000000 : nvlddmkm+0x18de0b fffff880`009b0dd0 fffff880`0733cd19 : fffff880`072de8b4 fffffa80`07a640c8 fffffa80`07a64000 fffffa80`07a640c8 : nvlddmkm+0xb891d fffff880`009b0e70 fffff800`030d72fc : fffff880`0733ccb5 fffff880`02fd5180 00000000`00000000 00000000`000000bb : nvlddmkm+0x116d19 fffff880`009b0f00 fffff800`030cfd05 : 00000000`00000000 fffffa80`0a5fc8f0 00000000`00000000 fffff880`0733d040 : nt!KiRetireDpcList+0x1bc fffff880`009b0fb0 fffff800`030cfb1c : fffffa80`071f0780 fffff800`030d81b8 00000000`0019fd01 00000000`7efdb000 : nt!KyRetireDpcList+0x5 fffff880`0b8aabe0 fffff800`03117b53 : fffff800`030c8643 fffff800`030c86af 00000000`57993dbc fffff880`0b8aaca0 : nt!KiDispatchInterruptContinue fffff880`0b8aac10 fffff800`030c86af : 00000000`57993dbc fffff880`0b8aaca0 00000000`000000ff 00000000`06cc9600 : nt!KiDpcInterruptBypass+0x13 fffff880`0b8aac20 00000000`6cc52844 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiChainedDispatch+0x19f 00000000`003ed9f0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x6cc52844 STACK_COMMAND: kb FOLLOWUP_IP: nvlddmkm+352b7d fffff880`07578b7d 488b7c2450 mov rdi,qword ptr [rsp+50h] SYMBOL_STACK_INDEX: 3 SYMBOL_NAME: nvlddmkm+352b7d FOLLOWUP_NAME: MachineOwner MODULE_NAME: nvlddmkm IMAGE_NAME: nvlddmkm.sys DEBUG_FLR_IMAGE_TIMESTAMP: 518fe8f9 FAILURE_BUCKET_ID: X64_0xD1_nvlddmkm+352b7d BUCKET_ID: X64_0xD1_nvlddmkm+352b7d Followup: MachineOwner --------- 3: kd> lmvm nvlddmkm start end module name fffff880`07226000 fffff880`07d07000 nvlddmkm (export symbols) nvlddmkm.sys Loaded symbol image file: nvlddmkm.sys Image path: \SystemRoot\system32\DRIVERS\nvlddmkm.sys Image name: nvlddmkm.sys Timestamp: Sun May 12 21:09:45 2013 (518FE8F9) CheckSum: 00AB6DED ImageSize: 00AE1000 Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4 Når jeg søker opp nvlddmkm.sys så er den relatert til NVIDIA og det virker litt rart når jeg nettopp har avinstallert driveren, kjørt Driver Sweeper i Safe Mode for å kvitte meg med alt som evt. skulle ligge igjen og så installere helt ny driver. Daemon Tools dukket også opp når jeg søkte opp BCCode d1, så skal avinstallere det også. Bruker det relativt sjeldent uansett. Edit: Når jeg sjekker opp det med nvlddmkm.sys og NVIDIA, så legger jeg plutselig merke til at jeg jeg ikke har noe NVIDIA kontrollpanel ikon i toolbaren. Så sjekker jeg fort og det virker rett og slett som at driveren bare har blitt borte. Og jeg kjørte jo nettopp clean install for noen dager siden hvor jeg er helt sikker på at alt gikk bra og at den ble installert helt korrekt. Så jeg laster ned driveren igjen og når jeg skal installere så får jeg opp 3 forskjellige Windows feilmeldinger mens den holder på å installere Graphics Driver. Får opp; "Windows host process (Rundll32) has stopped working" og kan velge "Check online" osv. bla bla. Deretter får jeg "You are about to be logged off"-feilmelding som sier; "Windows must restart because the DCOM Server Process Launcher service terminated unexpectedly". Dette skjer altså midt under installasjonen. Endret 7. juni 2013 av armanite Lenke til kommentar
