Neste Gen skjermkort Nvidia (gtx 700)
Good news, I'm glad to announce that after a couple months of development and closed beta testing we're ready to launch release candidate of MSI Afterburner 4.0.0. MSI Afterburner 4.0.0 Beta 9 version will be launched as release candidate this week, then we'll collect feedback on new functionality and release final 4.0.0 shortly. Changes list includes:
Version 4.0.0
• Various parts of hardware monitoring module have been pumped up to improve hardware monitoring usability and flexibility:
o Added layered monitoring graphs rendering mode. Now you may right click source graph in monitoring window, select “Attach” in the context menu then point to destination graph to attach source graph to it and create a group of layered graphs. This feature allows you to render as many layered graphs on the same grid as you wish. The colors of graphs in layered rendering mode can be customized independently of each other so you can easily identify them
o Added multi-column monitoring graphs rendering mode. Now you can adjust the number of graph columns in “Active monitoring graphs” section in “Monitoring” tab
o Added “Override graph name” option to “Monitoring” tab. Now you can rename the graphs displayed in hardware monitoring window
o Monitoring history buffer size is no longer defined by monitoring window width. Now pre-history buffer size is fixed and stores the last 3600 samples (1 hour for 1000ms polling period) for each graph
o Improved tray icon monitoring module:
o Now you can select either text mode or barchart indicator mode for each value displayed in tray icon. Barchart indicator mode can be extremely useful for visualizing data like GPU / CPU usage
o Improved Logitech keyboard LCD monitoring module:
o Ported to new Logitech API to provide support for newer Logitech LCD displays
o Added support for color LCD display of Logitech G19/G19s keyboards
o Added graph mode support for color LCD display of Logitech G19/G19s keyboards. Now in addition to previously available text mode you can optionally select graph mode and see exact copy of MSI Afterburner’s monitoring graphs displayed directly inside the keyboard LCD. You can also press “Menu” soft button on your Logitech G19/G19S keyboard to toggle between text and graph modes dynamically in realtime
o Added acceleration support to LCD scrolling implementation
o Added larger 8x12, 10x12, 12x12 and 12x16 fonts support for text mode
• Added “Regional settings” section to “User Interface” tab:
o Temperature format settings allow you to switch between Celsius and Fahrenheit format for monitored temperatures. Please take a note that this setting affects temperature readouts only. Hardware related temperature adjustments (e.g. fan speed to temperature mapping curve for all cards or temperature target adjustment for NVIDIA Kepler series) are always being displayed and adjusted in Celsius for maximum unification, safety and compatibility
o 12 hours / 24 hours time format settings allow you to configure time format for On-Screen Display and hardware monitoring window
• Added “Enable low-level IO driver” option to the “Compatibility properties” section in “General” tab
• Added SLI sync performance limit graph for release 340 and newer NVIDIA drivers
• Display device enumeration implementation has been modified slightly to allow monitoring Intel iGPUs when low-level IO driver is not enabled
• Improved handshaking algorithm reduces the risk of seeing multiple running instances of child processes (e.g. RTSS)
• Optimized hardware polling for NVIDIA graphics cards
• Optimized hardware polling for multi-GPU systems
• Added SVI2 voltage control support via AMD ADL SDK to provide compatibility with future graphics cards
• Added automatic prerecording settings to “Videocapture” tab. When you enable automatic mode prerecording session is being started automatically on each 3D application startup. Please take a note that in this case you can still use video prerecord hotkey to stop then manually restart prerecording session if necessary
• Drastically improved skin engine:
o Improved skin compiler gives more detailed error messages when skin compilation fail due to error in some source image file
o Source image file format is no longer limited to 24-bit BMP files only. Now skin compiler supports all possible bit depths for BMP format and fully supports PNG format with alpha channel
o Added built-in bitmap effect for extracting alpha-channel from PNG image files
o Skin format has been upgraded to v1.3. New format supports alpha channel based transparency for skinned window, allowing skin designers to define semi-transparent skin areas, apply antialiasing to the skin window edges and so on
o Added new skinned window composition modes support and “Skin composition mode” settings to “User interface tab”. New settings allows you to use one of the following modes:
o Traditional mode – suits best for backward compatibility with existing skins and performance testing
o Layered mode with colorkey - provides much faster rendering of skins with non-rectangular window shape and additionally allows you to adjust transparency of skinned window
o Layered mode with alpha – provides per-pixel alpha channel support and advanced visual effects for compatible skins and also allows you to adjust transparency of skinned window
o Skin format reference guide has been updated to v1.7 to document these changes
o Improved implementation of rollback to default skin
o Full skins cross-compatibility with other overclocking applications based on RivaTuner engine. Special GUI transformation layer allows you to use the skins designed for third party RivaTuner based overclocking applications and makes the process of migration to MSI Afterburner from such overclocking tools much more comfortable for you. You can keep the look and feel of your preferred overclocking application and at the same time enjoy extended MSI Afterburner’s features including full range of supported graphics cards, industry leading powerful and robust monitoring module, flexible video recording features and many more
• RivaTuner Statistics Server has been upgraded to v6.1.3
Personal thanks goes to those of you who took part in closed beta testing program. Thanks a lot, guys. Private beta testing approach seem to be much more effective than public releases of each new beta version. So after launching 4.0.0 we'll continue testing new versions privately.
Some features of 4.0.0 are demonstrated live here.
Alexey Nicolaychuk aka Unwinder, RivaTuner creator
  • 5 uker senere...
Hjalp en kamerat å installere nytt skjermkort i PC-en. Et MSI Gtx 780.
Men etter en dag eller to datt ytelsen dramatisk og kortet begynte å lage en høy coilwhine lyd.
Test skjermkortet i 3 forskjellige pcer bare for å være 100% sikker da vi i starten trodde det var strømforsyningen som var årsaken:
Altså pcen fikk ingen crash eller noe, men skjermkortet fikk langt dårligere resultater
Tok å sammenlignet resultatene med min egen pc som for øyeblikket har 1x gtx 680.
Test med 680: http://www.3dmark.com/3dm/3483787?
Test ned 780: http://www.3dmark.com/3dm/3483789
Alle testene vi kjørte reflektere det samme.
Gtx 780en ga langt lavere ytelse enn mitt 680.
Så etter å ha testet at skjermkortet yter dårlig uansett pc, så sendte vi det inn til cdon.com der det var kjøpt.
Vi registrerte returen noen dager etter 7.juli.
Og nå 11.september fikk vi svar:
Hej *******,
Vi måste tyvärr meddela att reklamationen vi skapat för er produkt blivit nekad, detta då produkten passerat diverse tester som verkstaden utfört. "Coilwhine" faller oftast inte under garantin utan är väldigt vanligt förekommande fel.
Vi beklagar givetvis avslaget, men produkten kommer att returneras till er.
Med vänliga hälsningar
Hugo E
Kundservice Hemelektronik
Jeg tenker at deres testrutiner inngår bare at så lenge det fungerer så fungerer det. Om det lager veldig høy coilwhine og yter dårligere enn forrige generasjons produkt det betyr ingenting.
Hvordan ville dere gått fram videre? Vi må selvfølgelig betale cdon for at dem har "testet" skjermkortet nå også.
Bare det at det tok 8 uker i seg selv syntes jeg er uakseptabelt.
Du får ikke nødvendigvis akseptert coilwhine på reklamasjonsrett, så at de har avslått på grunn av dette er jo en ting. Dette har vel og merke lite med ytelsen å gjøre, så det blir i så fall et annet problem.
1. Ytelsetesten du har lagt ved sier ikke mye. For det første så er det en benchmark ment for mobiler og laptoper, så den belaster knapt skjermkortet, og PCen med GTX 680 har en vesentlig kraftigere og dyrere prsoessor, og over dobbelt så høy minnebåndbredde. Dette teller mye i tester som nesten bare tester CPU (pga grafikken er så dårlig)
Har du andre tester? For du burde egentlig testet Firestrike-delen når du kjørte en yteletest. Og aller helst Extreme-versjonen (koster penger). Da denne presser skjermkortet til det ytterste, og forskjellen i prosessor har mye mindre å si da.
2. Skjermkortet blir ikke bare tregere uten videre. Den er satt til å utføre et gitt antall prosesser i sekundet, og er det defekthet/ustabilitet så vil du nok oftere oppleve at maskinen får blåskjerm, driveren klikker, eller bare svart skjerm.
Jeg sier ikke at et ikke kan bli tregere, men du vil da kunne overvåke om klokkefrekvensen holder seg på det nivået den skal. Eller at minnebruken og spenningene ser bra ut. Dette kan f.eks overvåkes i GPU-Z eller mer nøyaktig i EVGA PrecisionX. Er det strøm/spenningsproblemer så kan det påvirke varme, og at kortet skrur ned frekvensen (throttler) for å redde seg selv.
Akkurat hvordan du går frem nå er jeg litt usikker på, da det nok ikke var så smart å sende det inn uten å teste dette på forhånd. Og Coil-WHine er ikke beste grunnalget å sende det inn på. Mulig de kan bekrefte at kortet kjører testene på oppgitte spesifikasjoner. Men vet ikke om de tar ekstra betalt for dette, eller om du må gjøre det selv når de sender deg kortet tilbake igjen.
Men har du andre grunner til at du tror kortet yter dårligere enn det skal?
Endret av Andrull
Virke som du får den ytelsen du skulle hatt, i hvert fall på Firestrike, som er den mest relevant til skjermkortet ditt.
Edit: Glem det, jeg tenkte på extreme versjonen.
Ja, 4400 poeng er ganske lavt. Nærmere halvparten av hva jeg ville forventet.
Endret av Andrull
Systemet ditt er ikke fylt til randen med drit, eller noe som kjører i bakgrunn og tar opp ressursjer? Kan være noe så enkelt som virus.
Optimalt burde du nok prøvd ditt skjermkort i din venns PC. Sånn at du hadde et bra sammenligningsgrunnlag.
Edit:
Litt usikker på hvorfor 3Dmark bare rapporterer at maks turbo er på 800MHz. Kan også være et problem i BIOS. (eller så er det bare 3Dmark som rapporterer feil, eller Idle-turbo)
Endret av Andrull
Takk for info, skulle testet det litt grundigere før vi sendte det inn, alt for lett å bare sitt en konklusjon før en har sett på alle resultatene.
Skal ta å teste det grundig når vi får det tilbake da. Skal da ta mitt 680 kort inn i kompisen sin pc, og teste 780 kortet i min pc. Da får jeg ihvertfall testet kortet i en pc jeg vet fungerer 100% og et kort jeg vet fungerer 100% i kompisen sin pc.
Men selv om kortet fungerer, så må en altså bare leve med coil whine? Er så høy coilwhine at en kan høre det med lukket dør fra et annet rom og ut i stuen. Er ganske absurd.
Skulle valgt Komplett eller DI, Dustin er også fin!
Komplett godtok mitt 780 Classy med coil whine uten å spørre, Pengene var på konto innen en uke :D
Så de pengene fløy til mobil og nytt Hk. Men har nå spart opp til 980 som jeg håper kommer snart!
Spørsmål
Da 700serien begynte å selge for et år siden satt jeg med 2 stk 770er for å ha i SLI. Ytelsen var det jeg hadde forventet meg, bortsett fra 1 ting. Blåskjerm, ofte. Tror jeg hadde værtfall 1 blåskjerm dagen i den perioden jeg hadde kortene.
Men kan dette ha vært barnesykdommer? Er problemene med SLI i 700serien løst? Sitter å tenker på å anskaffe meg et ekstra 780kort til å prøve ut SLI igjen, hvis prisen synker på kortene nå som 9xx er ute.
Har gjort noen endringer på setupet mitt. Har byttet ut miditårnet mitt CM HAF912 med et større tårn fra Fractal Design, så det vil jo hjelpe på med luftflyt og div.
Takk for respons!
Spørsmål
Takk for respons!
Ikkje bland 770 med 780, så går det bra :D
770 er "overklokka" gtx680 og 780 er ny brikke.
Hvilke 7 serie sli problemer? Er det noe du har hørt :wee:
Det er problemer med alt her i verden, men noe er det mere problemer med. At det er noe 7 serie sliproblemer generelt har det aldri vært.
Største datafeilen er fortsatt brukerfeil :green:
Endret av Nizzen
Blåskjermer kan komme av så mangt. Det har nok ikke noe med barnesykdommer å gjøre.
SLI er gammelt, og noe jeg har brukt i over 10 år. Aldri hatt en eneste blåskjerm som følge av SLI (tror jeg). Men av dårlige drivere, temperatur, overklokking og dårlige programmer så har jeg fått en del i min tid.
GTX 770 er i tillegg et ganske gammelt kort (er jo strengt talt GTX 680 med navnebytte), så barnesykdommer på kjernen er nok heller ikke problemet du hadde.
Trenger litt hjelp her. Mens jeg flashet gpuene på nytt hang pcen seg. Nå finner den bare en gpu, og pcen fyser hver gang jeg skrur den på slik at jeg ikke får flashet. Det er like før pcen går ut vinduet fra 2 ett og ned på asfalten. Nå er jeg jævla lei. Er det noen måte jeg kan ordne dette på uten å drepe pcen?
Ordne at den kan lande på asfalten uten å dø, eller ny BIOS? :p
Hmm, man kan kanskje prøve gamlemåten, hvor du flasher via. en Minnepenn du bootet fra (dos). Dog må jeg innrømme at jeg en gang måtte kaste et skjermkort som en dag trodde den var en GTX 295, selv om det bare var gtx280. Men det skjedde etter driverbug, som på en merkverdig måte påvirket firmwaren.
Prøvde å re-flashe, men uten hell. Dog var nok kortet ekstra bugga kontra ditt.
Går selvsagt ut fra at det er referansedesign? Da alle skjermkortoppsett med respekt for seg selv har to BIOSer, nettop av denne grunnen. Xd
Hadde ikke OC på dem. Hvor sannsynlig er det at det var pga temperaturene?
Nesten umulig å si. Jeg skal ikke hardnakket påstå at det ikke var SLI sin feil, men husk på at dette bare er en enkel driverfunksjon som utgjør noe i spill.
Å ha flere skjermkort er jo ikke SLI (noen kjører ekstra skjermkort for GPGPU og flere skjermkort blandt annet), og så har alltids problemer generelt sett, som kan skje med alle. Samt det faktum at jo flere mulige feilkilder, og jo mer komplisert oppsett, jo verre.
Og det kan være varme, men også så mye annet. Men en ting er sikkert og det var at det ikke var barnesykdommer, for hverken SLI eller korta er noe barn akkurat. ^^
